It is currently Mon Apr 20, 2026 3:52 pm
PostPosted: Tue Nov 14, 2017 11:43 pm
First name: Conor
Last Name: Searl
City: Duncan
State: British Columbia
Zip/Postal Code: V9L 2E5
Hi, a fellow wants me to re-glue this sound hole rosette on his ovation. It's about 1/2 - 2/3 unglued. There's nothing else wrong with the guitar seems like I should be able to simply clean most of the glue off and reglue with titebond. There's nothing structural about it. Am I missing anything?
PostPosted: Wed Nov 15, 2017 12:44 am
Yeah, I suppose you could. But why?
See my comments on other Ovation threads about dropping anvils on them.
These users thanked the author Chris Pile for the post: Hesh (Wed Nov 15, 2017 1:17 am)
PostPosted: Wed Nov 15, 2017 1:24 am
First name: Conor
Last Name: Searl
City: Duncan
Haha, yup. Not my favorite.
PostPosted: Wed Nov 15, 2017 10:34 am
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
Seems like a perfect place for CA. Probably get away with no cleanup.
PostPosted: Wed Nov 15, 2017 12:11 pm
First name: Conor
Last Name: Searl
City: Duncan
Cool, I didn't think of that, my mind went straight to titebond.
PostPosted: Wed Nov 15, 2017 12:39 pm
First name: Freeman
Last Name: Keller
Another vote for thin CA. If you put some wax (paraffin or candle wax) on the top all around the rosette and wick the CA into the gap you'll stand a better chance of it not adhering to the finish. I'm always afraid of using accelerator around finish - sometimes it seems to make it cloudy - so I would just use the glue and a little light clamping
These users thanked the author Freeman for the post (total 2): Bryan Bear (Wed Nov 15, 2017 3:57 pm) • Conor_Searl (Wed Nov 15, 2017 1:21 pm)
PostPosted: Wed Nov 15, 2017 1:22 pm
First name: Conor
Last Name: Searl
City: Duncan
How do you thin CA?
Also when you say use wax around the rosette how do you suggest applying the wax?
PostPosted: Wed Nov 15, 2017 2:00 pm
Conor_Searl wrote:
How do you thin CA?
Apply wax with your fingers.
You can get CA glue in varying viscosity from suppliers like LMII and such.
PostPosted: Wed Nov 15, 2017 2:40 pm
First name: Conor
Last Name: Searl
City: Duncan
I've got this paste finishing wax, will this work? Or should I melt a candle and apply the warm wax, or just wipe around the rosette with a dry candle?
Afterwards do I just wipe the wax off, or will I have to buff it out?
Conor
PostPosted: Wed Nov 15, 2017 3:13 pm
City: Tyler
That's the stuff.
PostPosted: Wed Nov 15, 2017 3:46 pm
Conor
I wouldn't warm the wax since it'll be tough to control. You can use the paste finishing wax just fine, just wear gloves. The candle wax could work I just haven't tried it myself.
All the wax does it make any runout of glue stick to the wax and not stick to the guitar top. After you've done your glue up all you should really have to do is wipe off the wax with some guitar polish. The wax is pretty benign stuff (it won't eat through your finish) so don't overthink it too much.
PostPosted: Wed Nov 15, 2017 3:53 pm
First name: Freeman
Last Name: Keller
That will work but I keep a little piece of paraffin (or the stub of a candle) and just rub the wax on the surface next to where I'm going to do the repair. The CA won't stick to the wax, it kind of beads up and you can chip it off with your fingernail. Obviously don't get the wax into the joint you are trying to glue.
CA (cyanoacrylate) glue comes in several viscosities - thin (or water thin), medium, gel. You can get them all from various vendors including StewMac and GlueBoost (both OLF sponsors). Normally you can't find the thin stuff at a hardware store but hobby shops might have it.
I use the medium for most gluing tasks where I can get the nozzle in the joint, the thin stuff will wick its way into cracks by capillary action. You can get little pipettes to apply it - its wonderful for minor cracks that aren't opened up. I think in this case you can probably get medium under the rosette but the thin would work its way under the area that hasn't come loose yet.
When I'm done with a repair like this I usually do buff it with a fine auto polishing compound (with no wax or silicon). You can remove the wax with denatured alcohol or just polish with a rag.
PostPosted: Wed Nov 15, 2017 3:55 pm
Be careful Conor if you screw up it might sound better.....;)
PostPosted: Wed Nov 15, 2017 4:17 pm
Be hard to make it worse beehive
These users thanked the author SteveSmith for the post: Hesh (Wed Nov 15, 2017 4:30 pm)
PostPosted: Wed Nov 15, 2017 4:37 pm
Guess I don't have the guts for that. It's not mine, even if it is a POS.
I'd probably use clear double stick carpet tape and cut it after sticking. You can also buy sheets of "stickum" for pickguards. Peel off paper, stick to rosette, peel off the other side of paper and adhere. You could even throw a couple of clamps and a caul on it overnight to be sure.
PostPosted: Wed Nov 15, 2017 11:31 pm
First name: Allan
Last Name: Bacon
Oh Jeez, another Ovation bash...
PostPosted: Tue Nov 21, 2017 8:21 pm
First name: Dan
Last Name: Savage
City: Trabuco Canyon
Zip/Postal Code: 92679
Don't try to clean the glue off the underside of the rosette. The factory used epoxy to glue these to the polyester finish.
Personally, I would not use CA on the Ovation rosette as it's liable to wick between the pearloid layer and the plastic rosette and dissolve the oak-leaf pattern silk-screened to the underside of the plastic rosette.
A better bet is to use hardware store-grade 5-minute epoxy. That's what the factory used and what I use to glue rosettes onto the Os I've restored.
Hold it into place with your fingers until the glue cures. If you have any squeeze-out, clean it up with denatured alcohol before it cures.
PostPosted: Tue Nov 21, 2017 8:29 pm
First name: Joey
Last Name: Holliday
City: Palmetto
Zip/Postal Code: 34221
Conor_Searl wrote:
How do you thin CA?
If you have a Rockler or Woodcraft near you they usually carry (thin viscosity CA) as well.
PostPosted: Tue Nov 21, 2017 9:23 pm
First name: Dan
Last Name: Savage
Yep. Haters gotta hate...
PostPosted: Tue Nov 21, 2017 9:26 pm
First name: Dan
Last Name: Savage
Or, your local hobby shop sells it. Modelers were using CA long before luthiers 'discovered' it.
PostPosted: Fri Nov 24, 2017 2:19 am
First name: Frank
Last Name: Ford
City: Palo Alto
Zip/Postal Code: 94301
I usually take the rosette off and use regular contact cement to glue it back - quick and easy. Spread it on nice and thick, let it dry, squish the parts together. . .
Cheers,
Frank Ford
FRETS.COM
HomeShopTech
FRETS.NET
