It is currently Tue Jul 29, 2025 10:25 pm
PostPosted: Mon Sep 12, 2016 11:02 am
First name: Jason
Last Name: King
City: Austin
State: tx
Zip/Postal Code: 78749
Country: uSA
Good morning:
Finished my first build a while ago and I'm getting ready for my second. I'm thinking of trying out the radius dish/go bar deck setup for gluing up the back and top bracing, but I'm not sure I'll like it.
I was tempted to buy 1 radius dish just to see how it goes instead of getting multiple dishes (one for the back, and one for the top). Is there a commonly accepted general radius that will work well for both the back and the top? I can't see why having the same radius for the top and back would be a bad thing, but most folks seem to have different radius dishes for everything.
What sayeth the group? Can one dish do the job (at least for a test guitar)? And if so, what's a good middle of the road radius? 25', 20', etc.?
Thanks again,
Jason
PostPosted: Mon Sep 12, 2016 11:25 am
I know makers that use 25' or 28' for both
But check out our dish prices likely you can afford a pair.
Ken Cierp
PostPosted: Mon Sep 12, 2016 11:26 am
Last Name: Smith
City: Graton
Zip/Postal Code: 95444
Most builders want a greater radius on the back than the top. Also having separate dishes for the back and top allows you to use one while the other is out of service during glue up.
Michael F Smith
Goat Rock Ukulele
http://goatrockukulele.com
PostPosted: Mon Sep 12, 2016 11:28 am
Last Name: Denvir
City: Baltimore
State: ON
Zip/Postal Code: K0K 1C0
Hi Jason, fwiw, I build with a 25' back radius and a flat top, and it seems to work fine. Some excellent, high-profile builders use a flat top.
If you don't like it, you can always try a radiused top on subsequent guitars.
Good luck
These users thanked the author JSDenvir for the post (total 2): BradHall (Thu Sep 15, 2016 7:27 pm) • kencierp (Mon Sep 12, 2016 11:35 am)
PostPosted: Mon Sep 12, 2016 11:31 am
A 28 foot radius will work for both the top and back. If you arch the top too much it makes it harder to fit the neck.
PostPosted: Mon Sep 12, 2016 11:41 am
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
I have to confess that I use the same radius for both top and back. Though you should remember, I am far from an expert. I made an adjustable radius dish a long time ago because I thought I would want to do all types of different radii. The dish worked well enough but the only problem was it was never totally obvious from a glance what radius it was set to (since it does multiple radii you can't just label it). I worried that I would forget to adjust it or change it back moving from top to back and whatnot. I have been just using the same radius I use for the top on the back. In fact, I don't even know what radius that setting actually is. A long time ago I made a radius template based on the spline curve Cumpiano recommends for tops in his book. I set the dish to that and haven't touched it in a long time. I'm interested to hear the responses on this, who knows, I may be persuaded to go back to a more pronounced radius for the back. . .
Bryan Bear PMoMC
PostPosted: Mon Sep 12, 2016 12:09 pm
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
I use two different radii, 25' for the top and 15' for the back. If you decide to use one radius for both, I think it makes sense to use a radius closer to what people use for the top for both, i.e., a 25' or 28' radius dish. If you go the other way, and use a 15' radius for both the top and back, the top is going to be pretty round, and that can cause all sorts of problems. Using a 25' or 28' radius on the back just means you have a flatter back than other folks, and that's no big deal. Having a rounder top than other folks can be a big deal.
PostPosted: Mon Sep 12, 2016 12:12 pm
I also use the 25' top and 15' back - that's a pretty common configuration but by no means the only one or necessarily the best either. I would not hesitate to use 25' for both top and back. I would not use 15' for the top as that would require increasing the neck angle more than I would like.
PostPosted: Mon Sep 12, 2016 1:00 pm
If you contact the Martin factory they'll proudly tell you that Martin makes flat top guitars. However the main braces are contoured to 52' and the finger board extension area is sloped 1.3 degrees, note the top edge of the rim is sanded flat and sloped on a two stage sander. Currently Martin backs are contoured to 15' braces and rim edge sanded to match.
You can find more detail and images here:
http://www.kennethmichaelguitars.com/neckangle.html
Ken Cierp
PostPosted: Mon Sep 12, 2016 1:16 pm
First name: Freeman
Last Name: Keller
I'm another who uses 16' for the back and 25' for the tops, however I only own one radius dish (the 16 footer). When I glue the top braces on I pre radius them (on a belt sander) and simply clamp against a 25 foot caul (piece of wood that I've sawn to that radius).
