It is currently Mon Apr 27, 2026 8:56 am
PostPosted: Fri Jun 01, 2018 10:28 am
First name: Wendy
Last Name: W
State: Arizona
This is the first time I have used Engleman spruce. I swear...all I have to do is glance at it and it dents or scratches. I'm worried about masking for the bridge when I get ready to finish the top. No matter what I do to tape, or how I peel it up, it pulls fibers out of the wood. My method of masking is to put tape over an area larger than the bridge, cut around the bridge, and peel away the excess.
Questions: 1) Is there something I can use for masking that will be less likely to pull fibers on removal? Or 2) Should I just finish completely and then scrape all the finish off the bridge area. I really do prefer masking first, if possible. Thanks, Wendy
PostPosted: Fri Jun 01, 2018 10:42 am
First name: Julie
Last Name: Moriarty
City: Punta Gorda
State: FL
Zip/Postal Code: 33950
Stew Mac sells a low-tack protective tape for taping over finishes. Some reviews said it's very low-tack, "wouldn't take fuzz off a peach." Not sure how it would do on bare wood but here's the link: https://www.stewmac.com/Materials_and_S ... _Tape.html
Julie Moriarty
http://JulimorCreations.com
PostPosted: Fri Jun 01, 2018 11:09 am
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Zip/Postal Code: 43085
I cut my mask before sticking to the top so any fibers that get pulled up are under the bridge.
My bridge is registered to the top with 2 small hole drilled through the saddle slot that small brads drop through as index pins.
I put the bridge over a sheet of frisket film with a piece of cardbord beneath. I punch the brads through the saddle slot holes, frisket film & into the cardboard. Now the film is registered to the bridge. I then cut the film, slightly undersized to the bridge.
The film is registered to the top using the index holes and a piece of low tack masking tape as a hinge (search vinyl application hinge method).
When peeling off the mask, bend it over on itself so you're pulling along the surface - don't pull up! This works pretty well for me buy YMMV.
Kevin Looker
I'm not a luthier.
PostPosted: Fri Jun 01, 2018 11:17 am
First name: Tim
Last Name: Lynch
City: Santa Cruz
Zip/Postal Code: 95060
I use Friskit masking tape. Can be bought at any good drafting supply store. Tape is .002 thick low tack. Never had a problem but you will still need to score the perimeter before removing it. Make it easy to measure your finish thickness also. Don't buy the liquid, much messier.
PostPosted: Fri Jun 01, 2018 11:37 am
First name: Brad
Last Name: Combs
+1 for the friskit film. You can pick it up an Amazon if you don't want drive anywhere. :)
PostPosted: Fri Jun 01, 2018 11:49 am
Last Name: Beaver
City: Lake Forest
I've never used Engleman so what I say may not be applicable, but.... I either use frisket or the low tack green painters tape from the Home Depot. If I use frisket I do it like Kevin says. If tape then I do it as you mentioned.
The jury is still out on which way works the best for me.
Joe Beaver
Maker of Sawdust
PostPosted: Fri Jun 01, 2018 12:16 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
Have you tried heating the tape with a hair drier before pulling it off the wood? You could do a test run on the inside surface of the top or on the off cuts to see if that prevents tearing out fibers.
You may already be doing this, but it helps to pull the tape off across the grain rather than with the grain.
PostPosted: Fri Jun 01, 2018 6:57 pm
First name: Ken
Last Name: Lewis
City: Mt. Pearl
State: NL
Another option is to route finish off with dremil mounted in a router base.
PostPosted: Fri Jun 01, 2018 8:27 pm
First name: Wendy
Last Name: W
State: Arizona
All great information and suggestions! I think I will try the friskit and Kevin's method for a change. I will also try the hairdryer next time I have to remove tape. Good idea. Thanks for all the answers!
PostPosted: Fri Jun 01, 2018 9:00 pm
First name: George
City: Seattle
My process is the same as Kevin's. I also use a hairdryer, as Jay describes. Since adopting these practices I have not had any problems with pulling up wood fibers.
Go slow. Be patient. Take your time. [:Y:]
George :-)
PostPosted: Sat Jun 02, 2018 5:07 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
Cut it off with the dremel here as well....
Brian
PostPosted: Sat Jun 02, 2018 5:59 am
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
We do a rout-off, but the concern with either that approach or a 'mask and score' is that any wood fibers nicked in the process provide a place for stress to concentrate and cause a joint failure. A rout-off largely avoids the issue at the cost of removing 0.001"-0.002" of finish-saturated wood.
These users thanked the author Woodie G for the post: Pmaj7 (Sat Jun 02, 2018 9:22 am)
PostPosted: Sat Jun 02, 2018 1:53 pm
To remove some of the tackyness of masking tape I will stick it to my clothing where it picks up lint and dust. I try not to leave it on the wood too long And prior to removal I do carefully score score the finish.Being careful to remove tape across the grain rather than along the grain also seems to help.
PostPosted: Sat Jun 02, 2018 3:07 pm
Wendy, I'm going to be contrary to everyone here. I would suggest to put the bridge on, give the top a light wash coat and then play the guitar to determine if any adjustments need to made, make the needed adjustments, then finish. It's not too difficult really.
Users browsing this forum: Mark Mc and 21 guests
