It is currently Sat Apr 18, 2026 1:28 am
PostPosted: Thu Apr 07, 2016 8:12 pm
First name: Jan-Alexis
Last Name: Tremblay
City: Montreal
Hey there,
My father in law bought a guitar when he was a teen in the 70's, a Norman B20, the first commercially made guitar from Quebec. It was a rustic guitar in many ways, with a bolt-on neck and an all laminated birch construction.
So that particular guitar traveled a lot, and was played a lot, and was pretty much left dying, now 40 years later. Challenge accepted.
Here is the beast. The top actually now has an inversed dome, the strings are buzzing everywhere.
It was converted to a tailpiece some time in its history. You can see that crack which goes through and through the (plywood) top, making this virtually unrepairable.
The frets are also a wreck.
And the sides have been sanded through the first ply layer.
And from the inside the X is blown.
Let the fun begin!
PostPosted: Thu Apr 07, 2016 8:20 pm
Last Name: Tremblay
City: Montreal
Sadly, I figured that the top was beyond what was repairable and it had to go.
Rest assured that Norman guitars from the 70's are not particularly rare nor valuable, altough they certainly have a cool vibe to them.
The X was crudely cut and joined, which precipitated the brace failure.
I refreshed the fingerboard surface after truing it up.
Here I join the spruce top the same father in law had laying around in his shed for some decades now.
I decided to go with spruce insteat of birch ply as 1-It's just better and 2-He already has an all ply Norman from the same era.
PostPosted: Thu Apr 07, 2016 8:27 pm
Last Name: Tremblay
City: Montreal
Rosette installation, practice run.
After planing.
New frets are in! Tapped first.
Then glued on with this.
Brace preparation.
I braced during the fall when the RH was a steady 40% in the basement shop.
And this is the end result for the bracing.
PostPosted: Thu Apr 07, 2016 8:33 pm
Last Name: Tremblay
City: Montreal
Gluing the top on.
With judgemental dog.
Next I modified the standard bridge I got to reduce the belly a bit. Polished it up.
I had to arrange this sort of jig to adjust the neck angle in the neck pocket.
Next comes finishing.
PostPosted: Thu Apr 07, 2016 8:54 pm
Last Name: Tremblay
City: Montreal
The challenge with this finish is that I had a lot of things to hide, namely the various places where the ply was sanded through and left hideous scars. So I went with a dark burst, aimed at doing something resembling an old Gibson J45.
However I don't have any spraying equipment and don't want any. So I was left with the "hand rubbed" method, which I really like, and I thought I could pull something out resembling the Gibson Mandolins from the turn of the century.
So here I go. The whole guitar was sealed with shellac first, then the back was slathered with various amonts of transtint vintage brown and amber, with a touch of black opaque pigment here and there. Applyed with rags for the most part, but also brushed un in some places to fake up (subtle) grain lines.
My first try on the top was just horrible.
The problem is that I had the transtint diluted in alcohol, which, as I spread it on the top, softened the shellac undercoat and smeared everything around to a form a dirty colored goo. So I sanded it back and did it again with dye diluted in water this time.
Much better! On this pic I already scraped the bindings.
Similar treatment on the neck here.
I decided to coat the thing in Tru-Oil, as it is compatible over shellac and produces a tougher surface than the spirit varnish I usually do.
PostPosted: Thu Apr 07, 2016 9:08 pm
Last Name: Tremblay
City: Montreal
Reaming bridge pin holes after gluing the bridge and the pickguard.
Nut filing
And that is the end result:
It sounds great and plays great. Overall the burst is certainly a bit blotchy but it kinda has its charm. Pretty sure this thing is gonna live on for another 40 years (or more!). Bringing a dead guitar back to life is really something isn't it?
Thanks for watching!
PostPosted: Fri Apr 08, 2016 12:15 am
First name: Frank
Last Name: Ford
City: Palo Alto
Zip/Postal Code: 94301
Well, sir that's not exactly what I'd call a restoration - it's a TRANSFORMATION - good show!
Cheers,
Frank Ford
FRETS.COM
HomeShopTech
FRETS.NET
PostPosted: Fri Apr 08, 2016 5:57 am
Nicely done!
PostPosted: Fri Apr 08, 2016 6:39 am
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
I've never seen a Norman look so good! I have a 35 year old Lys 12 string that is mint, except for needing a neck reset.
Alex
PostPosted: Fri Apr 08, 2016 7:18 am
Last Name: Sollod
At first I was thinking "why bother", but you made that guitar better than it started out. Good Job!
www.swiftcreekguitars.com
PostPosted: Fri Apr 08, 2016 10:11 am
Chapeau!!
PostPosted: Sun Apr 10, 2016 11:33 am
Last Name: Tremblay
City: Montreal
Thanks guys!
Pretty thrilled with Mr Ford's kudos. I must have spent at least 10 complete hours on his extraordinary website.
PostPosted: Sun Apr 10, 2016 1:19 pm
Last Name: jennings
City: Lopez Island
Zip/Postal Code: 98261
Second and Third Frank's comments… [and you're right, if Frank gives it a thumbs up you're well on the right track!]
So how about a photo with Father in Law….Like to see that facial expression…. [Getting your favorite dinner for the next year of so????]
PostPosted: Mon Apr 11, 2016 8:31 am
Wow that is absolutely fantastic. I must say at first I thought what the heck are you doing with this old junker? But then as I scrolled down it just kept getting better and better!!! The dog definitely approves and you deserve another glass of Chardonnay :D
These users thanked the author jfmckenna for the post: Johny (Thu Apr 21, 2016 10:01 pm)
PostPosted: Wed Apr 20, 2016 7:28 pm
Last Name: Lewis
City: Newnan
State: Georgia
Zip/Postal Code: 30265
That's awesome! That is great of you to do that for your Father-in-Law (and for the guitar)! I always enjoy watching someone bring an old instrument back to life. Thanks for the photo essay. Good stuff!
John Lewis
