It is currently Wed Aug 13, 2025 5:08 am
Post new topic Reply to topic  [ 36 posts ]  Go to page Previous  1, 2
PostPosted: Tue Jul 26, 2016 9:44 am
Rocky Road wrote:
Wow. And just when I thought I was beginning to get a handle on this craft and move a little closer to a build that sounds consistently great. Then I went and read this thread. But seriously. The one thing that struck me is that we're always trying to put our fingers on the factors that consistently move the quality of tone one direction or another. But the materials we are using are not measurably consistent. Wood just in one specie alone varies greatly in its sound giving qualities I've built my necks always of mahogany. And noted great differences between each one. Possibly density? Amount of resins?
Age? And as Hesh noted what is the "killer" sound? Different to everyone. We all expect a different great sound from a stringed instrument.
I'm not saying that it's not possible to analyze. But yes, it is beyond rocket science. This is just one reason which makes this craft so enjoyable. Not to mention the great talent this forum taps into.
This is why I don't really like to build on commission. I am building one now on commission. And the buyer wants it because he heard one of my other guitars and loved it so much he wants me to build one just like it. That makes me nervous because I know that it's actually quite impossible to do so. But if I stick to the program I'll at least get close.
These users thanked the author jfmckenna for the post: Bryan Bear (Tue Jul 26, 2016 9:53 am)
PostPosted: Tue Jul 26, 2016 9:53 am
First name: David
Last Name: Riedmiller
State: WI
DennisK wrote:
Alan Carruth wrote:
1) it's awfully hard to make a big improvement in the standard designs,
I agree to some extent, but you have to keep in mind that the standard designs are also optimized for production efficiency and warranty minimization. We hand builders can afford a lot more man hours per guitar, and can expect our customers to be more careful with them, so our fully optimized designs will tend to be a bit different.
Hesh wrote:
I wanted to think of torification/torifaction as snake oil and then I heard one of the best sounding to my ear instruments ever with you guessed it, a torrified top.
I need to try one sometime. From all the descriptions, it just sounds like a process to turn spruce into redwood :P But to my ears, that would indeed be an improvement. Most of the time, anyway. Last year I built a steel string harp ukulele with a thunky sounding riftsawn bearclaw sitka top, and it turned out to have the magic. So that's one more data point in the category of "you can't explain that" :lol:
Yeah. I've built two with torrefied tops so far, and the results on both have exceeded my expectations. One a slope D. The other a OLF small jumbo. Both of these I've built with non aged tops in the past. Neither of the earlier builds have the punch volume or sustain. But again, hard to make a truly critical comparison, without weighing in all the variables, known and unknown.
"It is easier to fool a man, than it is to convince him that he has been fooled"
Mark Twain
These users thanked the author Rocky Road for the post: Hesh (Tue Jul 26, 2016 12:34 pm)
PostPosted: Tue Jul 26, 2016 11:00 am
kencierp wrote:
Quote:
No offense intended to those who did the research, math, spent the time in the trenches etc. IME no one has adequately gotten to the point where they can explain exactly what is happening with an acoustic guitar. We have read many, many doctoral thesis available in every college town USA (and your country too) and there is no agreement.
Amen to that - I believe most famously Michael Kashsa indicated that he had it figured out, the folks at Ovation too. I'll stop there. The point is, there is no consensus.
I personally like to keep the sound board structure lightly built -- but there are those that will tell me I have to take care or I will over drive -- seems to me the player touch and the string set tension are adjustable variables dictating that end result. So I believe there usually is a ying and a yang for most of our build choices.
To my ear one of the best sounding Martin OM's I played was on a rack in a store in State College PA right along side other Martins of the same style. This one noticeably weighed far more than the others. I made that comment to my brother he agreed, but in the end the only difference was the totality in weight of the materials used for that particular guitar. I did not go back to our shop and try and build a heavy guitar.
Plus 10 to most of that. I don't believe in lightweight guilars, never believed in lightweight tops
and don't believe in lightweight bracing. Some may put lightweight in fine, exponential words, but I'll just say...Larson.
These users thanked the author Haans for the post (total 2): kencierp (Thu Jul 28, 2016 8:21 am) • Hesh (Tue Jul 26, 2016 12:33 pm)
PostPosted: Tue Jul 26, 2016 12:30 pm
Rocky:
It is actually quite possible to predict some of what will happen objectively to the sound output of a guitar in many cases when you make one or another change. For example, adding a 'port' in to an existing guitar will always raise the pitch of the 'main air' mode, and make it more powerful. What you can't say is what that might sound like to a particular listener or player;whether that's 'good' or 'bad'.
It's also quite possible, and even not too difficult, to test the wood you use to find it's properties. Some of us have been doing it for years. After a while, when you have enough data, you might start to see correlations between some of the wood properties and your impression of the tone of the guitars. Somebody else might hear things differently, of course, but that doesn't matter in a sense. If you can come up with any sort of objective correlation with the sounds you like, and can figure out how to move the sound in one direction or another by the choices you make, you're on your way to making more consistent instruments. Of course, not everybody will like the same things you do, but that's OK too. All you need to do is find enough folks who agree with you who will buy the things you make; you're not trying to sell one to everybody.
DennisK:
I think we're actually saying the same thing. That was my point number 2. Many of us use more or less 'standard' sizes, shapes, and brace layouts, based on designs by Martin or Taylor or Gibson. For one thing, this makes it a lot easier to buy decent cases! We don't just build copies, though; we change things like the thickness of the top or the sizes and profiles of the bracing to try to optimize the outcome, based on our own understanding of the way the things work and the material we're working with. This is something we can do that factories simply can't. For the most part it amounts to 'build tweaks', as I said, although it can lead to substantial re-design in some cases.
