It is currently Mon Apr 27, 2026 8:33 pm
 Post subject: Small buffing setup
PostPosted: Sun Oct 29, 2017 3:00 pm
Last Name: Denvir
City: Baltimore
State: ON
Zip/Postal Code: K0K 1C0
I'm looking for a small buffing setup, solely for use with parts. Bridges, nuts, saddles, necks.
Can anyone suggest power requirements, wheel size, etc? Red flags I should watch for?
Thanks in advance
 Post subject: Re: Small buffing setup
PostPosted: Sun Oct 29, 2017 3:06 pm
First name: Allen
Last Name: McFarlen
City: Mt. Sheridan
State: Qld.
Zip/Postal Code: 4868
I use my drill press with a mop on a mandrel for those little things. Simple and doesn't take up any extra room.
Allen R. McFarlen
Facebook
Cairns, Australia
These users thanked the author Allen McFarlen for the post (total 2): Glenn_Aycock (Thu Nov 09, 2017 9:02 pm) • Pmaj7 (Sun Oct 29, 2017 4:43 pm)
PostPosted: Sun Oct 29, 2017 3:47 pm
Last Name: McDonald
City: Okanagan Centre
State: British Columbia
Zip/Postal Code: V4V2H6
Steve, princess auto has a small unit, with variable speeds, and work lights.
Pic is with 6" buffs
They come on sale 1/2 price every now and then. I think I paid ~$70 plus buffs.
Works great for small stuff, marginal for bigger stuff.
B
These users thanked the author Bri for the post: Alex Kleon (Sun Oct 29, 2017 5:25 pm)
PostPosted: Sun Oct 29, 2017 7:05 pm
First name: Ken
Last Name: Lewis
City: Mt. Pearl
State: NL
I too just use a couple little buffs in the drill press. (around 5 or 6 in.) Think I got them at Busy Bee.
They have a built in mandrel, so just chuck 'em and buff away. I only use them for small parts, bridges
and such. Necks get the big buff. They're cheap as well.
Ken
PostPosted: Mon Oct 30, 2017 5:46 am
State: ON
I've found I prefer micro mesh for a lot of the smaller stuff. Especially nuts, no buffing compound to clean out later.
Josh House
Canadian Luthier Supply
http://www.houseguitars.com
PostPosted: Mon Oct 30, 2017 6:55 am
Would the buffing rigs from Harbor Freight be sub par for this? I know it’s hard to beat their prices. I’ve found some things cheaply made while some thing (certain clamps) are a really great value.
PostPosted: Thu Nov 09, 2017 9:05 pm
First name: Glenn
Last Name: Aycock
City: El Lago
Zip/Postal Code: 77586
Snow,
I use them for buffing wood turnings and metal parts. I'm sure they work fine for dense hardwoods.
Glenn
PostPosted: Fri Nov 10, 2017 6:17 am
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
We have a low speed grinder from Woodcraft (essentially the same as the $99 Rikon that Woodcraft runs on sale) with two double 8" muslin sewn buffing wheels. Both get medium compound, and the left-most wheel is used for buffing bridges and metals (mostly final fret buffing), while the right is used exclusively for light-colored items such as nuts or saddles. The buffer is cantilevered off the corner of a table, so access is very good for larger items such as assembled guitars.
A note on co-locating grinders and buffers...all grinders will throw debris into the air, and those with friable grinding wheels will throw grit as well - usually large grit (we use an 80 grit 3X wheel on the right side of the grinder to handle odd-shaped tools). This debris and grit can make its way onto buffs located nearby, so we use a barrier shield behind the grinder and cover the buffing wheels with a trash bag or dedicated cover while grinding to avoid the issue.
PostPosted: Fri Nov 10, 2017 7:43 am
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
I use a yellow buff wheel from grizz
Users browsing this forum: No registered users and 421 guests
