It is currently Tue Jul 29, 2025 7:10 pm
PostPosted: Wed Jan 03, 2018 4:30 pm
First name: Gary
Last Name: Leddington
Or shellac? Or Sander Sealer? Then Lacquer?
G.
www.leddingtonguitars.com
PostPosted: Wed Jan 03, 2018 7:01 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
If you don't want to use a pore filler, Behlen has a vinyl sealer. I assume you mean Nitro Lacquer. Regardless, Nitro will adhere to all you mentioned. I just did a strat body with z poxy and Behlens Nitro. Your question sounds like this is your first attempt. I'd suggest asking a lot of questions, telling us about the wood, and specifying your goals. Also, do you live in a place where you can safely shoot nitro?
PostPosted: Wed Jan 03, 2018 8:14 pm
First name: Danny
Last Name: Vincent
Yes, but would recommend toothing the epoxy with 220 prior to nitro.
PostPosted: Wed Jan 03, 2018 8:27 pm
I put down a couple of coats of shellac between them. And be sure to wait a couple of days between steps (DAMHIK).
Ken
Ken Mitchell
Durham, NC
These users thanked the author Ken Mitchell for the post: Mike OMelia (Wed Jan 03, 2018 9:20 pm)
PostPosted: Wed Jan 03, 2018 9:20 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Ken
You put shellac over z poxy?
PostPosted: Thu Jan 04, 2018 4:10 am
First name: Gary
I'm just wondering if i need to seal the z-poxy before shooting nitro... but i have my answer i think as long as i scuff sand it should be good.
Thanks Folks.
G.
PostPosted: Thu Jan 04, 2018 9:39 am
First name: Glenn
Last Name: LaSalle
City: Saint Petersburg
Mike OMelia wrote:
Ken
I do. I like tru oil on back/sides/neck, and find shellac is a good barrier between the zpoxy and tru oil. Works great.
Glenn
PostPosted: Thu Jan 04, 2018 11:02 am
Lacquer works just fine straight over z-poxy. No need to do anything special.
Andy
PostPosted: Fri Jan 05, 2018 12:12 am
I used Cardinal over shellac over Z-Poxy on my last one as well and it worked fine. They don’t recommend it, but I didn’t want to buy a quart of sealer for one guitar. Adhesion is not quite as good as it is over their sealer, but still perfectly solid.
To clarify: Z-poxy > shellac made from kusmi button lac dissolved in Everclear > Cardinal LuthierLac
PostPosted: Fri Jan 05, 2018 1:38 am
Last Name: Beaver
City: Lake Forest
For Nitro I only use cardinal. I use their vinyl sealer followed within 30-60 minutes with nitro.
Before I started with cardinal I did a test panel. I tried it a) direct on epoxy, b) over vinyl sealer that had been drying for 12 hours and c) over vinyl sealer that had been drying less than an hour. The results were Best- spray over vinyl in less than an hour, Close 2nd- spray direct on zpoxy, and a distant 3- spray over vinyl sealer that had completely dried (at least 12 hours)
After hearing bad things from Cardinal I didn't bother to test it over shellac.
I might have gotten different results with a different product.
Joe Beaver
Maker of Sawdust
PostPosted: Fri Jan 05, 2018 3:53 am
First name: Gary
Thanks for all the great insight folks!
Glenn LaSalle wrote:
Mike OMelia wrote:
Ken
Glenn
Really? I thought oils 'thing' is that it absorbs into the wood.
PostPosted: Fri Jan 05, 2018 10:40 am
First name: Glenn
Last Name: LaSalle
I think Tru Oil is more varnish than oil... but based on numerous reports of Tru Oil having difficulty adhering directly to Z-Poxy, thats what I do. Have a few guitars 6 years old now, and no issues.
PostPosted: Fri Jan 05, 2018 8:55 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I’ve never lots over z poxy. Waterborne or nitro. Works great. I do scuff epoxy surface to increase mechanical bond. (This includes west system epoxy as well). To me, perfect surface prep is a level epoxy layer, no wood showing. Perfectly flat. I do use a special sealer for most wood, oily, before epoxy application.
PostPosted: Fri Jan 05, 2018 10:34 pm
First name: Aaron
Last Name: Craig
State: Missouri
I’ve shot Cardinal nitro directly on z-poxy on multiple guitars. Probably my preferred combo. I typically signfigantly thin the first couple coats before shooting thicker coats. May not be necessary, but it works for me.
Aaron Craig
PostPosted: Sat Jan 06, 2018 11:18 am
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Zip/Postal Code: 43085
Are you leaving a layer of Z-Poxy over the entire surface or just in the pores? I'd say if it's over the entire surface you're fine. If not, I'd use vinyl sealer or something to make the surface all the same.
I'm not a luthier.
PostPosted: Sat Jan 06, 2018 7:22 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
What Kevin said is a very good point. Myself, I leave a layer over entire body. Use a vinyl sealer on the top. Do not epoxy the top just in case there was a question about the that.
PostPosted: Sun Jan 07, 2018 5:36 pm
I shoot vinyl sealer regardless what's under my nitro top coats. It's cheap. It's fast. I'll take the security, and consistency (same old boring thing) approach with the predictability it lulls me in to.
Andy
Users browsing this forum: Ken Lewis and 25 guests
