It is currently Sun Aug 03, 2025 5:04 pm
 Post subject: LR Braggs Anthem
PostPosted: Sat Jan 26, 2019 5:50 am
Just fitted an LR Braggs Anthem to a Sigma 000-18, first time I've heard one, and must admit I'm quite impressed.
 Post subject: Re: LR Braggs Anthem
PostPosted: Sat Jan 26, 2019 6:54 am
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
We have installed somewhere around 50 of them in the last three years, about half replacing B-Band, I-Beam, passive K&K, and Taylor Expression systems and the others on new guitars or first pickups. The only real complaint we have is the cream color of the soundhole unit, which often forces us to a flush installation and adding some additional stand-offs to allow that style of mounting. A color change to the same tortoid-colored plastic used for the Lyric mic would likely save the customer about $30 on some installations.
- Beth Brower
PostPosted: Sat Jan 26, 2019 7:40 am
Had to use a 2mm standoff for the control module due to high sound hole bracing, and slipped it a bit under the edge because it's a smaller sound hole than the 4" it's made to fit so it's not so obtrusive in this particular model.
PostPosted: Sat Jan 26, 2019 2:09 pm
First name: Conor
Last Name: Searl
City: Duncan
State: British Columbia
Zip/Postal Code: V9L 2E5
Woodie, you like them more than the K&K? Every time I hear one of those K&K passive pickups I'm knocked over with how good an amplified acoustic can sound these days. Microphones still win, but not so practical with a full band.
PostPosted: Sat Jan 26, 2019 2:15 pm
First name: Joey
Last Name: Holliday
City: Palmetto
Zip/Postal Code: 34221
The miniflex 2mic sounds good as well but it's clunky and is a PITA to install especially if you have large hands.
That being said the Anthem is pretty sweet.
PostPosted: Sat Jan 26, 2019 3:27 pm
Have installed several Baggs units through the decades, but not an Anthem....
Another vote for the Ken Donnell Mini-Flex systems. I prefer them very much over under saddle transducers, as they have a more natural sound. I have hams for hands, and have a little problem when the soundhole is smaller - but the effort is worth it in the long run.
PostPosted: Sat Jan 26, 2019 10:48 pm
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
Those of you who dislike how USTs sound might want to try an LR Baggs Lyric. It’s basically an Anthem without the UST.
PostPosted: Sun Jan 27, 2019 7:27 am
First name: Willard
Last Name: Guthrie
City: Cumberland
Given my limited experience, I'll pull from the flyer we provide to those considering pickup installation to try to explain why we believe the Anthem works so well for for lower-cost installations for some acoustic performance situations:
Quote:
We believe the Anthem is the best solution for an acoustic performance (e.g., solo or duet/trio of other acoustic stringed instruments; vocal accompaniment) mic/transducer system under $800 installed (retail cost of system plus install labor). The Anthem uses the mic for mids and highs, and the under-saddle transducer (UST) for low frequency when blending. Running the blend control in the other direction progressively pulls the mic signal out of the mix and adds mids and highs from the UST. Baggs addressed the weakness of most onboard mics - sensitivity to installation location/capsule orientation - by mic capsule design, mounting, and preamp signal processing to eliminate tunnel effect and other issues seen in internal mic systems. Baggs considers the Anthem system primarily a mic system supported by the UST, although we have customers that are happy to use a soundhole cover and the UST alone for play where the stage environment is not handled well, retaining the preamp function of the system (i.e., impedance matching and moderate signal boost (~3 dB).
Quote:
For those that have used the Baggs i-Beam or other acoustic pickup system, there is little in common with this latest generation of Baggs systems - the Element UST, the Lyric mic, and the Anthem and Anthem SE systems are game changing technology, providing the sort of fidelity seen in the K&K Pure, plus the tone-shaping potential seen in higher end onboard preamp/transducer/mic installations.
Quote:
Like other transducer (K&K Pure; Fishman Matrix) or transducer/mic systems (K&K Trinity, Fishman Matrix Blend), the Anthem is not the best system for players who generate a lot of movement of guitar against body or who employ a lot of guitar body dynamics (rap/slap/tap) in their performances. We have found that of these systems, the Fishman Matrix is the least sensitive to impulsive noise, but it is also the least accurate of the amplification systems mentioned (although this lack of accuracy may not matter in a given band or venue situation).
Quote:
The K&K Pure is a great low-cost solution (~$175 installed) for acoustic venues in non-band situations. The issue with the Pure is lower output on some guitars with heavier, less responsive construction and the potential for noisy signal. The K&K is also surprisingly sensitive to installation variances - minor errors in installation make a big difference in how well the system works, and can require some trial placements on non-traditional instrument configurations to ensure the best location to balance output and noise. The K&K UltraPure (~$300 installed) addresses some of the issues with output and balance with an onboard 3-band EQ and phase control, but correct installation of the bridgeplate transducers is still the best way to start with as balanced and clean a signal as possible. With a soundhole cover, the Pure and UltraPure will support performance in higher volume environments, but other systems such as soundhole magnetic pickups or magnetic/mic systems (e.g., Fishman Rare Earth/Blend, Baggs and Infinity Blend; L.R. Baggs M1 and M80 soundhole magnetics) may be a better choice for those players fronting a band with a steel string acoustic.
We have done installs of a number of other systems, such as the Trance Amulet MVT, broadcast-quality lavalier/Dazzo SBT combos, PUTW, and McIntyre , with retail value up to about $2200 for the components, as well as removing some of those systems a few years later in favor of another 'Holy Grail' system. It seems like Acoustic Guitar Forum has a role to play in generating this sort of churn, although we are always surprised at just how many $25K plus guitars get a K&K Pure and nothing else.
- Beth Brower
These users thanked the author Woodie G for the post: Pmaj7 (Sun Jan 27, 2019 8:59 am)
Users browsing this forum: No registered users and 40 guests
