It is currently Fri Jun 12, 2026 10:36 pm
PostPosted: Wed Aug 09, 2017 1:38 pm
First name: James
State: Maine
Building my first baritone. Because of the wound 3rd string of a baritone does this mean that non adjustable wraparounds like this would not work http://www.abm-guitarpartsshop.com/Wrap ... ::190.html ?
Anything else that may change when laying out scale length, compensation and bridge type to keep in mind when making a baritone?
PostPosted: Wed Aug 09, 2017 2:45 pm
Yep, the wound 3rd is going to be a goodly amount off in intonation with that tail piece/bridge. Instead it will need to be similar to if not forward of the wound 4th.
PostPosted: Wed Aug 09, 2017 4:43 pm
First name: Freeman
Last Name: Keller
http://www.liutaiomottola.com/formulae/ ... ocId800114
PostPosted: Wed Aug 09, 2017 9:40 pm
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
Zip/Postal Code: J2M 1R5
You're right, standard compensation "rules" don't work on baritones. I developed a spreadsheet to make the calculations for any steel string instrument, including multi-scale. See http://www.mullinguitars.com/2015/10/compensation-calculator-for-steel-string-guitars.html
