It is currently Mon Aug 04, 2025 11:46 am
 Post subject: Sterling Silver Inlays
PostPosted: Fri Sep 20, 2019 4:53 am
First name: Gary
Last Name: Leddington
Hi Folks....
I have a request from a client to make a guitar themed around the 'silver dollar' and as such we have talked about the possibility of various silver inlays about the guitar...
One idea is to have a ring of sterling silver in the rosette... a quick search turns up nothing, so i'm wondering is there a reason??
I'm envisioning a fairly standard rosette where the center ring is 'bwb, silver, bwb'. The silver being about 1mm in thickness. Can anybody foresee a problem with this? Silver is fairly soft to work so i would just level it flush and lacquer over as normal.... could it react with the lacquer (nitro), for example?
May be i'm missing something so i thought i'd just check with you good folks first?
Thanks.
G.
www.leddingtonguitars.com
PostPosted: Fri Sep 20, 2019 5:17 am
8 pages of results searching "silver inlay", maybe start there?
PostPosted: Fri Sep 20, 2019 6:01 am
First name: Gary
Hi Colin... just shot you a PM.
G.
PostPosted: Fri Sep 20, 2019 8:35 am
A possible concern might be lacquering over the silver wire. Silver tarnishes easily and nitrocellulose lacquer is somewhat permeable to air and moisture. The silver might tarnish under the finish and the finish would keep it from being repolished. Brass instruments use a special baked epoxy lacquer that is less permeable and allows the brass to hold its polish longer.
If you could leave the silver wire slightly proud of the lacquer (like cloisonne) it might allow it to be polished, but I don't know what other problems that might cause.
PostPosted: Fri Sep 20, 2019 11:09 am
First name: Roy
Last Name: Machin
City: Mexborough
State: South Yorkshire
Zip/Postal Code: S64 0HW
Country: United Kingdom
I have some limited experience of inlaying silver wire script in a couple of ebony head veneers. It worked well for me. The guitars were french polished but I finished the faces of the headstocks with brushed water based lacquer so as not to colour the silver. They have not tarnished in the three years since they were built.
I think that some Larrivee guitars have a silver border on the headstock but I`m unsure as to what finish they use.
When I was asked to do the silver inlay I spent some time looking at the options and one of them was to use argentium silver; this is supposedly tarnish free and easy to work. However I could not source any square wire in the gauge that I needed.
These users thanked the author stumblin for the post: Clay S. (Fri Sep 20, 2019 6:28 pm)
PostPosted: Fri Sep 20, 2019 11:49 am
Lots of larrivees with silver border haedstock. Both nitro and poly...
These users thanked the author meddlingfool for the post: Clay S. (Fri Sep 20, 2019 6:28 pm)
PostPosted: Fri Sep 20, 2019 8:35 pm
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
I did my logo along with side dots in sterling silver and put shellac over them 7 years ago - still shiny
Ed
PostPosted: Sat Sep 21, 2019 10:10 am
Aluminum banding looks like silver but it does not tarnish. Cheaper too.
PostPosted: Sun Sep 22, 2019 4:33 am
First name: Gary
Interesting ideas folks... thanks alot.
PostPosted: Mon Sep 30, 2019 9:42 am
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
What grit would you prepare a silver or aluminum inlay to. I imagine really fine would be needed to make it look shiny and polished but then would there be issues with finish sticking to it?
Bryan Bear PMoMC
PostPosted: Mon Sep 30, 2019 5:33 pm
I would sand to at least 600 grit but it would probably look better the higher you go. Don't worry about going too fine for finish. They apply lacquer to brass instruments after buffing to a high gloss. The main thing is to keep the metal's surface clean and free of anything oily before apply finish.
These users thanked the author Barry Daniels for the post: Bryan Bear (Mon Sep 30, 2019 7:39 pm)
PostPosted: Tue Oct 01, 2019 4:11 am
First name: Roy
Last Name: Machin
City: Mexborough
I`ve used fine Micromesh Up to 12000. No problems with finish adhesion.
PostPosted: Wed Oct 02, 2019 11:24 pm
First name: jim
Last Name: mccarthy
City: ojai
State: ca
Zip/Postal Code: 93023
I inlaid bits of silver into a piece of furniture 30 years ago and it still looks like I remember it did day one. The finish was nitrocellulose sealer and lacquer.
