It is currently Sun Jul 27, 2025 10:13 am
PostPosted: Tue Sep 06, 2016 10:08 am
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
I have some some epoxy I want to use as a filler on white oak uke I have some silica filler as well. What would be a good thinner for this product in your opinion ??. DA. ? laquer thinner , ? acetone , and to what ratio ? 5-10% I read john greven/s article in the GAL but not sure how much silica or thinner to use . Also warming up the wood to 100-115 deg seems to help. Your thoughts ?? thanks
PostPosted: Tue Sep 06, 2016 3:42 pm
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Zip/Postal Code: 43085
You may have already read this, but here's an article about thinning epoxy from West System's site
http://www.westsystem.com/ss/thinning-w ... tem-epoxy/
Sorry, no personal experience. I do use West Systems 105/207 to pore fill though but I don't thin it.
I'm not a luthier.
PostPosted: Tue Sep 06, 2016 4:09 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Thanks I read it. Got no real answers . I replied to your rosette question , blonde dewaxed shellac 2 thin coats.
PostPosted: Wed Sep 07, 2016 7:15 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
I always added enough fumed silica to make a stiff paste similar to beaten egg whites. Thinning is counter productive when actually filling. The silica makes the epoxy stiff so it doesn't sag out of the pores before it drys. The only time I thinned the product was my final wash coat after sanding when I just wanted to be sure all the wood was sealed and there were no bare spots.for this I used my fastest lacquer reducer. Can't remember the ratio but I made it water thin.
Brian
PostPosted: Wed Sep 07, 2016 7:28 am
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Thanks again for the explanation Brian.Your method seems to align with all the other people using this product.It/s been awhile since I/ve used epoxy. 30% for silica. and a very thinned out final wash coat by adding laquer thinner
PostPosted: Wed Sep 07, 2016 3:40 pm
First name: Tim
Last Name: Benware
City: Creedmoor
Zip/Postal Code: 27522
No thinning is correct. I have used System 3 SB-112 for 7 years now and mix it 10:4.4 grams and add 1 teaspoon of silica to the mix. I use the weight mix ratio as I have found it to be finickier than other epoxies when mixing. If you don't get the mix right it doesn't cure properly. I get on application per batch (body, neck, head plate) and clean up with DA. If I need to put on a thinned layer I use DA to thin, no silica (rarely do this).
"I've been had again"
Tim Benware
Creedmoor, NC
PostPosted: Thu Sep 08, 2016 7:41 am
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Thanks Ben , do you use 2 or 3 coats ?/I/ve put on 2 and will sand back today, an do a 3 rd .wash coat. Last batch was streaky .I used a razor blade to apply it. I/m practicing on a test sample
