It is currently Fri Jul 25, 2025 9:56 am
PostPosted: Sun May 13, 2018 12:48 pm
First name: David
City: Napa
Zip/Postal Code: 94558
So I'm getting close to finishing a couple of maple top guitars. Both of these dye manufactories recommend alcohol as a dye mix, I'm curious as to what kind of alcohol? Denatured or ever clear or some other product?
PostPosted: Sun May 13, 2018 1:56 pm
City: Escondido
Zip/Postal Code: 92029
Trans-tint can work with almost any carrier. Alcohol, shellac, lacquer, even water. I usually use a very thin shellac or straight alcohol. Denatured, as you can’t get real everclear in California.
PostPosted: Sun May 13, 2018 7:01 pm
When alcohol is specified I assume denatured because of the cost and the fact that it is mostly ethanol (cheapest to produce) with a small amount of denaturant. Other alcohols could work but are usually found as less pure (isopropyl) or more deadly (methanol) so not quite as desireable
PostPosted: Sun May 13, 2018 8:59 pm
First name: Freeman
Last Name: Keller
I've use plain old denatured alcohol from the hardware stores with Colortone dyes to make stains. I've been shooting a vinyl sealer coat over the stained wood before applying lacquer. I'll also add Colortone dyes to lacquer when I want to tint the final coats. So far its worked great
Hopefully you've kept all the maple cutoffs for practice
PostPosted: Sun May 13, 2018 11:01 pm
First name: David
City: Napa
Thanks for the info guys and yes I kept all the off cuts and am going to sacrifice some crappy maple to do test runs.
PostPosted: Mon May 14, 2018 8:59 am
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
Homestead Finishing, Mr. Jeff Jewitt's company, makes both the TransTint and Colortone dyes...it appears as though Stewart MacDonald repackages and adjusts the names to be a little more 'guitar friendly' in nature. Not sure why StewMac calls these stains, when they are metal-complex dyes, but they work well for just about everything except urethanes and oils straight from the container.
- Beth Brower
PostPosted: Sat May 19, 2018 10:30 am
First name: Julie
Last Name: Moriarty
City: Punta Gorda
State: FL
Zip/Postal Code: 33950
Most of the time I dilute Trans Tint in water but when I've used alcohol it's been off the shelf hardware store stuff. These were done with water based Trans Tint, if you're thinking of going that route.
Julie Moriarty
http://JulimorCreations.com
PostPosted: Sat May 19, 2018 12:08 pm
First name: D
Last Name: S
I prefer water because it dries slow and gives more time to blend.
You have to pre-raise the grain and sand.
Do a water wipe before applying the dye for a more even application.
Use distilled water and don’t get the piece too wet.
Of course, water on wood can be risky.
wah
Wah-wah-wah-wah
Wah
These users thanked the author dzsmith for the post: Jules (Sat May 19, 2018 1:14 pm)
Users browsing this forum: Bing [Bot], Ken Lewis, mikeyb2 and 6 guests
cron
