It is currently Sat Aug 02, 2025 4:28 pm
 Post subject: vinyl placeholder
PostPosted: Thu Oct 11, 2018 9:58 am
First name: Richard
Last Name: Hutchings
City: Warwick
State: RI
Zip/Postal Code: 02889
Been doing some searching for the vinyl strips used for placing a purfling strip after gluing the binding. I bought soe herringbone purfling and I think I will need this to install it.
Hutch
 Post subject: Re: vinyl placeholder
PostPosted: Thu Oct 11, 2018 10:07 am
You should be able to bend the strips after a quick hot water bath (very quick or it will fall apart.
It should fit into the purfling channel fine. Install at the same time as the binding.
There are Teflon strips to use as a spacer if you're doing a shell inlay, but not for herringbone.
These users thanked the author bftobin for the post: banjopicks (Thu Oct 11, 2018 10:20 am)
PostPosted: Thu Oct 11, 2018 10:17 am
Most of the herringbone I've used was not as thick as the binding, so you need a stepped rebate - one for the purfling and a deeper one for the binding.
PostPosted: Thu Oct 11, 2018 10:26 am
First name: Richard
City: Warwick
State: RI
Teflon, not vinyl. That's why I couldn't find it. And now I know I don't need it. Thanks
Clay, I am aware of that. Should be fun trying to get that right. I use a simple jig on my router table for binding ledges but have never done a stepped one. I also have the hand tool for final adjustments if needed or I may try to do the whole thing by hand. This step is a long way off so I have plenty of time to think about it and then change my mind at the last second. :-)
Hutch
PostPosted: Thu Oct 11, 2018 10:48 am
First name: Freeman
Last Name: Keller
Here is the teflon strip used to hold a channel for abalone purfling
PostPosted: Thu Oct 11, 2018 11:27 am
Online
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
Just a note regarding terminology: You can use Teflon (PTFE), but UHMW plastic works just as well for this application and is cheaper. If you buy what is labeled as Teflon from LMI in the already cut sizes, that's fine, but if you want to just buy larger sizes of UHMW plastic and cut it down yourself, you might get more bang for your buck. Just a suggestion. Oh, and I agree that it is unnecessary when dealing with herringbone. It is a shell thing. For Herringbone, just cut both channels and glue both the purfling and the binding in one step.
PostPosted: Thu Oct 11, 2018 11:48 am
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
You can pre-bend herringbone binding to fit your guitar body shape by placing it in a large cookie sheet filled with hot tap water for 90 seconds and then taping it to the side of the body and leaving it overnight to set. This makes installing it at the same time as the binding easier. I've found that after soaking, taping the two purfling strips together and then taping both pieces to one side of the guitar prevents twisting of the purfling. When I taped one piece separately to each side of the body, the purfling had a tendency to twist because of its width.
These users thanked the author J De Rocher for the post: banjopicks (Fri Oct 12, 2018 9:02 am)
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
Zip/Postal Code: J2M 1R5
As suggested by others, not only is a plastic spacing strip unnecessary for installing herringbone, it’s likely a really bad idea. Herringbone has variation in thickness when straight and even more so once bent. You’ll have trouble fitting some areas and gaps in others.
Various ways to bend the stuff. I make sacrificial strips of maple the same “thickness” and bend a sandwich, together with any side purfling lines as I bend the binding in my Fox bender.
PostPosted: Fri Oct 12, 2018 8:16 am
I have not used herringbone for a long time but when I did here is how I bent it. It works well.
http://www.kennedyguitars.com/bending-herringbone.html
PostPosted: Fri Oct 12, 2018 9:03 am
First name: Richard
City: Warwick
State: RI
I like this method, no extra fixtures to make.
Hutch
Users browsing this forum: doncaparker and 53 guests
