It is currently Wed Apr 22, 2026 9:38 am
PostPosted: Tue Aug 27, 2019 6:44 am
hi,
i have fitted new frets to an old gibson Lg, the trouble is the truss rod is seized solid, the neck has relief in it already
how do i go about levelling the frets without a flat fretboard to work from
thanks
Sent from my SM-G960F using Tapatalk
PostPosted: Tue Aug 27, 2019 7:59 am
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
Before resorting to extraordinary measures, is the truss rod truly frozen?
- Penetrating oil on the nut? (corrosion products lock nut to threaded shaft)...give it time to work and avoid slopping oil all over the access cut. On your own guitars, a pinhead-size dot of anti-seize compound on the threads can avoid the issue.
- Heat truss rod nut with soldering iron (use a shield around the nut to avoid overheating adjacent lacquer work...soften glue in nut/threaded shaft interface)...try turning with appropriate wrench while still hot...if it turns hot, but turns less readily/not at all cold, there is likely either finish or glue stuck in the threads and nut. Also - avoid burning hand, and don't break the rod
- If all above does not work, is the customer better served with a truss rod replacement before the refret (this depends on the total relief locked into the neck)?
These users thanked the author Woodie G for the post: cablepuller1 (Tue Aug 27, 2019 10:41 am)
PostPosted: Tue Aug 27, 2019 8:07 am
You could seat the frets carefully, use a fret rocker to make adjustments where necessary, and use a short stone or sanding block to level the frets a few at a time, starting at the nut and working toward the bridge, and removing a minimum amount of material. Use a guitar string to measure progress periodically and make sure you are keeping the right amount of relief. Without a working truss rod you may not be able to fine tune the action, but if you can get it reasonably close without buzzing that would be better than snapping the truss rod.
Eventually you may be able to get the truss rod to work using PB Blaster or something similar. Sometimes heating the rod with a - clean - soldering iron can loosen things up.
These users thanked the author Clay S. for the post: cablepuller1 (Tue Aug 27, 2019 10:42 am)
PostPosted: Tue Aug 27, 2019 8:14 am
In my shop frozen truss rods get fixed before doing a refret, period. You are unlikely to get a decent action if you cannot level the frets with a level fretboard.
Edit: What I would do is one thing but just my opinion. On the other hand you can always do a compression refret.
These users thanked the author SteveSmith for the post: cablepuller1 (Tue Aug 27, 2019 10:42 am)
PostPosted: Tue Aug 27, 2019 8:15 am
I just use a short file for unruly necks. as long as the first few frets in front of any given fret is the same level then you are good to go.
But yeah, double check that the rod is truly stuck too.
These users thanked the author jfmckenna for the post: cablepuller1 (Tue Aug 27, 2019 10:42 am)
PostPosted: Tue Aug 27, 2019 9:05 am
I had a neck once that had carbon fiber rods inset in the neck - totally straight, no adjustment. I pulled the frets and planed some relief in, and refretted - paying particular attention when leveling the frets to remove the minimum. The guy is still playing it decades later.....
These users thanked the author Chris Pile for the post: cablepuller1 (Tue Aug 27, 2019 10:43 am)
PostPosted: Tue Aug 27, 2019 12:30 pm
First name: Gary
Last Name: Leddington
Make a thin-ish wooden sanding block with a truss rod in that you can adjust to match the relief in the neck? ?
Just an idea..
www.leddingtonguitars.com
These users thanked the author Fasterthanlight for the post: cablepuller1 (Tue Aug 27, 2019 12:56 pm)
PostPosted: Wed Aug 28, 2019 2:09 am
Best if you can free off/replace the truss rod of course.
Next possibility is a compression refret, and level the frets with 10lb of weights on the shoulders of the guitar. Stringing the guitar up will induce the needed relief.
But, I have successful levelled frets on a classical with no truss rod which had relief built in to the neck - used abrasive on a ~ 10" MDF 1/4" board which flexed to conform to the relief.
These users thanked the author Colin North for the post: cablepuller1 (Wed Aug 28, 2019 3:45 pm)
PostPosted: Wed Aug 28, 2019 5:31 am
I glue wet/dry sand paper on short wood blocks. and it just tracks over whatever relief you have. The length of the blocks is just long enough to span the three widest spaced frets, plus a little. For blocks, I use a bit of lathe or similar wood, so if you put a little pressure in the center, it can deform to the relief, but that might be overkill.
These users thanked the author wbergman for the post: cablepuller1 (Wed Aug 28, 2019 3:45 pm)
PostPosted: Wed Aug 28, 2019 9:00 am
One other point about loosening stuck nuts - after the penetrating oil has had time to work it is better to "wiggle" the nut in both directions in small amounts and as it frees up back it on and off much as you would cut threads with a die, rather than trying to unscrew it in one go. This may be common knowledge and I may be stating the obvious, but .... pizza
These users thanked the author Clay S. for the post: cablepuller1 (Wed Aug 28, 2019 3:45 pm)
PostPosted: Wed Aug 28, 2019 9:25 am
double post
PostPosted: Wed Aug 28, 2019 9:35 am
My classicals have carbon fiber in the neck with no truss rod. I have shape the relief into the fretboard, along with a slight twist, I use a short, flexible sanding block made from a piece of an old fret saw 1" x 3" and a fret rocker.
Just an idea..
That is a great idea!
These users thanked the author Pat Foster for the post: cablepuller1 (Wed Aug 28, 2019 3:46 pm)
PostPosted: Wed Aug 28, 2019 6:09 pm
First name: D
Last Name: S
I saw a feller use a truss rod with sandpaper on it.
He adjusted the rod to match the relief on a strung-up guitar, and leveled with strings on.
wah
Wah-wah-wah-wah
Wah
PostPosted: Thu Aug 29, 2019 1:48 pm
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
Your post made me think of an idea for an adjustable large radius guide or sanding block (for braces one way and bridge bottoms the other.
Glue a 2 wide inch strip of plexiglass or even a 4 mm thick strip of wood to a truss rod. The radius can be set by adjusting the sagitta of the arc.
