It is currently Fri Jul 25, 2025 4:50 am
 Post subject: Martin D28 Rosette
PostPosted: Mon Nov 21, 2016 7:19 am
First name: Curtis
Last Name: Woodall
City: Houston
Zip/Postal Code: 77065
I must have missed it. I'm looking for the dimensions for a pre-war D28 rosette. The 5-9-5 purfling pattern. I'm pretty sure John Hall (BluesCreekGuitars) has the black/white material. I'mjust looking for what the period-correct dimensions are for each layer/width....hole diameter.....etc
thanks
curtis
"I need to hurry up, the years are going by far too fast"
 Post subject: Re: Martin D28 Rosette
PostPosted: Mon Nov 21, 2016 11:42 am
City: Quakertown
State: Pa
John should be able to provide you will all of the information as well. Reach out to him.
PostPosted: Mon Nov 21, 2016 5:35 pm
State: Tennessee
thanks
curtis
I'm sure I lifted this from the UMGF and other sources:
From your sound hole come in .100 to the "inside of the inner ring "5" BWBWB. The outside of the inner ring to the inside of the middle "9" .100 BWBWBWBWB. The outside of the middle ring to the inside of the outer ""5" BWBWBWB .0115 actual material thickness are all over the place.
This is my latest I like the "grained ivoroid" but maple looks great and is more traditional
PostPosted: Mon Nov 21, 2016 6:05 pm
Martin didn't use bias ivroid
there are a few different rosettes but if your looking for the old style pre war
b/w/b/w/b inner and outer rings are .015 .015. .020 .015 .015
middle ring
was b/w/b/w/b/w/b/w/b
.015 /.015 /.020/ .040 /.015./040/.020/.015/.015
They used maple and ivory then they used the celluloid for the heavy white changing to all white celluloid but the 45 used maple later than the 28's . Martin started to phase out maple starting in 1933
as the change occured the rosettes on the 28 and 45 got a bit wider. The 18 series didn't change all that much other than the inner and outer ring got wider . I have seen 18 rosettes with rosewood center rings , and black wood fiber.
PostPosted: Mon Nov 21, 2016 6:57 pm
State: Tennessee
[quote="bluescreek"]Martin didn't use bias ivroid
middle ring
as the change occured the rosettes on the 28 and 45 got a bit wider. The 18 series didn't change all that much other than the inner and outer ring got wider . I have seen 18 rosettes with rosewood center rings , and black wood fiber.[/quote]
Well I believe I bought my bias ivoroid from you for rosettes :mrgreen:
Anyway after looking at quite a few guitars and hundreds of pics it seems they used whatever they happened to have on hand, here are some pics for reference. John Hall sent me some good information and John Arnold has been very helpful. Getting the proportions right is the key.
PostPosted: Mon Nov 21, 2016 7:24 pm
First name: Curtis
Last Name: Woodall
City: Houston
Thanks guys! I believe I have enough info from ya'll to nail down my plan of attack. I like those pics, especially the last one.
PostPosted: Fri Nov 25, 2016 8:03 am
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
While we - like Mr. Hall suggested - have not seen the use of end-grain ivoroid on Martin rosettes, we have inspected or worked on a number of 1940's and 1950's Martins with end-grain ivoroid purflings. The photo below shows an early 1942 D-18 with end grain ivoroid purfing line (Martin verifies it as being from the same batch as Elvis Presley's 1942 D-18) . We've also seen several 1952 and 1953 models with the same treatment, so it would seem to give some support to Collings and others (including our shop) that prefers the additional interest in the rosette and purfing lines that end grain provides.
Is the correct term end-grain or bias-cut? In sewing, bias-cut means that the fabric is cut at a 45 degree angle across the mid-line to get a better drape. Is end-grain ivoroid indeed cut on the diagonal, instead of square-cut?
Also worth noting, the difference in width between the spacing from the center-to-inner and center-to -outer rings. We see some variations between vintage and modern rosettes, but the difference (greater spacing on outer ring) is always there.
The second shot has nothing to do with rosettes, but reflects how thankful I am for the luthiers in my shop and here online...this was waiting for me Wednesday AM in my shop storage cubby, along with a nice note offering Happy Thanksgiving wishes. Thanks, fellas...it was tasty!
- Beth Brower
PostPosted: Fri Nov 25, 2016 9:29 am
City: Tyler
Hey guys, where do you get the bias cut ivoroid purfling?
Glen
PostPosted: Fri Nov 25, 2016 9:56 am
First name: Curtis
Last Name: Woodall
City: Houston
Makes me wonder what the"G" in "Woody G" stands for. Very tasteful. I MEANT THE ROSETTE PHOTO!
Thanks.
PostPosted: Fri Nov 25, 2016 10:10 am
Glen
Last batch I got was from Axiom
PostPosted: Fri Nov 25, 2016 11:35 am
City: Tyler
Thanks Steve, I'll check them out.
PostPosted: Fri Nov 25, 2016 12:12 pm
First name: Willard
Last Name: Guthrie
City: Cumberland
Mr. Hall sells .060" material through his Blues Creek store as well.
Would that I were affiliated with Glenfiddich, Glendronach, Gengoyne, or even Glenlivet...some of us have multiple sugar daddies, but I'd settle for a single malt daddy.
- Beth Brower
PostPosted: Fri Nov 25, 2016 1:07 pm
Glen, keep in mind that most places charge a hazmat fee for shipping ivoroid, about $27 if I recall correctly. On the last buy I went in with a fellow OLF'er to share fees and bought enough for several years.
