It is currently Tue Jul 22, 2025 7:48 pm
PostPosted: Thu Feb 23, 2017 5:13 pm
Last Name: Waszazak
City: Vancouver
State: Wasington
Zip/Postal Code: 98665
CharlieT wrote:
Regarding pore fill, I think Vijay was OK with using epoxy as long as it is sanded back to bare wood and a few coats of shellac are applied before applying the Royal-Lac post cat. I would think that should take care of the shrink back issues.
I would have thought so too, but that wasn't my experience. I still had visible pores after doing this. This post-cat formulation shrinks back more than the original.
I contacted Vijay about this. Here is his reply.
Quote:
It is a very common misconception people have with regards to shrinkage. Let’s look at it very simply; After a layer of any type of solvent based finish is applied on a substrate, the process of solvent evaporation begins. This process continues till all solvent is removed from the film. Yes, the majority of the solvent evaporates with the first few days and weeks but residual amounts remain and works its way up over a long period of time. Even shellac flakes that you buy have actually small traces of alcohol in them. They will weigh ever so slightly less after a year or more! Anyways, as the majority of the solvent evaporates, the solids molecules start to get closer to each other thus resulting in shrinkage. Therefore, all finishes will shrink based on the amount of solids it contains. But there is another parameter that is usually not taken into account; density of the solids. Synthetically engineered finishes have high density and hence tend to shrink less when compared to shellac. So if you have a finish that has 40% solids and compare it to Royal-Lac, which is also 40%, it is still not an apple to apple comparison because the density of a shellac based finish will be lower.
Solution: Two ways. Either the pore filling is done using a no shrinking material, which is not possible given the laws of physics as explained above. Or apply extra layers of finish to compensate for the shrinkage.
Pore filling: Epoxy is fine as long as it is sanded back to wood and a layer of Seal-Lac or shellac is present and acting as a barrier between the epoxy, which is alkaline and Royal-Lac which is acidic. As a matter of fact most solvent based finishes are usually acidic. Care has to be taken that there are no sand through spots. Here, wait for the shellac to dry for at least three weeks before level sanding with 600 grit and finally applying coats to fill the scratch marks of the sand paper. Let dry for a week. No sanding after this.
Extra layering: Apply extra layers of the finish and compensate for shrinkage over time. A bit of experimentation is required to know how much extra to put on. Final level sanding and buffing also reduces the overall thickness.
As I read his response, I was surprised to hear the recommendation for 3+1 week for the barrier coat. So, I replied back to get clarification. Here is his response.
Quote:
The type of pore fill does not matter. You will have to decide on what works best for you and your process. Two factors to keep in mind are:
1) Pore fill must be sanded back to wood.
2) A layer of Seal-Lac or shellac acting as a barrier coat without sand through is essential.
I had suggested that the barrier coat be allowed to dry for at least 3 weeks since most of the solvent will evaporate during that period of time. The time could be less too if the ambient temp is higher. The 3 weeks is a ball park number to start with. A barrier coat is simply as the name implies. It need not be pristine looking because the finish coats are going to sit on top anyways and the top most coat will be leveled and buffed in the end. Therefore only a very light sanding is required just so to get a level surface.
The number of extra coats is determined with experimentation. The most ideal condition is over a period of six months.
One of the attractions of Royal Lac Post Cat for me was an abbreviated spray schedule. But, if I were to follow Vijay's recommendations, the finishing phase would be very long. At this point, I'm not sure if it's worth investing more of my time in testing the product. I'll have to think this over a bit.
These users thanked the author MikeWaz for the post (total 2): Joe Beaver (Thu Feb 23, 2017 10:04 pm) • Pmaj7 (Thu Feb 23, 2017 5:31 pm)
PostPosted: Fri Feb 24, 2017 4:22 pm
Last Name: Beaver
City: Lake Forest
I hear what you are saying. I also think the finish has real promise if we can work through the 'pore fill, sand to wood, seal and wait 3 weeks', part of it.
With that in mind I just ordered some product for testing.
