It is currently Sat Apr 25, 2026 1:44 pm
PostPosted: Sun Jul 21, 2019 2:30 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
So that seller, Hongyin Music sells some guitar tonewood and stuff at a good price (though I would not break CITES rules, China to Taiwan may be considered "domestic" in their eyes but def. not China to USA). I notice they sell truss rods, similar to the low profile truss rods sold at Stewmac (and it appears to be the same truss rod used in Martins these days), it is sold at around 2.50 each rather than around 10 dollars each Stewmac sells them for.
I have bought 6 Stewmac truss rods, mainly because if they break, they are very hard to fix. But I wonder has anyone tried those Chinese copy? Are they any good, or do they break easily? I like to hear from some people before I take a chance on it.
Typhoon Guitars
PostPosted: Sun Jul 21, 2019 5:02 pm
First name: David
City: Napa
Zip/Postal Code: 94558
The bulk of there products are kind of sub standard. I did buy some bone nuts that have worked out pretty well for $1.50 each.
PostPosted: Sun Jul 21, 2019 5:08 pm
May well be worth $10 to buy 4 and test them to destruction.
PostPosted: Mon Jul 22, 2019 7:28 am
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
Even doing that, my worry would be consistency batch to batch. I think the biggest benefit from buying from stewmac or other trusted source is the increased confidence that you should always know what you are getting. I appreciate paying less when possible but for something like a truss rod, I would want a little bit more assurance I am getting a quality product. With some things it can be readily observable if the discount/knock off is substandard. With truss rods you might not know how the metal and welds stack up.
I know in Tai's case, shipping would be a factor that puts an even bigger disparity between the two costs though.
Bryan Bear PMoMC
PostPosted: Mon Jul 22, 2019 7:40 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
Yea like I said I still spend the money on Stewmac truss rods because I know they stand behind it. Maybe until the day that I can competently TIG weld (and can afford a TIG rig) then I may consider making my own. It's harder to mess up on stuff like wood because it only takes time if it were not properly dried (if at all). But broken truss rod is a major headache.
Typhoon Guitars
PostPosted: Mon Jul 22, 2019 3:27 pm
There's other people that offer well made truss rods besides Stewmac. LMII I know has a double action rod that seems to be good quality.
Regarding the Aliexpress ones, several times I've removed truss rods from cheap imports just for the heck of it. The quality of them vs. the ones you can buy from good suppliers is pretty apparent. The cheap ones came from guitars like Eastmans, Blueridge and they were pretty low quality. The welds were goopy and 2 of them had a fair amount of wane to them. If the aliexpress ones are the same as they're putting in those guitars I'd be cautious.
PostPosted: Tue Jul 23, 2019 6:44 am
Last Name: Lee
Country: Wales U.K.
On what basis do you feel able to make that sweeping statement? I have used both Chinese and "non sub standard" rods and, by appearance alone, the Chinese rods were better made.
PostPosted: Tue Jul 23, 2019 6:50 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
So what is your experience with Chinese truss rods? Are they properly welded? I'm looking at this one: https://www.aliexpress.com/item/3291101 ... 3c00iuCjk3
It looks similar to Stewmac's low profile hot rod truss rod, only that it's 1/5th the price, and no tariff, low shipping, no hassle with CITES (does not apply to truss rods unless steel becomes endangered, but they also sell tone woods as well)
Typhoon Guitars
PostPosted: Tue Jul 23, 2019 7:17 am
+1
The company appears to be legit, and not some drop shipper that doesn't have to worry about negative feed back, so they might be worth looking at. Where does Stew Mac have their rods made? Didn't people have some problems with their Hot Rod truss rods?
Being a production item I doubt they would be the same quality as Blanchard's rods, but they may be as good as the run of the mill offerings.
PostPosted: Tue Jul 23, 2019 7:23 am
these are surprising decent
The construction is not welded on the threaded rod . I have tested them and found that they work well
PostPosted: Tue Jul 23, 2019 8:12 am
That's incredibly cheap. If they do actually pass the muster. In looking for cheaper alternatives I found the Bitter Root truss rods to be good. I think they still came in about $10 bucks per rod but they had much more varieties and sizes to choose from. My guess is that they are made in China too.
