It is currently Fri Jun 12, 2026 5:09 pm
 Post subject: Baritone Ukulele Bridge?
PostPosted: Wed Apr 24, 2019 4:04 pm
Last Name: Schaefer
City: Atlanta
State: Ge
Zip/Postal Code: 30310
I need to either make a baritone ukulele bridge or buy one. Does anyone know where I can get one? StewMac sells Ukulele Bridges but not for the Baritone.
I would be Ok with making it, but I can't think of a way to do it without getting my fingers very close to a spinning blade. I will take a tutorial of you know of one.
PostPosted: Wed Apr 24, 2019 10:49 pm
First name: doug
Last Name: powdrell
City: hilo
State: big island
Bandsaw with push stick?
PostPosted: Thu Apr 25, 2019 4:34 am
Last Name: Schaefer
City: Atlanta
State: Ge
You don't use the bandsaw to cut the groove for the bone do you? You got a cut that with the router or maybe even a tablesaw. Also in my plans there's a slanted slot where are the strings pass through the back side of the bridge. Do you do that with a band saw
PostPosted: Thu Apr 25, 2019 12:23 pm
First name: doug
Last Name: powdrell
City: hilo
State: big island
Several methods to choose from depending on your tools, etc.....
I take a 2" x 8" x 1/2" blank to make 4 bridges. Using a Proxxon mini table saw, cut the saddle slot, then four 1" x 4" blanks on the bandsaw or mini table saw. I use pin bridges, so remove excess on mini table saw. Push stick. Your slots could be cut, I imagine, on a bandsaw or japan saw, and microfiles depending on the width of your kerf...again, I use pinned bridges, so limited info, sorry......best of luck. Sometimes just buying pre-made is the way to go (have done that too!)
PostPosted: Thu Apr 25, 2019 2:36 pm
Last Name: Schaefer
City: Atlanta
State: Ge
I would buy one if I could find someone selling them
PostPosted: Thu Apr 25, 2019 5:55 pm
Last Name: Miller
City: Wood Dale
State: Illinois
Mike at Mainland Ukulele sells parts. I have bought neck, fretboard , tuners, and bridge with saddle from him. Tenor size but bridge should work for baritone.
Ed M
PostPosted: Thu Apr 25, 2019 8:25 pm
You don't need power tools for a simple uke bridge. Get a small craft saw and go to it.
PostPosted: Fri Apr 26, 2019 12:57 pm
First name: Kevin
Last Name: Mason
City: Wheeling
State: IL
Zip/Postal Code: 60090
My baritone uke bridges use the same string spread as my tenor bridges (1.75"), so a pre-made tenor bridge will work just fine. However, these days I make the bridge footprint a bit larger for a baritone.
Kevin Mason
Mason Guitars and Ukuleles on Facebook
http://masonguitars.net
PostPosted: Fri Apr 26, 2019 1:32 pm
Last Name: Schaefer
City: Atlanta
State: Ge
Thanks!!!
I wish someone had said this earlier :)
PostPosted: Thu May 16, 2019 1:41 pm
First name: Kevin
Last Name: Keith
City: Conroe
Zip/Postal Code: 77384
Since I make my own fingerboards from blanks, I can use the left over end wood to make my own bridges to match. Still a beginner ukulele maker, on #12 now, but could not find any bridges for sale that I like, so I get to create mine however I want. Cut the bridge to the size you want, ( use 1x3.5 or 4 inches x1/4). I made a jig to cut the slot with at router and a 1/8" bit. Then I use a chisel to bevel the ends, and file and sand the final shape. Lately I have been polishing the bridge with a dremmel and polishing wheel with tripoli, and then finishing with caranuba wax. They come out very nice and smooth. Westfarthingwoodworks.com has a good video on making your own bridges. I also bought his book on making jigs which has been very helpful. That book is where I learned to make my own fretboard slot duplicator and bridge slot cutting jig.
These users thanked the author modkev for the post: Steve-atl (Thu May 16, 2019 2:03 pm)
PostPosted: Thu Jun 13, 2019 8:20 pm
Cheapest and easiest way I've found is to buy a finished bridge on eBay. You can buy rosewood ones that come with all the slots ready cut. You often need to sand the base smooth and square to the slot but nothing that can't be done with hand tools, far from spinning blades. Just search for ukulele saddles, not baritone, and check the dimensions given.
I bought 4, with bone saddles for $14.50. The string spacing for those was 12mm which should work on a baritone.
After all string spacing is up to you. Having said that I mostly make my own because I like to differentiate by using more exotic timber. I use a router and have a timber jig that that pushes the bridge past the router bit. It not only keeps my fingers far from the action but ensures the cut is properly lined up. It's quick and easy.
