It is currently Thu Jul 31, 2025 4:11 pm
PostPosted: Sun Feb 17, 2019 6:32 pm
Last Name: Livermore
State: Minnesota
Has anyone had issues with using tentalones for the top/rim jointon a steel string?
Asking for a friend.
dl
PostPosted: Sun Feb 17, 2019 6:33 pm
That's what Sexauer does...
PostPosted: Sun Feb 17, 2019 7:56 pm
Last Name: Kincheloe
Only in terms of time consumption if you make them too small :) I like to have a selection from around 3/8" long for the waist to 3/4" for the lower bout, and sand them convex or concave to mate with the sides. I also make supersize ones for armrest bevels.
PostPosted: Sun Feb 17, 2019 8:02 pm
Last Name: Ball
It's the way Charles Fox was teaching back in the 70's when I made my journey to Earthworks...
PostPosted: Sun Feb 17, 2019 8:04 pm
I have used them on steel string flat rimmed instruments built on a solera and never had a problem with them. You could probably space them like pickets on a picket fence and still not have a problem.
PostPosted: Sun Feb 17, 2019 9:37 pm
Rob Girdis did that on all of his guitars. Built on a Solara.
New username, same Pat Mac
PostPosted: Mon Feb 18, 2019 2:16 am
No, never any problems, also my preferred way of doing this job.
PostPosted: Mon Feb 18, 2019 11:00 am
First name: George
City: Seattle
I switched to using tentallones several guitars ago and have not had any problems. What's going on with your friend's instruments?
George :-)
PostPosted: Mon Feb 18, 2019 5:05 pm
State: Minnesota
Thanks all for responses.
I have a client who questioned the practice as I too have done this on steel strings and wanted some backup for the idea.
dl
PostPosted: Mon Feb 18, 2019 5:58 pm
Dave Livermore wrote:
I have a client who questioned the practice....
dl
I’d have a very had time with this. If someone wants me to make a guitar, I would seriously wonder why they are questioning my practice.... I wouldn’t want someone looking over my shoulder questioning every process I’m doing.
Dave, please feel free to tell me to delete this if your plan is to show your client this thread.
PostPosted: Tue Feb 19, 2019 7:48 am
The work of Rosie Heydenrych, luthier "Turnstone Guitar Company"
PostPosted: Tue Feb 19, 2019 8:40 am
For those of you who choose this method what do you feel the advantage is?
Just curious
PostPosted: Tue Feb 19, 2019 9:26 am
The method works well when you build guitars 'off the top' in the Spanish tradition. That is with an open work board (solera) in stead of a mold. You can place the bent sides along the outline of the guitar and clamp it down. Sometimes you have to push and pull the sides to get it to follow the line perfectly, once clamped it will stay there and then you set in the tentalones and it retains it's shape.
I've been thinking of gong in this direction as I do build off the top. I normally glue kerfed strips to the sides then clamp the whole assembly up but sometimes to the eye you can see a slight discrepancy. The thing is, it takes a lot more work to do it this way.There also seems to be a shift in thinking about guitar design to use stiffer sides with solid linings or reversed kerfed linings for better tone.
PostPosted: Tue Feb 19, 2019 9:35 am
No need to fit the braces into the linings! And much easier to deal with side braces.
Seems like it is the preferred method when using a Solara.
And you get to use the word tentallones!
PostPosted: Tue Feb 19, 2019 12:03 pm
First name: George
City: Seattle
Pat gets it! Tentalone, tentallone, tortallino ... no matter the spelling they go well with a nice red sauce. pizza
Personally, I started experimenting with tentallones (and Spanish-style building methods) after reading a somewhat casual reference to fractals. The "best" approach to building, of course, is whatever your ears tell you.
George :-)
These users thanked the author George L for the post: Pmaj7 (Tue Feb 19, 2019 4:11 pm)
PostPosted: Tue Feb 19, 2019 12:59 pm
Sometimes I make the classic triangular shaped kerfed linings which at one point are rectangular. If they are of the right starting dimensions then in the process of making them triangular I generate tentalones from the off fall. Then the only wood wasted is the saw dust (unless I want to mix it with glue and make wood putty :lol: )
PostPosted: Tue Feb 19, 2019 2:15 pm
Tentalones make more sense when working on a solera than a kerfed 'ribbon' liner. They do take some time, but keep in mind that many of the old ways seem more reasonable if you consider wood to be expensive and hard to get, and labor to be cheap. You can make a lot of tentalones from leftover brace stock by simply cutting it into short pieces in a little miter box and splitting them in half along the diagonal. There's very little waste.
Users browsing this forum: doncaparker and 16 guests
