It is currently Tue Jul 22, 2025 1:19 pm
Post new topic Reply to topic  [ 243 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6 ... 10  Next
PostPosted: Mon Nov 14, 2016 1:42 pm
First name: Daniel
Last Name: Petrzelka
State: Washington
SteveSmith wrote:
I also tried the CA route once with the same result you had. Some kind of glue would be nice. I have been using basically a small nail ( broken dental pick) to hold them on and then outlining in 0.03mm pencil; it works ok but has some drawbacks. I could do a better job if I could glue the inlay down and trace it, probably with the tip of a #5 Xacto knife, or maybe a very sharp, small scribe depending on the shape of the piece. Need an adhesive that will dissolve with Naptha - the way we do with double-stick tape.
I wonder if Super 77 spray mount would work?
PostPosted: Mon Nov 14, 2016 2:13 pm
Don't know - I think I have a can somewhere. If I can find it I'll try it out.
PostPosted: Mon Nov 14, 2016 2:24 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
I've used both CA and Titebond to hold inlay pieces in place for scribing or marking around them. Both work fine but the key is that the glue has to be applied as a tiny dot (or a couple dots on a large/long piece). It's surprising how little of it is needed to hold the inlay piece in place for marking. For CA, a dot no bigger than 1/32" works. Sliding a razor blade under the edge pops the inlay right off without breaking it.
These users thanked the author J De Rocher for the post: SteveSmith (Mon Nov 14, 2016 2:35 pm)
PostPosted: Mon Nov 14, 2016 4:26 pm
Last Name: Miller
City: Wood Dale
State: Illinois
Fiddleback mahogany tenor ukulele for my wife. Work in progress but couldn't resist a picture with it partially assembled.
PostPosted: Mon Nov 14, 2016 5:23 pm
First name: Kerry
Last Name: Werry
City: Coquitlam
State: British Columbia
Always like these threads..
Right now I'm working on a nylon string crossover with cutaway and a tenor uke..
My Website http://klw-strings.com
My Luthier's Blog...http://klwstrings.blogspot.com
PostPosted: Tue Nov 15, 2016 10:02 am
First name: Rob
Last Name: Lak
State: Massachusetts
I'm working on.... acquiring tools, building forms, benders, go-bar deck, shooting board(s), biding jigs, etc.
The process of figuring out the basic needs is interesting, fun and frustrating. Learning lessons about various vendors.
PostPosted: Tue Nov 15, 2016 5:26 pm
Last Friday I bent this .08" ebony for a fanned fret headstock backstrap. Never again. From hence forth, the rear veneer will be .06" or less.
The next day my wife was out of town so I made an impromptu decision to clean it up over the kitchen sink. If I didn't have an exam tonight I'd be flossing the neck joint and gluing the fretboard today, but it'll have to wait.
PostPosted: Wed Nov 16, 2016 7:40 pm
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
An update to my previous post. I have may Indo Rosewood\ Sinker Redwood ready for finish prep. About 2 weeks ago I put on two coats of x-poxy on the back and sides waiting for some neck wood. The bindings are australian blackwood Here is where I am at.
PostPosted: Wed Nov 16, 2016 7:45 pm
First name: Jay
City: Bothell
State: Washington
Beauty! Do you have a closer photo of the rosette?
PostPosted: Wed Nov 16, 2016 8:18 pm
Last Name: Parchem
City: Seattle
State: Wa
Thanks Jay,
The rosette is just an Amboyna Burl ring with bwbbwb fineline purflings inside and out.
These users thanked the author johnparchem for the post: J De Rocher (Thu Nov 17, 2016 6:53 pm)
PostPosted: Wed Nov 16, 2016 10:08 pm
Good looking stuff folks.
I've not been in the shop since I started this tread. There was a tragic incident in our small town which took all my attention away.
On the inlaying, I've tried many different ways to hold the pearl and I've found CA the easiest with acetone to release it. Be patient with the acetone, it just takes a bit of time to get at the glue.
I wouldn't try super 77 as you'll just end up filling the pores of your wood with it. Might not be good when it comes time to finish...
These users thanked the author Rod True for the post: SteveSmith (Thu Nov 17, 2016 8:51 am)
PostPosted: Wed Nov 16, 2016 10:11 pm
First name: Brad
Last Name: Combs
Putting in dust collection to each machine. No more moving the hose!
