It is currently Thu Sep 18, 2025 9:41 am
PostPosted: Mon Jun 11, 2018 8:32 pm
What glue do you all recommend for marrying purfling and binding strips before bending?
Specifically gluing BWB to the binding for the side strip
PostPosted: Mon Jun 11, 2018 8:34 pm
Titebond 3. But that's it's only use...
PostPosted: Mon Jun 11, 2018 9:12 pm
First name: Freeman
Last Name: Keller
I cheat and by wood binding with the purfling line already glued on the short side and bend them when I bend the sides. If I want purfling on the top or back of the guitar I sandwich the lines in the channel and wick thin CA into the interface. This sort of shows it - the rose wood binding has a maple line on the bottom, I'm adding another between the binding and the body.
I bought one of those binding laminator thingies from StewMac that uses acetone to laminate plastic binding - using it was kind of a cluster so now I just stack the strips in the channel. Acetone only works on plastic binding, since I use wood, plastic, fiber and the little teflon to hold a gap for pearl my glue of choice is water thin CA. Others don't like it, I've had great results with it.
PostPosted: Tue Jun 12, 2018 7:38 am
First name: Mark
Last Name: McLean
City: Sydney
State: New South Wales
Zip/Postal Code: 2145
+1 for Titebond 3, as it holds together despite the heat when bending. But I agree that it is the only place that I use that glue. Everything else is TB1 or hide glue.
PostPosted: Tue Jun 12, 2018 8:03 am
Last Name: Colbert
City: Anacortes
+1 for TB3. It’s also the only place I use it. A problem I run into is that the premade purflings I buy aren’t layed up using TB3 and sometimes delam in the bender.
PostPosted: Tue Jun 12, 2018 8:14 am
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
Fish glue
Users browsing this forum: doncaparker and 40 guests
