It is currently Sat Sep 20, 2025 2:27 am
 Post subject: Heat Blankets...
PostPosted: Tue Feb 28, 2017 8:39 pm
Where y'all getting yours?
 Post subject: Re: Heat Blankets...
PostPosted: Tue Feb 28, 2017 8:50 pm
City: Lawrence
Zip/Postal Code: 66047
I got mine from John Hall
http://www.bluescreekguitars.com/
He's a good guy and contributes a lot here.
PostPosted: Tue Feb 28, 2017 9:09 pm
First name: Daniel
Last Name: Petrzelka
State: Washington
I ordered directly from Omega http://www.omega.com/, and add my own connectors.
Going with a trusted luthier supplier ensures you get the correct wattage and generally come with the connectors in place, but Omega offers many options including adhesive backed, depending on what use you have intended.
PostPosted: Tue Feb 28, 2017 9:34 pm
First name: Fred
City: Winnipeg
China by way of Ebay. A little wider than I wanted but otherwise it is fine.
PostPosted: Tue Feb 28, 2017 9:38 pm
First name: David
Last Name: Ingalls
City: Ashland
State: OR
Zip/Postal Code: 97520
I have one from McMaster-Carr that is several years old and a bit tatty but still working. i recently got a new one from Keenovo on eBay and am very impressed so far. It has a built-in thermocouple and a controller that keeps the temperature within about 10 degrees across the surface, according to a Fluke IR thermometer.
PostPosted: Tue Feb 28, 2017 9:46 pm
Thanks!
PostPosted: Tue Feb 28, 2017 9:55 pm
+1 for Keenovo with programmable controls.
Brent
PostPosted: Tue Feb 28, 2017 10:08 pm
Last Name: Beaver
City: Lake Forest
I have 3, all from LMI
Joe Beaver
Maker of Sawdust
PostPosted: Thu Mar 02, 2017 10:49 pm
I also ordered directly from Omega and just attached a standard plug. Seems to be doing well so far (25+ sets over 10 years or so).
Kent
PostPosted: Fri Mar 03, 2017 9:01 am
I have one from John Hall. Had it a few years. works perfectly.
Under Compensated Nut!
PostPosted: Fri Mar 03, 2017 9:08 am
36x6" from John Hall, + FB, FB extention, uke sides and bridge blankets from Keenovo.
Assembled my own PID temp controller.
PostPosted: Fri Mar 03, 2017 9:50 am
How do those compare? My first was a Pro Therm from Blues Creek and has always worked great (10 years very light use). I recently grabbed a used Bench Mark from LMI and it is much thinner and much more supple. .075 vs .055. Both are around 1k w, work the same as far as I can tell but the lmi seems more refined.
I think mine was around $80 back then. The way the prices seem to have doubled, I would be tempted to get the Chinese one.
PostPosted: Fri Mar 03, 2017 10:46 am
We have several different sizes all from Omega - years of use very pleased
Ken Cierp
PostPosted: Fri Mar 03, 2017 3:50 pm
First name: Rob
Last Name: Lak
State: Massachusetts
I got mine from keenovo on ebay (china) with temp control 36x6 for just north of $100. Had to add a plug end but it has a temp sensor built in. My largest concern was shipping time but they sent it out next day and I had it within the week. Very happy with that.
PostPosted: Fri Mar 03, 2017 3:54 pm
Like the temp control idea...
PostPosted: Fri Mar 03, 2017 4:16 pm
First name: David
Last Name: Ingalls
City: Ashland
State: OR
The Keenovo controller is a little box with an LED temperature readout and a few buttons for on/off, temp control and programming of various parameters. It was easy to learn the keystrokes. In practice, all the functions quickly became second nature.
The blanket is thicker than the one from McMaster-Carr but this makes no difference to me since it goes on top of the wood.
PostPosted: Fri Mar 03, 2017 4:32 pm
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
Just a suggestion to think about regular inspection of your blanket(s), however shiny and new. Copper-filled high temperature RTV (the same stuff used on automotive intake and turbo systems) will repair bubbled or burned-through elements, as well as abrasion damage to thinner blankets used without a top slat. Our blankets from Mr. Hall are still doing fine at 12 years of age and a couple hundred cycles of side and bind/purfling use, but they still get inspected prior to every use, along with the timer and temp control, cords, and plugs.
- Beth Brower
PostPosted: Fri Mar 03, 2017 6:33 pm
Our second one is wearing out after a few hundred uses. So be it...
PostPosted: Sat May 12, 2018 8:45 am
https://www.youtube.com/watch?v=g8huXkSaL7o
PostPosted: Sat May 12, 2018 2:24 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
I think someone needs to be shown the door, and the business end of a cowboy boot.
Alex
Users browsing this forum: DennisK and 18 guests
