It is currently Sat Sep 20, 2025 4:21 pm
PostPosted: Thu Sep 01, 2016 8:59 am
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
There is a seller on e bay selling these on e- bay for bridge removal . I have a cracked bridge that needs to be removed from a small guitar .Anyone have experience using these small blankets ?? thanks
PostPosted: Thu Sep 01, 2016 9:08 am
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
We use a 1" x 6" blanket originally purchased from John Hall's Blue Creek Guitars. Even at six inches of length, the last 1/4" to 1/2" or so of a silicone blanket lacks heating elements, so we could probably use a 1 x 7 inch blanket and avoid having to flip things when one or both bridge wings are very well attached. Blankets are sold with 5W, 2.5W, and 1.25W power ratings per square inch from our blanket vendor. With a rheostat-controlled blanket (we use a cheap Harbor Freight router speed control for the smaller repair blankets), it seems that the highest power setting available is desirable, given that the blanket can be throttled by the controller for less output.
- Beth Brower
These users thanked the author Woodie G for the post: ernie (Thu Sep 01, 2016 9:12 am)
PostPosted: Thu Sep 01, 2016 11:19 am
I bought one from LMI a long time ago (don't recall the specs) but it works great.
PostPosted: Thu Sep 01, 2016 1:48 pm
Last Name: Farmer
City: Durango
State: CO
I used a 25w 1x5 LMI at someone else's shop.. Not much power. Too slow. That's what prompted me to come up with the system in the photo.
Soft silicone rubber insulates the backside and dramatically improves contact.
John Hall's 1x6 blanket is 30watts and much better in my opinion.
Pros and cons in any system. These days I mostly use a heat lamp. It's always mounted over my bench for keeping Glue ups warm. Just swing it over and turn it on. You just have to get your heating times dialed in.
The good part about a blanket is, contrary to the photo, you need no heat shield.
You can also always see the finish. Even direct a fan on the top. you can also try a spatula on the joint even as it continues to heat up instead of racing the cooling process.
PostPosted: Thu Sep 01, 2016 3:17 pm
Omega is our supplier --- never any issues
http://www.omega.com/pptst/SRFR_SRFG.html
Ken Cierp
PostPosted: Thu Sep 01, 2016 6:29 pm
Last Name: Spector
City: ORANGE
Zip/Postal Code: 77632
I've been building guitars a few years now but I've been taking things apart since ... What crosses my mind is why nobody has come up with a heated spatula, other than using a torch or hotplate for working between the pieces.
PostPosted: Thu Sep 01, 2016 7:36 pm
Last Name: Farmer
City: Durango
State: CO
One reason is by the time a hot spatula contacts glue ahead of it, the surfaces must already be apart the thickness of the blade. I think even with a continuous heating of the blade, your mostly heating wood that's behind the place your trying to separate.
PostPosted: Fri Sep 02, 2016 8:41 am
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
I ordered a 1 by 6 for $15 from china off e bay . I only have 1 classical style bridge to do. Thanks to everyone for the pics , info and advice .I appreciate it . There is a sale on at harbor freight today , and I need to get some timers for my 3 other silicone heating blankets, just for insurance . You never know when you can get distracted, I/ve always just pulled the plug on the blankets . But time to play it safe. PS I would rather have a slower heating blanket than a quick one.
PostPosted: Fri Sep 02, 2016 9:11 am
Last Name: Farmer
City: Durango
State: CO
The speed is not impatience. The slower the heat up, the greater the chance of heating things you don't want to, bridge plate, braces, finish, etc.
PostPosted: Fri Sep 02, 2016 9:25 am
I would say that the heat up time variance between a six inch and a five inch strip at 5 watts per square inch turned on at full power is marginal at best. I believe Omega does offer 10 watts per square inch units.
Ken Cierp
PostPosted: Fri Sep 02, 2016 3:31 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Good point david I will do a HHG glue up on scrap first and test the silicone heating blanket
Users browsing this forum: No registered users and 83 guests
