It is currently Mon Jul 28, 2025 12:04 am
Post new topic Reply to topic  [ 69 posts ]  Go to page Previous  1, 2, 3
PostPosted: Thu Apr 27, 2017 6:16 pm
First name: Daniel
Last Name: Petrzelka
State: Washington
SnowManSnow - yes, if you want the 1.3-1.5 degrees that Ken speaks of, then you will need to machine that into your neck - sanding, routing, paring or otherwise, as the StewMac necks still come at 90 degrees (I believe)
Page two of the KMG neck set instructions give you one straightforward approach to adding the matching angle to your upper bout once you've adjusted the cheeks on your neck.
http://kennethmichaelguitars.com/NECKSET.html
I'm working on refining the upper bout geometry on two guitars right now - aiming for 3/32", but allow for some slight variation. I always adjust the neck/upper bout angles prior to top routing/binding, or glueing on the fretboards. This allows me to make any final adjustments (so far every one has needed a little upper bout adjustment) smooth any transition to the waist, and then cut my top binding channels for cleaner / even binding depth.
SnowManSnow wrote:
Oh. The rims were cut using the appropriate template and then sanded via radius disks before the box was assembled
PostPosted: Thu Apr 27, 2017 7:44 pm
I need to go back and make absolutely sure that as I flattened the area of the upper bout I didn't impose a forward leaning angle into the rims
PostPosted: Thu Apr 27, 2017 9:28 pm
My confusion is because of the following.
The angle of the neck isn't 90d g to the fretboard, so it is leaning back as it should. I cut relief as prescribed in the instructions and the cheeks sit down just right all around.
But... when I put down a strait edge it contacts the soundboard right around the rosette area. Until then there is adequate clearance. So... I'm not sure where to go with it since I can't move forward in the instructions.. at the index card step.
HOWEVER...
If the neck was leaning forward... then there would be NO gap at the soundboard, as the fingerboard base and the soundboard is level....
scratching my bald head.
PostPosted: Fri Apr 28, 2017 6:50 am
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
You may directly measure the clearance of the neck plane from top of the guitar at the saddle area, so there is no need to complete and fret the board before establishing the neck angle, although you may wish to have a pretty good idea of the finished thickness of the board and what frets you plan to install. Further, you may fret with fretboard off the neck, on the neck but off the body, or after assembling the guitar as is usually done in this shop for acoustics - there are advantages and disadvantages to each approach, but all work for their practitioners.
The key bit of information needed here to determine if the neck angle is at or close to correct is the clearance between the neck plane and the top at the saddle location. This allows the neck angle to be set, at which point the extension fit to the body may be refined and any gap addressed.
What is the rationale for flattening the tenon/cheek area of the body? If you could point to the source of that guidance, I'd be interested in understanding the pros and cons of the approach.
I will relay, Dr. Kennedy - the degree of regard in which he holds you may be deduced from the labeling on our set of templates and fixtures for profiling tapered heels. The box holding the heel templates is labeled:
Ole Doc Kennedy's Patent Wizard Elixir & Tapered Heel Profiling Templates:
(Treats Gout, the Flux, and Ugly Guitar Necks...apply liberally!)
- Beth Brower
These users thanked the author Woodie G for the post: Terence Kennedy (Fri Apr 28, 2017 7:28 am)
PostPosted: Fri Apr 28, 2017 12:45 pm
First name: Tony
Last Name: Thatcher
City: Bozeman
State: MT
For that, I'd just floss the under side of the fretboard extension so it has a little taper to the sound hole. That way you are not thinning out the top plate, especially as you get closer to the sound hole. I made that mistake once and actually sanded through my rosette!
That is assuming that you have the correct clearance at the saddle. If your geometry is correct, and the neck angle is giving you the correct clearance at the saddle, then don't change it. Just taper the under side of the fretboard extension. There is no problem with that. You are just adapting to the radius of the top in the upper bout.
Tony Thatcher
Bozeman, Montana
PostPosted: Sat Apr 29, 2017 5:19 pm
First name: Murray
Last Name: MacLeod
City: Edinburgh
Country: UK
Basic geometry.
If the neck heel has a Martin style V profile, flattening the area where the heel shoulders contact the body makes life simpler.... it means that you are then mating two plane surfaces together.
If the heel has a parallel profile, flattening is not of any benefit.
PostPosted: Sat Apr 29, 2017 6:18 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
ZekeM wrote:
Well I think that all depends on your fretboard and bridge thickness. But I shoot for the strings to be around 1/2" over the top at the saddle. You can plug in the other numbers and calculate what you need from that.
Wow, I've never achieved that. I always aim for slot depth times 2 Not sure if I ever achieved that either). In the end, its how well it plays and sounds. I normally lay a straight edge along fretted board and hope for around 3/32' to 1/8' above front edge of bridge. I'm working one now that scares me.
PostPosted: Sun Apr 30, 2017 7:00 am
First name: Willard
Last Name: Guthrie
City: Cumberland
This is a fascinating conversation! It appears to me that there are several schools of thought on neck setting, to include:
- Those that control body shape (really, top contour) and neck angle throughout the building process to hit a target string height at the saddle
- Those that adjust body shape and bridge thickness after construction to hit a target string height at the saddle
- Those that are aiming for a different target entirely (e.g., a set saddle height) and accept a range of different string heights at the saddle location, provided a bridge of minimum thickness with adequate saddle depth can be accommodated.
