It is currently Sat Jun 21, 2025 1:26 am
PostPosted: Wed Aug 08, 2018 6:53 pm
First name: Freeman
Last Name: Keller
I have been asked to look over a lovely little Benary parlor guitar built circa 1886. Apparently the other name associated with this style guitar is Tilton - I believe that Benary licensed the construction from Tilton (if anyone has good information I would appreciate it).
Anyway the guitar does need a neck reset and I'm trying to decide whether I want to take it on or not. It has a neck stick, very much like a banjo, running just below the top from the neck heel to the tail end of the guitar. I cannot see how the stick is attached and whether it is shimmed. I'm familiar with neck sticks in both banjos and resonators but this also looks like the neck heel is glued into the head block - it doesn't make sense that the guitar would have a dovetail plus the stick (I don't think). I can provide pictures but they won't show any details of the neck or the stick.
Any information would be appreciated. The guitar is playable in the first positions and I'm not crazy about diving into something this old that I don't understand.
PostPosted: Wed Aug 08, 2018 7:08 pm
pictures would still be appreciated by anyone that wants to help I'm sure.
PostPosted: Wed Aug 08, 2018 9:18 pm
First name: Freeman
Last Name: Keller
OK, here is the little jewel in its original coffin case
It is spruce (probably Adi) over Brazilian rosewood, has a funky plastic tailpiece that says patented on 1886 and a funky plastic disc on the inside with the makers name
The neck stick is approximately 1/2 tall and 3/8 wide, made out of some kind of dark wood and fastened into the neck heel
It definitely needs a neck reset
Advice and encouragement would be helpful
PostPosted: Thu Aug 09, 2018 2:58 am
Last Name: Reed
City: Stowmarket
State: Suffolk
Zip/Postal Code: IP14 2EX
Country: UK
My first guess would be that under that very funky tailpiece there is a screw or bolt into the end of the neck stick.
If so I'd loosen/remove that and see if moving the stick changes the geometry - I reckon it will. If that works, you then have to decide how to reattach the end of the neck stick (if it's screwed). I suggest trying to get pictures of the inside, to see what you have at the tail end. It looks like you could get a phone in there and take pictures using flash.
PostPosted: Thu Aug 09, 2018 2:57 pm
First name: Freeman
Last Name: Keller
I was hoping the same thing Chris, but not to be. The tail piece was screwed on with three fairly short screws, not long enough to go thru the end block. There is a 5/16 hole below the tailpiece (old strap button?) - I can reach thru and measure the end block at a bit over 1 inch. At some point the tailpiece had been move up a bit, there were two sets of holes
It is really hard to see much inside the instrument - not only the small size but that darn stick is in the way. However poking around with an inspection mirror and flash light it looks like the stick is let in to both the head and tail blocks. There are three ladder braces on the top - one under the bridge and one ahead and behind the bridge. The neck stick is contacting the first and third brace, not the one under the bridge.
Reading about the Tilton design apparently they had patented something about this neck stick and it was part of their "sound". I'm thinking that it has less to do with setting the neck geometry and more with some sort of bracing effect. The guitar has a fairly significant concave top - maybe they were trying to counter the downward component of the bridge - the fact that it has a tailpiece means the top is acting more like an archtop with the vertical component.
If that speculation is true it might just have a simple dovetail with this brace between the end blocks. However until I know more I not going to risk trying to get the neck off.
PostPosted: Thu Aug 09, 2018 3:05 pm
It might be worth taking the fingerboard off to see if you can get an idea of how the neck joinery is laid out. Once you know that you could create a plan that includes addressing the stick.
PostPosted: Fri Aug 10, 2018 9:14 am
That's what I was thinking. Just a brace but it also allows for the attachment of the plate - maybe they advertised it as a "Virzi plate" or Tone plate to differentiate their guitars from others.
PostPosted: Fri Aug 10, 2018 11:23 am
First name: Freeman
Last Name: Keller
I'm not going to do anything invasive until I know exactly what I'm dealing with. The idea isn't to make this a player but rather to preserve a really charming little instrument.
