It is currently Mon Aug 11, 2025 1:33 pm
 Post subject: Back and Side Thickness
PostPosted: Fri Mar 11, 2016 5:50 pm
First name: Brooks
Last Name: Rees
City: Provo
State: Utah
Zip/Postal Code: 84601
I was just wondering, how thick do you make your back and sides? I accidentally took a set of EIR sides down to .08" and the back to .09" in the sander... I'm pretty new to building. Do you think this will be a problem?
PostPosted: Fri Mar 11, 2016 6:07 pm
State: Tennessee
Thats in the ball park, what size guitar? O, OO I might go .080 back .070 sides depends on the wood.
PostPosted: Fri Mar 11, 2016 6:08 pm
Nope, you are good. Assuming back is already joined.
PostPosted: Fri Mar 11, 2016 6:16 pm
First name: Brooks
Last Name: Rees
City: Provo
State: Utah
It is joined. OM size btw. Taylor GS specifically.
PostPosted: Fri Mar 11, 2016 6:53 pm
That's what I would shoot for anyways. There are a number of factors that would make somebody want to go thicker or thinner for different reasons. Depends on what you want to do. But, if you don't really know, I would say those numbers are a fine place to start.
PostPosted: Fri Mar 11, 2016 10:11 pm
You're right on the money!
PostPosted: Sat Mar 12, 2016 1:14 am
Should be fine, but you could beef up the back braces a bit if you want
PostPosted: Sat Mar 12, 2016 9:21 am
First name: Greg
Last Name: Maxwell
City: Mount Vernon
State: Ohio
As noted, you are good. Here's a tip if your new to thickness sanding: Run your wood through twice without changing the sander height. Each pass at the same setting will take off a tiny amount, making it easier to sneak up on your target thickness. It will also help even out small variations across the piece of wood. Good luck!
It will probably be alright.
These users thanked the author Greg Maxwell for the post (total 2): Lonnie J Barber (Sat Mar 12, 2016 7:33 pm) • NightOwl (Sat Mar 12, 2016 2:20 pm)
Users browsing this forum: J De Rocher and 44 guests