These users thanked the author bcombs510 for the post: James Orr (Fri Nov 18, 2016 2:16 pm)
PostPosted: Fri Nov 18, 2016 7:12 pm
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
Not my idea, but I have used a small drop of shellac to hold down inlays. A drop or two of alcohol and a razor blade get it off - be careful, I had a tiny little square on a Style 3 soprano uke fly across the room and my 7 year old grandson found it along the wall.
Ed
PostPosted: Sat Nov 19, 2016 8:01 pm
State: Tennessee
Picked up the rest of the White Oak, ended up with twice the amount I asked for........ fitted and flossed a neck. Got a pretty good handle on my Luthier Tool neck angle jig
PostPosted: Sat Nov 19, 2016 9:07 pm
Those oak quarters look nice ... and heavy too:)
PostPosted: Sun Nov 20, 2016 6:45 am
State: Tennessee
Very nice if I say so myself, and too heavy, I'm going over my options for milling these.
PostPosted: Sun Nov 20, 2016 1:44 pm
Nice shop Brad!
These users thanked the author Colin North for the post: bcombs510 (Sun Nov 20, 2016 8:31 pm)
PostPosted: Sun Dec 04, 2016 8:34 pm
First name: Brad
Last Name: Combs
Got to try out the new go bar deck this weekend. I'm not sure the spacing is Woody approved, but it's nice to have enough to do all four back braces in one shot. Blackheart Sassafras with SM torrefied bracing. I like the smell of this stuff. Kind of molasses or something. :)
Brad
PostPosted: Mon Dec 05, 2016 6:00 am
I've been putting together an idea for a simple saddle slotting mill.
These users thanked the author Colin North for the post (total 2): Don Williams (Wed Dec 21, 2016 10:56 am) • bcombs510 (Mon Dec 05, 2016 6:39 am)
PostPosted: Mon Dec 05, 2016 7:44 am
First name: Lou
Last Name: Moritz
City: Fords
State: New Jersey
Zip/Postal Code: 08863
Awaiting customer to come over so i can profile the neck to his liking. He requested a chunky 58/59 profile. I think I got enough there for that ! laughing6-hehe
Once the neck is done I can fire up the glues pot and glue it up !
These users thanked the author SG Lou for the post (total 2): Colin North (Mon Dec 05, 2016 10:48 am) • bcombs510 (Mon Dec 05, 2016 8:21 am)
PostPosted: Mon Dec 05, 2016 10:44 am
First name: George
City: Seattle
Great looking work on display by you guys!
These are poor quality pics, but I just strung up this OM with WRC over wenge, curly maple bindings, and a walnut neck. I made this for my sister to give to her boyfriend for Christmas. Still have to finesse the setup, but I think it's going to be a pretty nice guitar. Hope to take better pics soon.
George :-)
These users thanked the author George L for the post: Colin North (Mon Dec 05, 2016 10:48 am)
PostPosted: Mon Dec 05, 2016 11:27 am
Building a replacement bridge for an old Guild D-40 restoration.
PostPosted: Mon Dec 05, 2016 11:46 am
First name: Douglas
Last Name: Ingram
City: Lorette
State: Manitoba
Now that I've finished my Lacote, I am going full blast on home renovations. Ripping out the 40 year old carpet, repairing subfloor, adding more insulation to the interior of the exterior walls, new drywall, taping, paint, new cork floor. Repeat room by room.
Oh, my poor knees.
http://redrivercanoe.ca/
PostPosted: Mon Dec 05, 2016 12:18 pm
First name: Joey
Last Name: Holliday
City: Palmetto
Zip/Postal Code: 34221
Rainbow Padauk and ebony rosette assembly. Installing tonight
PostPosted: Mon Dec 05, 2016 12:59 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
Man I love these threads. I never participate but what the hell.
I'm working on my challenge parlor (my take on a size 1ish) in Cherry and pine. Before I started that, I was working on my first ever O-ish guitar in walnut and WRC. Soon I'll get the parlor to the same stage as the O and finish them up side by side. I've never done two at a time so we'll see if I like that.
Bryan Bear PMoMC
These users thanked the author Bryan Bear for the post: bcombs510 (Mon Dec 05, 2016 2:18 pm)
Users browsing this forum: JimWomack and 36 guests
