It is currently Thu Sep 18, 2025 9:58 pm
PostPosted: Tue Apr 17, 2018 12:35 pm
Hey friends!
I am not sure if this is the right place to start this thread but here we go...
I think this may be a bit tricky because I searched online and found absolutely NOTHING about the subject!
OK, I am after some advice on how to start building SHAPED hardcases for my guitars. I know how to make rectangle cases (actually I have made some) but I find them very ugly and clumsy and now I would like to try to make shaped ones.
Any clue about which direction to go to start making my shaped cases? I would appreciate tips, material reference, etc...
Thank you!
PostPosted: Wed Apr 18, 2018 6:10 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
You need bending plywood. This what I used to by when I ran a cabinet shop, pretty sure they use similar to build cases. https://www.columbiaforestproducts.com/ ... g-plywood/
Brian
These users thanked the author B. Howard for the post: LPBR (Wed Apr 18, 2018 7:08 am)
PostPosted: Wed Apr 18, 2018 7:09 am
Thank you for the heads up! Yesterday making some research I bumped to a very nice material that I never had seen available for consumer before (in my country at least, Brasil)... flexible plywood. It turns the shaped hard shell making into a whole different story!
:D
PostPosted: Wed Apr 18, 2018 10:50 am
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
Here is a presentation by Ralph Nord on the Seattle Luthiers Group site. It has details of the materials and the process of making it. Lots of pictures.
http://seattleluthiers.org/wp-content/uploads/2017/01/Form-Fit-Guitar-Case-Construction.pdf
These users thanked the author johnparchem for the post: LPBR (Wed Apr 18, 2018 11:46 am)
PostPosted: Wed Apr 18, 2018 11:48 am
Wohay! Thank you John, I will take a thorough look on this documentation! This is no doubt one of the more valuable publication I have had the chance to put my hands on!
[:Y:]
PostPosted: Wed Apr 18, 2018 12:20 pm
Last Name: Reed
City: Stowmarket
State: Suffolk
Zip/Postal Code: IP14 2EX
Country: UK
Or you can bend ordinary plywood on a hot pipe - I've made a few cases that way. But nothing thicker than about 3mm/0.125 inches. Plywood can be a little tricky to bend, as a void or weak spot bends differently from the rest, but it's not too hard to do. Worth an experiment if you have a few scraps of thin enough ply and a hot pipe.
PostPosted: Wed Apr 18, 2018 5:33 pm
http://fraulini.blogspot.com/2016_03_01_archive.html
