It is currently Sun Apr 26, 2026 3:40 pm
 Post subject: Oh No!
PostPosted: Mon Feb 04, 2019 4:41 pm
I have waited all year for winter so that humidity in my home would drop to levels suitable for joining and bracing the top and back. I have glued most of the soundboard braces on at around 40% for the last 4 days. Today I glued the last brace on the soundboard this morning around 10:30, at 40% RH.
Temps outside have risen to 60F since then, and it is a beautiful day. So beautiful in fact, that my wife opened the front door to let a little fresh air and sunshine in.
I did not even think of this; but I was gluing the back graft to the underside of the back, and happened to glance at my hygrometer. 60% RH. gaah
I don't know if that swing since I glued that last tone bar on will cause issues down the road, but it is done, and I can't undo it.
Hopefully night time temps will kick my furnace back into action and lower RH so I can glue up the back braces. They are ready to go, Just have to wait on the back graft to dry.
A question related to this; can I shape braces at 60% humidity, or will I need to wait for humidity to steady down a few days before?
Thanks.
 Post subject: Re: Oh No!
PostPosted: Mon Feb 04, 2019 4:48 pm
First name: Big
Last Name: Jim
I don't think you will have much issue with it . Prolonged Higher % might have been, however the time frame your talking about was relatively short . Just my .02 worth
These users thanked the author WudWerkr for the post: Mike Baker (Mon Feb 04, 2019 4:54 pm)
PostPosted: Mon Feb 04, 2019 4:57 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
Once you get the humidity down again, I would let the braced top set at that RH for a while so it can equilibrate, then glue it to the rim at close to the same RH as you braced it.
Bryan Bear PMoMC
PostPosted: Mon Feb 04, 2019 4:59 pm
Last Name: Kincheloe
Yeah, my humidity has been all over the place this past week, with the outdoor temperature going from sub-zero to 60+ degrees in a few days...
The back seam reinforcement is so narrow and thin, it's unlikely to cause any problems. But do wait before gluing back braces.
Humidity is irrelevant when carving.
PostPosted: Mon Feb 04, 2019 5:03 pm
Thanks gentlemen. Very much appreciated.
What about carving the braces? Can I carve them once the glue has dried, so they will be ready when the humidity settles down, or should I wait?
PostPosted: Mon Feb 04, 2019 5:40 pm
Online
Carve braces at whatever humidity you like...
These users thanked the author meddlingfool for the post: Mike Baker (Mon Feb 04, 2019 5:48 pm)
PostPosted: Mon Feb 04, 2019 5:48 pm
Thanks, Ed!
PostPosted: Mon Feb 04, 2019 6:25 pm
We closed the door. Everyone got mad at me. Oh well, what can you do?
I put a fan in there running on medium. The room is 10' x 10', and it is already down to 48% RH. Now I need to let it be for a bit.
Thanks for all of the advice.
Users browsing this forum: meddlingfool and 25 guests