As was mentioned that is so cheap it can't hurt to just buy a few and check them over real good.
PostPosted: Tue Jul 23, 2019 8:44 am
I'm buying 2 way rods from reputable luthier suppliers in UK costing around $6.50, and much prefer then to the hot rods.
I'm sure they're not made here but imported from china, many sizes in small increments.
The welds are a little untidy, and need a light dress to fit in the channels, but I've tested and used about 10.
So far, so good.
PostPosted: Tue Jul 23, 2019 6:51 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
Boy, the price of the LMI double action truss rod has gone up quite a lot. I've bought them before for $23.65. The current price is $32.27. The Martin double action truss rod is still just $13.00 from Martin.
PostPosted: Tue Jul 23, 2019 6:54 pm
First name: Jay
City: Bothell
State: Washington
Clay S. wrote:
If I remember correctly, the height of the original Hot Rod truss rods was seen as the potential cause of blow outs on the back of thin necks. That wouldn't apply to the low profile Hot Rods.
PostPosted: Tue Jul 23, 2019 9:05 pm
J De Rocher wrote:
Yep, that happened on one of my acoustics using the original Hot Rod. Lesson learned!
PostPosted: Tue Jul 23, 2019 9:40 pm
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Zip/Postal Code: 43085
I've never shopped for truss rods from Ali Express.
A very good friend of mine works for a large music retailer whose prime focus is on guitars, enough said.
He spends a lot of time in China and tells me that "they can make great quality stuff, but nobody wants that, everyone wants cheap."
I have no doubt that great quality anything can come out of China but ensuring the quality seems pretty fuzzy. There are always bean counters getting involved, trying to maximize profit. Who cares if 5 or 10% of the product is defective, they're still delivering 90-95% which seems awesome...
I'm not a luthier.
PostPosted: Wed Jul 24, 2019 7:37 am
Last Name: Lee
Country: Wales U.K.
Don't know about the rods you refer to. These are the ones I have been using. https://www.aliexpress.com/item/3287305 ... 34eeda5330
They are well made and I use them with confidence.
PostPosted: Wed Jul 24, 2019 12:15 pm
Awhile back I had an LMI two way break in a brand new guitar. I thought I had tested it but obviously not adequately. It was one of those with the gobby welds that had to be filed to fit.
Subsequent more aggressive testing of my remaining batch of seven or eight resulted in failure in 2/3.
I switched to the more expensive Blanchard rod and never looked back although I took apart a Martin rod and it looked fine. I would use it with confidence.
Truss rods are not a place to take chances on quality.
PostPosted: Wed Jul 24, 2019 5:19 pm
Martin rods. They are highly proven and work. "Martin style" is a highly subjective term. This post seemed to cover the details well.
https://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=51333&p=675958&hilit=truss+rod+martin#p675880
PostPosted: Wed Jul 24, 2019 5:27 pm
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
The StewMac low profile trussrods are very definitely NOT Martin or Martin-style rods.
PostPosted: Thu Jul 25, 2019 11:46 am
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
I got some thinking they were and didn't look closely at the pictures. . .
Bryan Bear PMoMC
PostPosted: Wed Jul 31, 2019 5:30 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I just ordered and received some truss rods from the Aliexpress seller.
It looks, feels, and operates almost EXACTLY the same as Stewmac low profile truss rod!
Apart from the different color of heat shrink tape used, they are exactly the same, same fit and finish, same weld, same (appears to me) weld quality. Red is Stewmac, black came from Aliexpress
I ordered them because I needed some electric guitar length truss rods, since I bought an electric guitar (bolt on neck, Strat style) with a severely twisted neck. So I will go ahead and make a new neck with some rock maple I have lying around.
Typhoon Guitars
These users thanked the author Tai Fu for the post: Clay S. (Wed Jul 31, 2019 6:52 am)
