It is currently Sat Sep 13, 2025 8:40 pm
PostPosted: Thu May 16, 2019 2:33 pm
One thing about the mando was that I wound up having to press the frets in with the same block I used to mill the board. Pretty easy with a single radius. Turns out I felt pretty good about pressing frets. I can do a great job with the hammer, but am willing to believe that a press may do an even better job and leave more fret after dressing.
Is there a press system for a compound radius out there?
PostPosted: Thu May 16, 2019 2:45 pm
https://birkonium.com/product/ultimate-fretting-caul-set/
or I just made up my own flexible caul with UHMWP and a brass strip.
These users thanked the author Colin North for the post: dpetrzelka (Thu May 16, 2019 5:45 pm)
PostPosted: Thu May 16, 2019 5:34 pm
Stew Mac sells fret caul inserts. I bought a couple a few years back and promptly lost them. oops_sign
https://www.stewmac.com/Luthier_Tools/T ... serts.html
PostPosted: Thu May 16, 2019 5:35 pm
Pics Colin?
PostPosted: Thu May 16, 2019 5:52 pm
First name: Trevor
Last Name: Gore
City: Sydney
Check out Section 15.6.3 in the white book. Quite straight forward to make your own. The caul in Fig Fig 15.21 can be used in a press as well as a clamp.
http://www.goreguitars.com.au
PostPosted: Thu May 16, 2019 6:06 pm
Clearly I need to reread that book...
PostPosted: Thu May 16, 2019 6:08 pm
Here you go. UHMWP about 8mm x 15mm curved to 10" on bottom, groove cut for fret.
Used for 12 - 18" radius frets.
Originally had brass strip screwed to bottom, but I removed and cut off the ends.
PostPosted: Thu May 16, 2019 6:11 pm
Me too, don't remember a compound radius fret press.
PostPosted: Thu May 16, 2019 6:34 pm
Thanks Colin and Trevor...
PostPosted: Thu May 16, 2019 7:42 pm
Colin, how does the plastic caul work? Does it flex?
PostPosted: Fri May 17, 2019 4:13 am
Yes. It's not absolutely perfect, but does a good job if you work it across the frets.
Users browsing this forum: doncaparker and 30 guests
