It is currently Sun Sep 14, 2025 11:00 am
PostPosted: Fri Sep 01, 2017 5:50 pm
First name: D
Last Name: S
Finished my V build.
Maple, Padauk, and Ebony.
I went with the Schaller 3D bridge which allows varying the string spread.
The neck width at the bridge is wider than normal. Fits my fingers well.
Both fins are hollow, total weight is 6 pounds.
Grover tuners, Emg 81 pickup.
25.3" scale, 14" radius.
I made a mistake putting the jack on the inside of the lower fin: I'll need to get a right angle jack to play it sitting down.
Finish is wiped-on poly, no grain fill.
Dan
wah
Wah-wah-wah-wah
Wah
PostPosted: Fri Sep 01, 2017 6:09 pm
Beautifully done.
Sent from my SM-G955F using Tapatalk
These users thanked the author GourmetSaint for the post: dzsmith (Fri Sep 01, 2017 6:44 pm)
PostPosted: Fri Sep 01, 2017 11:26 pm
Looks very nice. Good choice on the bridge, too.
These users thanked the author Chris Pile for the post: dzsmith (Sat Sep 02, 2017 9:24 am)
PostPosted: Sat Sep 02, 2017 12:07 am
Very nice!!
These users thanked the author Hesh for the post: dzsmith (Sat Sep 02, 2017 9:24 am)
PostPosted: Sat Sep 02, 2017 10:53 am
That looks fun.
Nice job!
These users thanked the author Jim Watts for the post: dzsmith (Sat Sep 02, 2017 5:00 pm)
PostPosted: Sun Sep 03, 2017 7:10 am
State: Tennessee
Very balanced, nicely composed.
These users thanked the author Clinchriver for the post: dzsmith (Sun Sep 03, 2017 10:57 am)
PostPosted: Sun Sep 03, 2017 8:48 am
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
Nice one, Dan! The finish looks really nice without the grain fill!
Alex
These users thanked the author Alex Kleon for the post: dzsmith (Sun Sep 03, 2017 10:57 am)
PostPosted: Mon Sep 04, 2017 7:23 pm
Last Name: Lewis
City: Newnan
State: Georgia
Zip/Postal Code: 30265
Sweet!!!
John Lewis
These users thanked the author John Lewis for the post: dzsmith (Mon Sep 04, 2017 9:30 pm)
PostPosted: Mon Sep 04, 2017 7:54 pm
First name: Aaron
Last Name: Hix
City: Chatsworth
State: Georgia
Zip/Postal Code: 30705
Awesome work, Dan!! Looks great!
Guitar Maker and Purveyor of the World's Finest Tonewoods
http://www.aaronhixguitars.com/
http://stores.ebay.com/A-Hix-Tonewood-a ... r-Supplies
These users thanked the author A.Hix for the post: dzsmith (Mon Sep 04, 2017 9:30 pm)
PostPosted: Mon Sep 04, 2017 8:55 pm
Last Name: Imbler
State: KS
Zip/Postal Code: 67204
I don't know electrics, but that is -very- elegant!
These users thanked the author Imbler for the post: dzsmith (Mon Sep 04, 2017 9:30 pm)
PostPosted: Tue Sep 05, 2017 5:41 pm
it would appear as if you made the wings hollow by basically making the sides of the axe similar to ribs on an acoustic, then added in a cap and back, and viola'!
those guitars, along with the Kelly, are notorious for neck diving...e.g. by reducing the weight of the body you're most likely going to have that issue in spades...
I noticed that tendency on my '84 RR custom...eventually I figured out that if I wrapped the strap around the face of the guitar on the wing it solved the problem.
'nice' solution to the issue of having to put 2 angles on the neck blank...e.g. you left the body in the same plane as the neck and recessed the bridge to make it workable...the biggest hurdle I see to making a neck through with a TOM or floating FLoyd Rose is just how the he!! do you deal with the fretboard extension...the only real solution (I don't consider slipping a wedge underneath to be 'real') I can think of is to use an overhead router with a very short pattern bit to not only level the top but also pattern around the fretboard leaving wood underneath the extension (or something very similar to that concept if you deal with 'elevations' on the blank before you glue the wings on...
either way, nice looking axe
These users thanked the author Mike_P for the post: dzsmith (Wed Sep 06, 2017 5:00 pm)
PostPosted: Tue Sep 05, 2017 7:54 pm
State: AR
Looks great and tempting to play.
These users thanked the author Sandywood for the post: dzsmith (Wed Sep 06, 2017 5:00 pm)
cron