Two of the three approaches focus on a set geometry at the saddle, while the third is a different goal entirely. For those following the third school, such as Mr. O'Melia, what is the range of acceptable string heights, bridge thicknesses, and saddle projections for your guitars? Martin seems to adhere to the third school, with at least four different bridge thicknesses I've seen, saddle heights from just 0.090" to 0.180", and final string heights at the saddle of about 0.42" to about 0.58" (thanks, Mr. Parker!)...that seems like a huge range of possible results in exchange for simplifying the construction process, but their customers seem satisfied with the results.
Mr. McLeod - exactly! For a butt-jointed neck without fretboard installed, adjustments to back and side angle could be done on an abrasive-covered surface plate, versus the tedium of neck joint flossing. But how would one avoid thinning the binding under the heel cap, or disguise the loss of 0.015"-0.020" of binding thickness so as not to be noticeable?
- Beth Brower
PostPosted: Sun Apr 30, 2017 7:35 am
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
" and final string heights at the saddle of about 4.2" to about 5.8""
I think your decimal point should go a digit to the left, Woody. Not trying to be persnickety, but some folks could get confused by the numbers and wind up with a harp instead of a guitar.
These users thanked the author doncaparker for the post: Woodie G (Sun Apr 30, 2017 8:05 am)
There's many thoughtful responses.
This reminds me of the cold and flu isle at the pharmacy. There's as many remedies as possible to fill it top to bottom. And some might even have more than a placebo effect, but I doubt it.
It is all in fun so don't het me wrong.
When I made my first acoustic guitar years ago I followed a mixture of ideas which led me far astray when it came to meeting the neck to the body and having the proper projection. Problem was a good thing because it forced me to plan better from the beginning.
I now use the classical guitar method of building on a plantilla. Even with steel string guitar's. This way I can have different shapes for the body and still have the correct string height in the end.
Obviously from viewing many fine guitars built using radius dish method for the body, it can be worked out. But I think it takes more than one guitar to get right. There are too many variables with the bracing in the upper bound in conjunction with any angle that put on the rim.
So anyway that's just something to think about if anyone reads this, doing the research before building it's a good idea to build with the top down on a workboard or plantilla.
Ken
PostPosted: Sun Apr 30, 2017 9:42 am
This is a valid concern and one reason that we stress the importance of following the assembly sequence when using the KMG assembly manual construction process. However, when using the parts supplied with our KMG kits the flatting of the area in question is merely a clean up to remove glue squeeze out.
Ken Cierp
These users thanked the author kencierp for the post: dpetrzelka (Mon May 01, 2017 9:34 am)
PostPosted: Sun Apr 30, 2017 1:07 pm
First name: Murray
Last Name: MacLeod
City: Edinburgh
Country: UK
Woodie, I was thinking more of a very localized flattening, with a tapered custom made sanding block, which would flatten an area of maximum 2.5 " at the soundboard, tapering to like 1.25" at the back. This would be advantageous no matter what the type of neck joint employed ...butt, dovetail, bolt on, whatever (always assuming that the neck heel is a V-profile, of course}
This flattening to be done before the binding channels were routed. Any subsequent adjustment to be done on the shoulders of the neck heel ...just as if you were doing a neck reset.
I envisage that if you were building a parlor guitar with a very tight and pronounced radius to the upper bout, you would be more or less forced to do this (assuming you were using a V profiled heel, of course).
PostPosted: Sun Apr 30, 2017 1:13 pm
First name: Murray
Last Name: MacLeod
City: Edinburgh
Country: UK
Ken, are we talking about the same thing ?
I was referring to the area where the neck heel mates up to the body. I am not familiar with your KMG kits, but I cannot visualize why there should be any glue squeeze-out in this area, irrespective of what method of neck attachment is employed?
PostPosted: Sun Apr 30, 2017 2:41 pm
Yes we are --- side/rim butt joint on the neck block
Ken Cierp
PostPosted: Sun Apr 30, 2017 4:57 pm
State: Tennessee
When you glue the sides to the neck block you can have some glue squeeze out, pre-dovetail/tenon route
You can beat this to death, its time to make some shavings
PostPosted: Sun Apr 30, 2017 5:59 pm
First name: Murray
Last Name: MacLeod
City: Edinburgh
Country: UK
well yes ... I thought the thread was about neck angles ...with basic glue ups already taken care of ..
PostPosted: Sun Apr 30, 2017 6:03 pm
It's important to get it right but it's also real easy to way over think it.
PostPosted: Sun Apr 30, 2017 7:54 pm
Overthinking is very popular on this board.
I just eliminated the problems completely by making the top cylindrical. The top is basically flat from dovetail to end block. I look for a 1/16" gap in the straightedge above the top at the bridge. Done...
These users thanked the author Haans for the post (total 2): Jonny (Mon May 01, 2017 10:53 am) • Ken McKay (Sun Apr 30, 2017 9:34 pm)
PostPosted: Sun Apr 30, 2017 8:47 pm
I also think not reading " all " the posts in a thread before comments are made or questions asked can lead to misunderstanding intent of some of the posted comments. But no harm no foul its a forum.
Ken Cierp
Users browsing this forum: Bing [Bot], meddlingfool and 11 guests