PostPosted: Fri Aug 10, 2018 5:21 pm
Did you see the action with strings on it? That neck set is about right for a classical guitar, which would of been the norm during that time period.
PostPosted: Fri Aug 10, 2018 6:54 pm
First name: Freeman
Last Name: Keller
When it came to me it had a new set of nylon strings (with beads and balls to make them work with the tailpiece). The action was in excess of 0.150 (4mm) at the 12th fret.
This is another question that I need to resolve for the owner - how to string it. It is ladder braced, has a fixed bridge with a piece of fretwire for the saddle, and has the the tailpiece. The bridge has a little raised piece behind the fretwire saddle that has holes in it - apparently to space the strings coming from the tailpiece. The break angle is very low (I didn't measure it but I would guess only a few degrees. The tuners have small metal rollers rather than big plastic ones. The nut looks like the slots were cut for strings that increase in size (the nylon high E was fairly tight in the slot). Nut width is 1-3/4, I didn't measure the bridge.
I found reference to a couple of similar guitars with a web search. This guitar is remarkably similar, says its currently strung with silk and steels
https://reverb.com/item/6903561-benary- ... w.ds&pla=1
PostPosted: Sat Aug 11, 2018 5:47 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
I restored one of these a few years ago. It left my shop with a set of D'Addario EJ40 Silk & Steel strings on it. The tailpeice string termination and the support stick that you are wondering about seemed to point to this being a reasonable choice as I remember the scale being short as well. My research indicated that this was one of the first guitars designed to accept the new steel strings which is the main purpose of the vertical bar through the body, to hold the tension. From what I recall The stick is set into a square mortise in the head and tailblocks and glued. I cannot remember if this job included a neck set or not, I gave a quick look through my pics from when I think I did the job but I have thousands of pics from the past decade of doing this.....
Brian
PostPosted: Sat Aug 11, 2018 5:53 am
Last Name: Howard
City: Magnolia
State: Delaware
Found them! No neck set but I had the back off to repair lots of cracks.....
Brian
These users thanked the author B. Howard for the post: Johny (Tue Aug 14, 2018 8:13 pm)
PostPosted: Sat Aug 11, 2018 11:30 am
First name: Freeman
Last Name: Keller
Brian, you rock. That is exactly what I have. So the "stick" is really a brace between the head and tail blocks which makes total sense with the tailpiece.
I've repaired several cracks but was able to do it thru the sound hole (even with that darn stick in the way). I'll also discuss with the owner whether he wants to worry about the neck angle and which strings to put on it.
PostPosted: Sat Aug 11, 2018 11:39 am
Last Name: Howard
City: Magnolia
State: Delaware
Glad to help. I notice the celluloid tailpiece on yours is deformed as well. This is common and it looks as if the one in the reverb listing has a reproduction. My client opted to use a metal replacement tailpiece and keep the original in the case as we could not find a repro. I had a strategy to repair and reinforce the original with a small section of brass tubing cut in half inside to support the ball ends.
Brian
PostPosted: Sat Aug 11, 2018 7:03 pm
First name: Freeman
Last Name: Keller
Thank you again, Brian. Here is the rest of the story. I closed and cleated the largest crack, worked a little HHG into some other small ones and one on the neck heel (which had been worrying me if I had to do a reset), did some minor cleaning without removing any of the wonderful patina. Restrung with the nylon strings that were on it and met with the owner. Told him the action was fine in the first position but pretty high as we moved up the neck - its certainly playable and he agreed to take it as it is.
It sounds pretty wonderful with the nylon strings and I couldn't resist playing Ashokan Farewell - seemed to suit the little gem. Oh, when I cleaned out the dust bunnies and other bits and pieces I found a lady bug long since gone from this world. I figure she might be some of the mojo so I carefully put her back inside
There was a small piece of felt under the strings at the saddle - don't know why but I put it back. Here is another shot of the tailpiece
These users thanked the author Freeman for the post: Johny (Tue Aug 14, 2018 8:16 pm)