I'm thinking I'll try varied wait times after the Seal Lac, and various pore fill options.
The pore fill options I'll try are:
1. Fill with Seal Lac (should be ok on small grained wood like Maple and Macassar Ebony), wait 7 & 25 days before going to the RL PC
2. Fill with Seal Lac with some silica mixed in, (might not work but until you try, who knows?) wait 7 & 25 days before going to the RL PC
3. Fill with Medium CA, wait 7 days and then Seal Lac, waiting 7 & 25 days before going to the RL PC
4. Fill with System 3 SB112, wait 7 days and then Seal Lac, waiting 7 & 25 days before going to the RL PC
I figure I'll have to wait at least 6 months before I know how I fared, but with 3 builds this year I should be able to keep busy.
Joe Beaver
Maker of Sawdust
PostPosted: Fri Feb 24, 2017 6:54 pm
That would be a very impressive and very helpful test, Joe.
I understand that you'd be waiting that long for the sealer to cure. From a practicality standpoint, it's hard to imagine waiting nearly a month just for sealer to cure. That would take the finish process out to nearly two months, right? Or does this new version cure faster? My understanding was that Seal-Lac was just a thicker cut of Royal-Lac, so it seems like it's reasonable to seal with the catalyzed Royal-Lac, yeah? Just thinking out loud.
PostPosted: Fri Feb 24, 2017 7:14 pm
First name: Trevor
Last Name: Gore
City: Sydney
Just reading this thread puts the shivers up me.
Wouldn't it be nice if manufacturers did their own product development and testing rather than relying on their customers to do it for them at their own (vast) expense?
http://www.goreguitars.com.au
These users thanked the author Trevor Gore for the post (total 4): Clinchriver (Sat Feb 25, 2017 6:03 am) • MikeWaz (Sat Feb 25, 2017 1:33 am) • CharlieT (Sat Feb 25, 2017 12:09 am) • david farmer (Fri Feb 24, 2017 10:34 pm)
PostPosted: Fri Feb 24, 2017 8:50 pm
Last Name: Beaver
City: Lake Forest
James,
Actually, 3 weeks+ for a sealer to dry sounds insane, but.... My plan is to seal the whole board then divide each into halves. Then I'll wait about a week, then coat the 1st half with RL PC, then do the 2nd half after 25 days or so (depending on drying conditions). It might be an idea to do thirds, the 1st at 3 days, 2nd at 7 days and the last at 25 days. Might be smarter.
Trevor,
It would be very nice, but I think it is a small operation. Apparently the owner has been working with two luthiers. Word is they like it and are going to do a write up in GAL. It might answer a lot of questions.
I'm the wrong guy to be doing testing on shellac. I've never used the stuff. When I saw the threads on the new Post Cat stuff I thought of you. I think you have said you have your own method for making shellac harder, etc. I wonder what you think about the new post cat product?
Joe Beaver
Maker of Sawdust
PostPosted: Sat Feb 25, 2017 12:14 am
First name: Trevor
Last Name: Gore
City: Sydney
Not my method for making it harder, but I use Shines hard shellac, which, I think, is only available in Aus. I don't know what the additives are. Before I used it on a guitar, I used it on a kitchen work surface and left it for about 7 years (!) before I felt confident enough to use it on a customer guitar. The application method counts as part of the process, too. There is no way I would spray the stuff on a guitar without a similar test period.
The mob that supplies the nitro I use (I've used it for about 20 years) have changed the formulation about 4 times, all under the same product code, all without telling their customers. Mainly changes to flow additives and plasticisers. The spray characteristics would change significantly from batch to batch, which seriously caught out some users (lacquer cracks when sprayed on thick, bubbles forming in the film etc.), but I was lucky and got away with it, mainly because I spray lighter coats. Many of the finish manufactures have no idea of the catastrophic consequences that can result from messing with "trusted" products and, of course, accept no responsibility for consequential losses.
I've never used the Royal Lac post cat stuff and having read the comments above, I doubt I ever will.
Users browsing this forum: guitarjtb and 21 guests
