It is currently Sat Jul 19, 2025 10:04 pm
 Post subject: Plunge Trimmers POLL
PostPosted: Thu May 30, 2019 7:33 am
Last Name: Ensor
City: Springfield
State: Missouri
Which of these plunge trimmers do you own/would you buy?:
Bosch
Dewalt
Porter Cable
Makita
http://elevatelutherie.com
http://ensorguitars.com
 Post subject: Re: Plunge Trimmers POLL
PostPosted: Thu May 30, 2019 7:42 am
First name: Ernest
Last Name: Kleinman
City: Guthrie
Zip/Postal Code: 73044
DEwalt with retrofitted precise bits collet
PostPosted: Thu May 30, 2019 8:26 am
For small routers I usually "plunge" manually. I like that the Makita base has depth stops that you can set, but I suspect most would go for the Dewalt plunge base, which appears to have the advantage of being used with PC trimmers also.
PostPosted: Thu May 30, 2019 8:28 am
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
Chris--
The one I currently use is a Bosch Colt in a Bishop Cochran plunge base. I know the Colt is not the current favorite here on the OLF, but the functionality of the Bishop Cochran base is the star of this show. I can do big things and delicate things with it.
PostPosted: Thu May 30, 2019 8:29 am
City: U.P.
Dewalt. Plunge assembly is nice and tight and seemed more rigid than others I tried at store. Nice size, power to weight ratio. Easier handling than big routers. I use it for neck joints and slot heads.
Smaller trim routers Colt and Ridgid for bindings. Foredom and StuMac base for rosettes and inlay.
Brian R, Wood Mechanic
N8ZED
PostPosted: Thu May 30, 2019 8:58 am
I have a Makita and plunge base (+ a few trim bases for various jigs) which I like a lot. Perfect for my saddle slotting jig.
Would buy the DeWalt for my binding jig for the depth adjustment, but it's a tad expensive in UK so I'm sticking with my Bosch.
PostPosted: Thu May 30, 2019 9:16 am
We have the DeWalt at work and it is nice but I have the Colt at home and have no complaints.
Burton
Brookline, MA.
PostPosted: Thu May 30, 2019 9:24 am
What do you want to use it for?
PostPosted: Thu May 30, 2019 10:35 am
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
All of my generic plunge bases are on larger routers. I have a PC 310 in a bishop Cochran base.
PostPosted: Thu May 30, 2019 10:58 am
First name: Brad
Last Name: Combs
Edited...
Sorry, didn’t catch the plunge part... I use a DeWalt with a plunge base.
PostPosted: Thu May 30, 2019 11:10 am
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
Zip/Postal Code: J2M 1R5
+1
PostPosted: Thu May 30, 2019 12:04 pm
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
Both DeWalt and Porter Cable are made by Black and Decker. The two pictures above show they are identical except for the color scheme. Are they like a Chevy and a Buick - the same except for minor differences?? Do they have the same innards? Cost the same??
Ed
PostPosted: Thu May 30, 2019 1:10 pm
Last Name: Colbert
City: Anacortes
I’ve got both the Makita and the Bosch. To be honest I have yet to try out the Makita plunge base. I find the motion on the Bosch to be stiff and jerky no matter how you hold it. Lube doesn’t solve the issue either. I may be able to reduce the tension on the counter spring to solve the issue. Once my new shop is set up I’ll give the Makita a go and see if I like it any better. I have a separate router set up for each operation. I hate changing bits in the middle of a build. That means I have a dozen or so of these trim routers.
Why?
M
PostPosted: Thu May 30, 2019 3:55 pm
Last Name: Sollod
Dewalt
www.swiftcreekguitars.com
PostPosted: Thu May 30, 2019 5:40 pm
First name: Aaron
I got a used DeWalt. Then another, and added a few bases.
I use it for binding in a jig, and plunge rosettes/soundholes, bridge slots and M&T neck joints.
Replaced my lam trimmer, and keeps my router in the table. I like the soft start, led lights, quiet, and mostly the vertical adjustment.
Haven't tried the others.
PostPosted: Thu May 30, 2019 5:44 pm
Last Name: Gramann
City: Fredericksburg
State: VA
Zip/Postal Code: 22408
I have the Makita. I am very happy with it.
