It is currently Wed Jul 30, 2025 2:10 pm
 Post subject: Fuji Spray System
PostPosted: Fri Jul 01, 2016 1:33 pm
I have a Mini Mite 4, and I'm in the market for a new gun. My old one has an H4 air cap. But I see that their standard issue gun is equipped with an H3 cap, and it's also rated for nitro. Is anyone else here shooting nitro through a Fuji HVLP spray system? If so, which size air cap are you using--H3 or H4?
michael propsom
www.propsomguitars.com
 Post subject: Re: Fuji Spray System
PostPosted: Fri Jul 01, 2016 3:17 pm
I spray with an older Fuji system. It came with an H3 but since I've changed to an H4 and seem to get better results.
These users thanked the author Jim Watts for the post: jsmith (Fri Jul 01, 2016 10:12 pm)
PostPosted: Fri Jul 01, 2016 4:50 pm
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
We have the Fuji four stage turbine and have used the XPC and T-75G guns for lacquer and waterbased finishes. The 1.3mm aircap/needle set for the T-75G does a nice job on lacquer - on par with the Iwata and SATA conversion guns in the shop. While the 1.3mm set will spray waterbased, the 1.0mm does a better job atomizing finishes like Enduro-Var. All stainless fluid passages, etc. The T-75G runs about $319 via Amazon Prime. If converting to the PPS system, the #2 adaptor works (same as Iwata full-sized guns use).
- Beth Brower
These users thanked the author Woodie G for the post: jsmith (Fri Jul 01, 2016 10:12 pm)
PostPosted: Fri Jul 01, 2016 10:02 pm
FWIW, there is a recent discussion on Fuji HVLP systems and guns on MIMF Forum this week. You might want to check it out.
These users thanked the author WaddyThomson for the post: jsmith (Fri Jul 01, 2016 10:12 pm)
PostPosted: Fri Jul 01, 2016 10:13 pm
Thanks, gentlemen!
michael propsom
PostPosted: Sat Jul 02, 2016 10:17 am
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Zip/Postal Code: 43085
Mine came with a 4 but I changed to a 3 and feel I get better results with Mohawk stringed instrument lacquer, but of course, YMMV.
I'm not a luthier.
These users thanked the author klooker for the post: jsmith (Sat Jul 02, 2016 12:04 pm)
Users browsing this forum: CarlD and 7 guests
