It is currently Tue Apr 21, 2026 10:08 am
 Post subject: Saddle end rounding jig?
PostPosted: Sat Apr 20, 2019 9:45 am
Last Name: Blower
City: Keighley
State: West Yorkshire
Country: UK
Has anyone come up with a simple jig for shaping (rounding) the ends of a saddle?
I’ve always filed and sanded by hand but it seems like a task crying out for a jig to make it perfect and repeatable every time. My limited intellect just can’t conjure anything up.
A quick web search has come up dry, but maybe someone here has thought about this and come up with a solution.
PostPosted: Sat Apr 20, 2019 10:22 am
Last Name: smith
City: hemet
State: ca
Zip/Postal Code: 92543
roundover bit on router table before other shaping
PostPosted: Sat Apr 20, 2019 10:50 am
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
During a typical setup job, I doubt that I would want to take the time to set up my router table, or any other jig, just to put rounded ends on the saddle. It requires a few strokes on PSA backed sandpaper stuck to the bench, and boom, it's done. I guess you could use a fret crowning file. My point is that, other than in a high volume factory setting, I really don't think this is something that needs a jig. It just needs some TLC in the moment.
PostPosted: Sat Apr 20, 2019 11:43 am
I'm with Don, PSA on a slab. after thicknessing.
PostPosted: Sat Apr 20, 2019 11:45 am
Last Name: Colbert
City: Anacortes
+1 for keeping it simple.
I use a 12x12 granite tile with 150, 240, 320, and 400 grit 3M Stikit gold paper ready to go. It can’t take me more than a couple of minutes to radius the ends using this setup. I also write the grit on the face of the paper so I don’t screw up as I’m sneaking up on a good tight fit.
Best, M
PostPosted: Sat Apr 20, 2019 1:05 pm
Last Name: Blower
City: Keighley
Country: UK
Thanks for the responses chaps.
The simple way works fine, I was just wondering if anyone had come up with an elegant jig based solution. For one off saddles I agree it’s probably overkill, but perhaps a jig could be useful if making a batch of pre-shaped blanks.
I’ll give it another coat of thinking. :)
PostPosted: Sat Apr 20, 2019 3:32 pm
Last Name: Sollod
If you want speed you could use a disk sander if you have one set up to quickly get close to the size of the saddle slot and knock off the corners. Like Michael, I have a board that I glued successive grits of sandpaper to. I can start off with course and quickly go through finer grits...
www.swiftcreekguitars.com
PostPosted: Sat Apr 20, 2019 8:47 pm
First name: Trevor
Last Name: Gore
City: Sydney
Make a custom sanding stick with a groove in it of the right diameter. Make it long enough and you could finish the job with one stroke!
http://www.goreguitars.com.au
These users thanked the author Trevor Gore for the post: Tim Mullin (Mon Apr 22, 2019 3:12 pm)
PostPosted: Sun Apr 21, 2019 7:00 am
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
You know those razor knife/box cutter blades that come in dispensers of 100? They have 2 rounded cutouts at the top that fit the handles. Those two rounded cutouts make perfect scrapers for the shape of saddle ends and tops.
Ed
These users thanked the author Ruby50 for the post (total 2): Clay S. (Mon Apr 22, 2019 9:09 am) • dpetrzelka (Sun Apr 21, 2019 11:14 am)
PostPosted: Mon Apr 22, 2019 9:03 am
I start with a 45 degree chamfer on the 6 X 89 belt sander followed by a rounding on the same machine ,then hand sand- total time 3 minutes.
PostPosted: Mon Apr 22, 2019 6:18 pm
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
Zip/Postal Code: J2M 1R5
Rounding one end is not so difficult — many options. The tricky part is rounding the opposite end while keeping the saddle length perfect.
PostPosted: Mon Apr 22, 2019 6:23 pm
Yes, good point.
I have noticed on many guitars from even some prominent makers a gap at one end of the saddle-very disturbing!
PostPosted: Mon Apr 22, 2019 6:24 pm
Last Name: Parker
City: Charleston
Like I said above: a little TLC. It’s easy to go too far.
PostPosted: Mon Apr 22, 2019 8:34 pm
"Rounding one end is not so difficult — many options. The tricky part is rounding the opposite end while keeping the saddle length perfect."
" I have noticed on many guitars from even some prominent makers a gap at one end of the saddle-very disturbing!"
" Like I said above: a little TLC. It’s easy to go too far."
"I’ve always filed and sanded by hand but it seems like a task crying out for a jig to make it perfect and repeatable every time. "
laughing6-hehe
PostPosted: Mon Apr 22, 2019 11:00 pm
Treat the end of the saddles like a fret that's been leveled and you are now crowning it.
Or, in other words set your end points and make a pencil mark on what will be the crown of the saddle ends then have at it with a nice file. I like fairly non-aggressive 1/2 round files for saddles. Anyway I make saddles from scratch every week and do the ends by hand and it only takes a minute per end.
It's so quick and a no brainer that a jig for me and our shop which is high volume commercial would be a waste of time, effort and opportunity costs.
Also gaps are not acceptable especially on the ends and pretty easy to not have. Remember too that your nut buffer.... can be a good tool to dial in saddle ends as you are polishing them and removing scratches.
PostPosted: Tue Apr 23, 2019 10:52 am
Brad Goodman wrote:
Yes, good point.
That is one of the first things I look at when evaluating a guitar for fit and finish. I have a few saddle blanks sitting around that didn't quite make the grade.
PostPosted: Tue Apr 23, 2019 3:17 pm
Yep, every once in a while I have to remake a nut or saddle. I'm picky about what goes out on customer instruments.
Users browsing this forum: No registered users and 42 guests