PostPosted: Thu May 30, 2019 7:07 pm
Online
First name: Mark
Last Name: McLean
City: Sydney
State: New South Wales
Zip/Postal Code: 2145
I have the Makita too. Mainly used for binding channels, and bridge milling. I like it, but I can’t compare with the others as I haven’t used them. You going to make us some jigs for them Chris? I am seriously thinking of buying the Bishop Cochrane base. Would love to see an Elevate one.........
PostPosted: Thu May 30, 2019 9:32 pm
Last Name: Ensor
City: Springfield
State: Missouri
I may have a prototype in the works for cutting circle like shapes... ;)
PostPosted: Thu May 30, 2019 10:14 pm
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Zip/Postal Code: 43085
Sorry if this is a hijack, but...
I was looking at a Bishop Cochran base for my Colt but got sticker shock. I know you only cry once when you buy quality.
Any insights anyone can share to enable, I mean help others make an informed decision?
Kevin Looker
I'm not a luthier.
PostPosted: Thu May 30, 2019 10:37 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
Kevin Looker
When I took my guitar building course some years ago, I kept an eye out for what tools were must haves for setting up my own shop. I used a Bishop Cochran base in that class for my rosette and it was obvious to me that it belonged on my list. I love mine and use it for rosettes, saddle slots, and backstrip channels. Its adjustments are super precise to within a gnats's eyelash and solid with no free play. Every one of my rosettes is different so having the fine and accurate adjustment is really nice. It's one of the few tools I've splurged on and it was totally worth it for me. Ok, my enabling for today is done.
PostPosted: Thu May 30, 2019 11:01 pm
Last Name: Parker
City: Charleston
Everything Jay said, I echo. I will confess, though: I was lucky enough to buy my Bishop Cochran base used. Stick around the OLF long enough, and you can benefit from someone else getting fed up with this hobby. Yes, I’m a vulture.
It really is a great piece of gear. I can do rosettes, saddle slots, inlay, you name it.
PostPosted: Thu May 30, 2019 11:50 pm
Same as the others regarding the Bishop, but I use it for other work as well. If you put the close work fence on, it's really nice for cutting truss rod channels, etc. I used it as a basic circle cutter to make custom driver mounts for the car... It's just a really nice plunge base.
It's weight minimizes vibration, fit minimizes slop in adjustments, and the adjustments themselves are extremely fine.
My only concern with the investment is for future when my PC 310 goes kaput.
It isn't magical, but it's definitely luxurious.
PostPosted: Fri May 31, 2019 12:36 am
Online
First name: Mark
Last Name: McLean
City: Sydney
Chris, if you are designing something I have an extra consideration for you. I like to do some oval/eliptical soundholes and rosettes. To do this you adapt a circle cutting jig (I currently use the StewMac one with a dremmel) to have 2 pivot points, and you run it in a X-shaped track. When considering the Bishop Cochrane base I wondered if it could be set up with two of those adjustable bars that bear the pivot pin. For an oval guitar rosette and sound hole you want to place the two pivot pins around 20mm apart (at about 40 and 60mm, respectively, from the bit). Here is a short tute on how I have been doing it.
http://www.anzlf.com/viewtopic.php?f=5& ... 62c09bb0da
But the Dremmel is definitely an underpowered tool for this job. I tried cutting an oval rosette ring from a hardwood burl a few days ago and got a lousy result. I need a new setup and I would love something to use with my Makita trimmer (or would buy another trimmer to suit, if needed). I know oval-cutting is not something in high demand, but it could be an add-on feature.
PostPosted: Fri May 31, 2019 7:00 am
For cutting ovals another approach may be to use something like the Creative Memories system that scrapbookers use. They use plastic ovals with tracks that "bugs" ride in (an idea similar to the old LeRoy sets I used as a draftsman). The bugs have blades that will cut 1/16th inch deep - about the right depth for a rosette channel. Once the boundaries are scribed, excavating the interior could be done with a trimmer and chisel.
www.youtube.com/watch?v=NBBDwHTK8qU
PostPosted: Fri May 31, 2019 8:02 pm
Online
First name: Mark
Last Name: McLean
City: Sydney
Thanks for that tip Clay. Looks like a viable alternative method. But not as much fun if there are no power tools involved!
Users browsing this forum: Mark Mc and 29 guests
