It is currently Tue May 05, 2026 7:15 pm
PostPosted: Tue Jul 19, 2016 10:10 pm
I tired using the search on the site but I didn't come up with the specifications for the Martin 00028 EC. I am wondering about the top and back radius. I am thinking of making some radius dishes and thought that while I was doing the 15 inch, 25 inch and the 30 inch I would make a couple for the 000 also. However I have not been able to come up with the radius that would be needed.
Anyone know where I can get the specification for the Martin 00028EC?
Thanks for any help you can provide.
Chuck
PostPosted: Tue Jul 19, 2016 11:35 pm
Martin sound board bracing contour is 52' (X and tone bars) and the backs are 15' --- If you contact the factory they'll proudly tell you they make "flat top guitars"
The top of the rim is sanded flat with a 1.3 degree of slope from the sound hole to the neck block. Pictures of the rim sander can be seen here in this article.
http://www.kennethmichaelguitars.com/neckangle.html
Ken Cierp
PostPosted: Wed Jul 20, 2016 6:58 am
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Zip/Postal Code: 43085
If I'm not mistaken, Martin also glues their braces to the top on a flat surface - no dish or concave fixture.
I'm not a luthier.
PostPosted: Wed Jul 20, 2016 8:06 am
the tone bars on Martin are flat the only radiused braces are the 2 X and the Transverse . The neck is a mod Vee they use a fine herringbone Squares and diamond fretboard
Fine herringbone rosette
PostPosted: Wed Jul 20, 2016 8:22 am
Here's one of Martins sound board vacuum clamps -- I'll ask my Martin Engineering contact if its flat or slightly contoured.
There's plenty of boutique builders that use tighter radius bracing than Martin -- the folks at Santa Cruz and Taylor have indicated that this strategy increases treble response with the net result of less perceived bass response.
Ken Cierp
PostPosted: Wed Jul 20, 2016 9:36 am
Update from the Martin factory
Hi Ken,
That is a top bracing fixture. The plate is flat with a 1deg. angle that starts at the back of the number 1 brace just above the soundhole and continues to the top or front block.
Ken Cierp
Users browsing this forum: Kbore and 54 guests