I've been at this long enough that I've seen several 'radical' designs or features that were very highly touted come and go. Naturally, nothing of that sort ever completely dies out, but I can think of a couple of systems that made big claims about totally revolutionizing the field that are, at best, on the fringes now, and seldom seen. It's always possible that the latest thing WILL revolutionize the field, of course, but given the history of the guitar so far I'm not going to hang my hat on that.
These users thanked the author Alan Carruth for the post: Bryan Bear (Tue Jul 26, 2016 3:45 pm)
PostPosted: Tue Jul 26, 2016 4:05 pm
First name: Kerry
Last Name: Werry
City: Coquitlam
State: British Columbia
I always enjoy reading threads like these they get you thinking and in many ways they confirm what we already know.. they are more ways to build a good guitar than we know.. Now I'm a rank amateur when it comes to guitar building and I'm not sure I have enough years left to really know what I am doing, which is of course part of what draws me to this.. I appreciate reading Hesh's and Al's comments here I'm sure they have forgotten more than I'll probably ever know..
One thing I "think" I have figured out is cherry picking ideas does not work what I mean is say luthier #1 does this to his bracing and luthier #2 does this to his neck well then if I do both of those things my guitar will sound better (what ever better is and whoever decides that) well I don't think that is the case I "think" those people who build what most of us agree is a good guitar have through special knowledge or trial and error come up with call it a "system" that produces what they want and picking pieces of other peoples "systems" and trying to make a guitar out of them probably will not turn out as you hoped...
Plan on building a heavy guitar know it will be heavy and build the whole guitar around that premise and it may well turn out good same with a light guitar or a loud guitar or a soft guitar or whatever....
The first guitar I built I sold for a cheap price (it was not very good and it was taking up space in the house) they guy who bought it said " this sounds odd not like any guitar I've heard before, I kinda like it" Bottom line everything effects sound (at least a tiny bit) and everyone hears sound differently.. It does keep things interesting...
Kerry
My Website http://klw-strings.com
My Luthier's Blog...http://klwstrings.blogspot.com
These users thanked the author kwerry for the post (total 2): Alex Kleon (Wed Jul 27, 2016 5:55 pm) • Hesh (Wed Jul 27, 2016 11:56 am)
PostPosted: Wed Jul 27, 2016 8:43 pm
Last Name: Cox
So... When I read the title - I said "yep"... But when I read the post... "Nope"...
Things seem to turn out better when they are balanced out... And oddly, it works opposite of what you think.
For example - a heavy neck will probably need a heavy body to balance it out so it doesn't feel neck heavy and unwieldly. Then - you just need a good strap and all is fine.
If I was going to do it... The BRW neck would go on a rosewood body guitar.... And I wouldn't try to go thin on the sides.... And it would probably get a stout tail block to balance things. I think a heavy neck like that would be less desirable on a maple, cherry, or Spanish cedar guitar....
Sound wise - assuming you do your part, it will sound good. I did an oak B/S guitar with an oak neck. It's heavy but it sounds really good. The guitar doesn't give up anything due to the weight of the neck.
One thing I will say is... Carving heavy/dense wood into necks is quite a chore. It's not a spokeshave/draw knife/violin knife sort of job. It's a rasps, power tools, and sandpaper job. Wow that oak neck was a job to shape....
PostPosted: Thu Jul 28, 2016 3:14 pm
First name: Josh
All I'd add to this discussion is that in my experience ergonomics are at least as important as sound when it comes to determining whether someone falls in love with a guitar. Possibly more important, as the set up wizards like Hesh can probably attest to.
For this reason alone, I personally would avoid any severely neck-heavy design.
PostPosted: Thu Jul 28, 2016 4:58 pm
If I understand correctly you are going to laminate the BZ with Maple into a five piece neck. I say go for it. You'll never know till you try. I would think it fits the category of a "little tweak" on a conventional design. Please report back here and let us know how it worked out.
I did see a resonator once that a guy built with a solid BZ neck and it was ##@!! heavy.
PostPosted: Fri Jul 29, 2016 11:49 am
First name: Leonard
Last Name: Duke
City: Kalamazoo
Zip/Postal Code: 49001
Prototypng an idea for a design hunch (as in light top/ heavy body) takes a heck of a long time. My advice is make sure you admit to yourself that the first two are prototypes and build them as quick as you can with the least attention possible to ornamentation, bindings, fine appearance. Just get the dang thing playing, and be ready to take the back off and whittle away or add wood. Once you get the design sounding in the manner you intend, build a beautiful one.
As much as it irritates us, great guitars are usually made by copying other great guitars. The more experiments you put into one guitar, the less you know which change made which difference.
These users thanked the author philosofriend for the post: Hesh (Fri Jul 29, 2016 2:45 pm)
PostPosted: Fri Jul 29, 2016 4:08 pm
Overholtzer used solid brazillian rosewood for the necks on his "award winning" classical guitars.
They must have been severely unbalanced.
These users thanked the author Jeff Highland for the post: Hesh (Sat Jul 30, 2016 1:14 am)
PostPosted: Sat Jul 30, 2016 10:28 am
First name: Fred
City: Winnipeg
As dense as Rosewood, if not more. Also interlocked grain which seems to have a waxy feel. Basically use rasp, file and sandpaper, sweat buckets on this one. Have four more to use, saving them for people I really, really like. Not worth the effort otherwise.
