It is currently Tue Jul 29, 2025 3:16 pm
PostPosted: Mon Nov 28, 2016 12:43 pm
Hi
Has anybody know anything about the fox/delta 16/32 drum sander.
Just got one 2nd hand, but struggling to get the drum alignment right. It's sanding heavier towards the free end of the drum
I downloaded an instruction book online but it shows a slightly different one with a adjustment knob on the table. There is nothing like this on mine and nothing obvious on the roller.
There are 4 bolts holding the belt table down to the unit which I suppose I could shim if I had to but doesn't seem right
Here's hoping someone knows
Many thanks
PostPosted: Mon Nov 28, 2016 2:07 pm
Last Name: shelton
City: Alsea
State: Oregon
Zip/Postal Code: 97324
cablepuller1 wrote:
Hi
Adjust it until it cranks up and down smoothly then make a sanding sled. You'll never get that sander properly aligned.
PostPosted: Mon Nov 28, 2016 10:56 pm
Can you take a picture from the feed end looking at the motor? There should be some sort of adjustor for the drum head.
This the adjustor on a typical Jet/Performex sander.
PostPosted: Mon Nov 28, 2016 11:05 pm
There's a way to dial it using the four screw post that raise and lower the platen. I forget how exactly how but it's there. Basically you release the post from being slaved together and then adjust them. I did mine probably 15 years ago or so. It's accurate and it holds.
These users thanked the author Jim Watts for the post: askins (Tue Nov 29, 2016 9:57 am)
PostPosted: Tue Nov 29, 2016 1:34 am
Hi Rod . Yes the picture you have there is the one in the instructions but unfortunately mine does not have this adjustor and the drive unit is different
PostPosted: Tue Nov 29, 2016 1:39 am
Thanks Jim
Can you remember where these screws are, do you mean the 4 bolts that hold the whole conveyor table to the main frame or is it to do with the drum it's self.
The drum arm is held in a slider by 6 nuts.is it something to do with them
PostPosted: Tue Nov 29, 2016 10:09 am
First name: Alain
Last Name: Lambert
City: Trois-Rivieres
State: Quebec
These sanders all look alike, but here is a manual for one that look like yours.
http://steelcitytoolworks.com/media/wys ... lowres.pdf
These users thanked the author Alain Lambert for the post: cablepuller1 (Tue Nov 29, 2016 10:53 am)
PostPosted: Tue Nov 29, 2016 10:59 am
Alain
Thank you, it seems to be the one I need cheers
PostPosted: Tue Nov 29, 2016 9:27 pm
First name: Alain
Last Name: Lambert
State: Quebec
Let us know how it turns out
