It is currently Thu Aug 20, 2026 1:02 am
Post new topic Reply to topic  [ 38 posts ]  Go to page Previous  1, 2
PostPosted: Thu May 10, 2018 4:18 pm
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
We have not seen any issues with the Grizzly 513/514 saws, with routine resaw of coco, ebonies, and rosewoods down to 0.100". Most drift issues we've seen on student saws have been from running dull or damaged blades that are poorly set, running the blades either too far forward or too far back on the crown of the tire, or tired, flattened tires with out-of-alignment wheels. If the blade is sharp and evenly set, it will track where pointed, which means that with good tires, centering the band (versus the entire blade) on the tire and then aligning the table and fence provides the truest tracking.
PostPosted: Fri May 11, 2018 7:54 am
"May I just got an incurable lemon."
With Grizzly - quite possible. Some are decent and some not so good.
"If the blade is sharp and evenly set, it will track where pointed, which means that with good tires, centering the band (versus the entire blade) on the tire and then aligning the table and fence provides the truest tracking."
True enough, but how often are all those conditions met in the average cabinet shop. Usually the blades are a little dull (only changed when they break) the tires are as old as the saw (unless they fall apart) and alignment is only considered when the band won't stay on the saw.
For casual resawing I use the "nail in kerf" method using a combination of my table saw and the 1/4 inch blade I keep on my 14" bandsaw. If I was doing a lot of resawing I would "dig out" the 20 inch Rockwell that has been hemmed in by other tools the past couple of years.
PostPosted: Fri May 11, 2018 8:22 am
First name: Willard
Last Name: Guthrie
City: Cumberland
We do much the same - the Woodmaster CT reserved strictly for resaw and the Morse 1/4" utility blades working until they become too dull to handle the routine tasks. I do find the two saw solution quite attractive, and band saws happily fit well in those outside corners that really cannot accommodate other tools.
PostPosted: Fri May 11, 2018 12:38 pm
First name: David
Last Name: Ingalls
City: Ashland
State: OR
Zip/Postal Code: 97520
[quote=Clay S. "Maybe I just got an incurable lemon."
With Grizzly - quite possible. Some are decent and some not so good.]
Agreed. I don't mean to trash all Grizzly machines. My 4" oscillating drum sander and 6" jointer do their jobs. The fence that came with the jointer was warped but Grizzly willingly replaced it with a good one when asked, suggesting that part of the tradeoff for lower prices is the extent to which quality control is left to the buyer. I brought up my experience with the band saw in part to point out that if the goal is to get good results with demanding tasks, cheaper machinery may not be the most cost effective strategy.
PostPosted: Tue May 15, 2018 11:23 pm
First name: Rick
Last Name: Milliken
City: Okotoks
State: AB
After decades of trying to use crappy, cheap, undersized bandsaws, I finally bought a proper one. Laguna 1412. I took some time with set up up front, but love it. Resaw works very well right up to max.
The lower guides are fussy and tight quarters, but hold adjustment very well.
Don’t know how well it would hold up to a very heavy, constant work load, but for an all around machine, I’m very pleased.
These users thanked the author Rick Milliken for the post: gregorio (Wed May 16, 2018 10:39 pm)
PostPosted: Wed May 16, 2018 10:41 pm
First name: Gregor
Last Name: Crothers
Thanks everyone.
I have taken this all in and made a decision.
Likely going to purchase it this weekend. I'll leave you guessing and throw up a picture after I bring it home. : )
Wake up and smell the rosewood!
PostPosted: Fri May 18, 2018 6:09 pm
First name: Julie
Last Name: Moriarty
City: Punta Gorda
State: FL
Zip/Postal Code: 33950
I have an 18" Jet and use blades from 1-1/2" wide down to 1/4" without any problem. But things changed on the resaw end when I bought the Laguna Resaw King. WOW! That blade cuts so easy I can see the Laguna 14SUV taking on some pretty big jobs.
Julie Moriarty
http://JulimorCreations.com
PostPosted: Fri Jun 01, 2018 8:53 pm
First name: Gregor
Last Name: Crothers
Phase 1 = Complete.
All my pennies and some non-vital organs and I'm in the game!
I can hear the cherry and walnut I have out in the garage trembling... in fear of being literally massacred! hah
PostPosted: Mon Jun 11, 2018 7:03 pm
First name: Gregor
Last Name: Crothers
Well, I finally got it home.
I'm going to need a hand to lift this thing up, so its going to have to lay in its bed for awhile.
Looks like a seriously nice machine.
Ill post some more when its upright and running. : )
PostPosted: Tue Jun 12, 2018 5:18 am
First name: David
Last Name: Ingalls
City: Ashland
State: OR
Excellent choice!
PostPosted: Thu Jun 14, 2018 7:52 pm
First name: Gregor
Last Name: Crothers
Small update.
I was quite happy to find that it has an integrated mobile base.
That is to say, I thought I had to pay for it, but it came in the box. : )
Only negative comment so far is that they did not provide the bolts to attach the rear "axle" assembly.
Moves nice and easy on the concrete.
Unfortunately, I dont think it will be spinning for awhile.
I still have to wire the saw and bring 220 into the garage.
On top of that I am in Germany for the next 2 weeks for work.
Like everything else, just going to take some time.
PostPosted: Fri Jun 15, 2018 12:19 am
Wow, you went all-in. Nice!
PostPosted: Fri Jun 15, 2018 6:19 am
First name: Gregor
Last Name: Crothers
I keep telling myself waist-deep Pat. : )
Users browsing this forum: No registered users and 135 guests
