It is currently Sat Sep 20, 2025 4:53 pm
PostPosted: Thu Nov 16, 2017 12:05 pm
Stainless and spring. I have only used .015" SS and wondered if thicker would give more support?
PostPosted: Thu Nov 16, 2017 12:07 pm
much depends on the temper . Many buy the shim stock that is non tempered and will bend I use the tempered stainless.
.015 is plenty for support .
These users thanked the author bluescreek for the post: Pmaj7 (Thu Nov 16, 2017 12:08 pm)
PostPosted: Thu Nov 16, 2017 1:09 pm
I've been using blue tempered shim stock at 0.010 with no problem for a long time. Wrapped in foil plus the brown wrapping paper.
These users thanked the author Terence Kennedy for the post: Pmaj7 (Thu Nov 16, 2017 2:10 pm)
PostPosted: Sun Nov 19, 2017 2:15 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I got mine from John, perfectly sized for the fox bender. If what I have is what he is selling now, they do bend some, easily reshaped, but not that true blue spring steel. I've always been a bit wary of that stuff. What I use now will pop if tape comes undone (after bending), but not bad as to worry me. I have never had a support issue with these.
PostPosted: Sun Nov 19, 2017 2:16 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
What do you use the foil for?
PostPosted: Sun Nov 19, 2017 3:16 pm
To make sure the slats don’t discolor the wood. Might not be necessary with the paper but i’ve been doing it so long I just keep doing it. I just wrap it around the slat and secure with binding tape. The same foil has been on my slats quite a while.
PostPosted: Sun Nov 19, 2017 7:01 pm
I use strips of Formica for slats. They do eventually take a "set" but they are semi disposable. I don't use paper or foil and keep the blanket to the inside of the work piece so any minor scorching that might occur is on the inside.
PostPosted: Sun Nov 19, 2017 7:19 pm
I just bought John Hall's whole setup. It works, the thermostat is reliable and just made my own bending forms.
Looking back on it all, I probably should have ordered a third slat, but it worked very well, Only problems I had were of my own making.
PostPosted: Sun May 13, 2018 7:29 am
This "Frank Barraza" bot or whatver is a bit of a pain in the proverbial @/.'*.
Users browsing this forum: Michaeldc and 43 guests