The 16' dish does come in handy when sanding the rim to fit the back
PostPosted: Mon Sep 12, 2016 1:34 pm
And for assembly there's this method:
http://kennethmichaelguitars.com/contourtool.html
Which we use in our vacuum clamp since some braces are flat not contoured while the main braces have a 40' contour -- kills two birds with one stone so to speak.
Ken Cierp
These users thanked the author kencierp for the post: cablepuller1 (Mon Sep 12, 2016 2:52 pm)
PostPosted: Mon Sep 12, 2016 2:11 pm
First name: Jason
Last Name: King
City: Austin
State: tx
Country: uSA
Great discussion. This forum never ceases to amaze. Kenicerp, it looks like I'll be buying 1 (or 2) dishes in the near future.
Thanks again everyone.
PostPosted: Mon Sep 12, 2016 5:38 pm
First name: Freeman
Last Name: Keller
I have used Ken's card idea ( a stack of business cards works well) for the top - recommended.
PostPosted: Mon Sep 12, 2016 6:59 pm
First name: D
Last Name: S
Wow! 52' radius?
Is that even measureable over a 20" span?
Very interesting, Ken!
wah
Wah-wah-wah-wah
Wah
PostPosted: Mon Sep 12, 2016 9:04 pm
Quote:
Wow! 52' radius?
Yes you can see the 52' contour and even the 65' that Taylor uses for their top of the line models. Of course it not much. Its best to have some level of doming -- since a domed plate actually has more surface area covering the perimeter than a perfectly flat plate. The sound board braced to form a dome has a little better chance of surviving low humidity shrinking rather than cracking.
We sell plenty of both sizes -- I should note that Taylor also uses perfectly flat braces on these top end models said to have slightly more perceived bass response.
Ken Cierp
These users thanked the author kencierp for the post: dzsmith (Mon Sep 12, 2016 9:05 pm)
PostPosted: Tue Sep 13, 2016 9:04 am
As Usual, I did it different.
My tops were 10' cylindrical and backs were 10' dish.
These users thanked the author Haans for the post: Ken McKay (Fri Sep 16, 2016 1:43 pm)
PostPosted: Tue Sep 13, 2016 8:11 pm
First name: David
City: Napa
Zip/Postal Code: 94558
When I toured Michi's new shop I was surprised to find that he uses 50' for the tops.
PostPosted: Tue Sep 13, 2016 10:02 pm
First name: Brad
Last Name: Combs
With a radius of 50' plus, is there a need to flatten the upper bout / soundboard for the fretboard extension any more?
PostPosted: Wed Sep 14, 2016 6:18 am
Keep in mind that, as an example, the process at the Martin factory sands the top edge of rim flat and the extension area is also sanded flat -- the important point is the extension area including the neck block are sloped 1.3 degrees.
In other words -- at least Martin (and I agree) see no value in sanding the tiny bevel on the rim edge that would be produced with a 52' contoured sanding dish.
Ken Cierp
These users thanked the author kencierp for the post: askins (Wed Sep 14, 2016 12:38 pm)
PostPosted: Wed Sep 14, 2016 6:57 am
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
We use a different approach in the shop to fix the neck geometry, but I've had some pro/con discussions on milling in upper bout wedges with other builders. I would think that approach would be the most consistent way to ensure a fixed geometry, but it seems as though Martin still needs multiple bridge thicknesses to get to a reasonable saddle height and has more variation than I would expect to see. Is the variation just the usual bell curve of stiffer/softer bracing, top, etc., or due to a reluctance to expend labor in fine-tuning the the neck angle in the manufacturing process? Or perhaps just the normal distribution at work with materials and factory processes generating the 1/32"-1/16" differences in overall distortion of the guitar at string-up?
- Beth Brower
PostPosted: Wed Sep 14, 2016 11:31 am
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
Ken
Thanks for the index card tip - I will use it on my next instrument. Fascinating topic
Ed
PostPosted: Thu Sep 15, 2016 12:33 pm
I pulled 30' for the top and 15' for the back out of my hat for no good reason 13 years ago and stuck with it. I have to angle the upper bout a little with a sanding jig.
