It is currently Fri Jun 05, 2026 9:57 pm
PostPosted: Sun Dec 16, 2018 11:37 am
Last Name: Schaefer
City: Atlanta
State: Ge
Zip/Postal Code: 30310
I am assembling a StewMac Baritone Ukulele kit. I am getting close to gluing on the top and bottom. Looking at the braces they are big and bulky and certainly do not taper to paper thin at the ends. Should I spend time thinning these out a little?
Anything else I should do before gluing the top and bottom on.
PostPosted: Sun Dec 16, 2018 9:33 pm
If you make them more of a triangle shape, they will be nearly as stiff but much lighter.
New username, same ole Pat Mac
PostPosted: Mon Dec 17, 2018 4:50 am
Last Name: Schaefer
City: Atlanta
State: Ge
PostPosted: Mon Dec 17, 2018 9:45 am
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
Never done a baritone uke before but. . . I would profile the cross section to remove some mass as mentioned above and I would certainly work the ends down to either feather them out to nothing or thin enough to tuck under notches in the linings. If it were me, I would choose feather out to nothing.
Bryan Bear PMoMC
