It is currently Fri Jul 18, 2025 4:10 pm
PostPosted: Thu Sep 21, 2017 2:44 pm
First name: doug
Last Name: powdrell
City: hilo
State: big island
Have some small pieces to run thru drum sander......few years ago a thread on here, I think....
-slave board, CA, wax paper, CA, veneer? something like that??? thanks in advance......
PostPosted: Thu Sep 21, 2017 2:56 pm
I use hot melt glue -- thin as required -- release with alcohol, HG peels off clean
Ken Cierp
PostPosted: Thu Sep 21, 2017 3:20 pm
Last Name: McDonald
City: Okanagan Centre
State: British Columbia
Zip/Postal Code: V4V2H6
How small are you talking?
I have run pieces under 4" in length and have thinned to about .040" through my drum sander with no issues.
B
PostPosted: Thu Sep 21, 2017 3:41 pm
First name: doug
Last Name: powdrell
City: hilo
State: big island
Thanks Ken...sounds like a plan!
Bri; just don't feel comfortable with small pieces....maybe as small as heel caps....I have a 10-20 Performax that I really like, but the 'hold down' bars are kinda far apart.....
PostPosted: Thu Sep 21, 2017 4:10 pm
Backing board and 2 side tape.
These users thanked the author meddlingfool for the post: powdrell (Thu Sep 21, 2017 9:17 pm)
PostPosted: Thu Sep 21, 2017 4:24 pm
Online
First name: Brad
Last Name: Combs
I use the same setup as well.
Sending just heel cap sized material through there though... whew... don't be on the back side when that bullet comes flying out!
These users thanked the author bcombs510 for the post: powdrell (Thu Sep 21, 2017 5:39 pm)
PostPosted: Thu Sep 21, 2017 4:37 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
Same here. This works no problem for things in the size range of head plates and bridge blanks. You can go much smaller if you want. Last year I inlaid ammonite fossils into a fretboard and needed to flatten them from the back side. They were only 3/8" to 5/8" across. Double-stick taped them face down to a carrier board and it worked great.
I use Scotch removable poster tape which comes in a small plastic dispenser. It's very thin and has very good stick. I get it at Ace.
PostPosted: Thu Sep 21, 2017 4:59 pm
I just send it through, what's the issue? Are you worried about sniping? I have only seen that happen when talking to deep a cut so just go slow and easy.
PostPosted: Thu Sep 21, 2017 8:39 pm
Last Name: McDonald
Performax suggests minimum stock length of 2-1/2".
I would give it a try on some scrap.
B
PostPosted: Thu Sep 21, 2017 9:19 pm
First name: doug
Last Name: powdrell
City: hilo
State: big island
Thanks guys for the help!! I'm good to go!
PostPosted: Fri Sep 22, 2017 9:59 am
I also used double sided tape on a backer board - releases easy with naphtha. For real little stuff I put a few sacrificial strips on either side to make sure I get a clean level cut on the small parts.
These users thanked the author SteveSmith for the post: powdrell (Fri Sep 22, 2017 12:04 pm)
Users browsing this forum: kfish and 17 guests
