It is currently Tue Aug 19, 2025 6:00 pm
PostPosted: Wed Oct 16, 2019 6:58 am
First name: Gustavo Adolfo
Last Name: Costa
City: São Paulo
State: SP
Zip/Postal Code: 04524-020
Country: Brasil
Keep studiying on how to built the SG i've already commented in other posts here in the forum. I've been trying to find color tones that are close to the mockups I've projected on Photoshop, So i tried several variations between Mahogany (Mogno in portuguese) and Walnut (Nogueira). So, when I found the color tones I enjoyed the most, I started experimenting with finishes like these 3: Birchwood's Tru-Oil, and two brazilian products: Olio Brasile (which is similar to tru-oil, but I found it better) and just a plant-based beeswax called Cera Artifice Supreme. What do you guys think?
Now, my question: I LOVED THE BEESWAX FINISHING. CAN I USE IT ONLY? ARE THERE ANY DOWNSIDES, LIKE STAINS IN MY SHIRT WHEN I PLAY, FOR INSTANCE? :D
Thanks!
PostPosted: Wed Oct 16, 2019 7:07 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
You can use wax as a finish, My partner and I did in the 80's when I made my first attempt at lutherie.
Drawbacks:
One way street, no other finish will ever stick after you do this so if you do not like it you are stuck with it.
Does not seal down the wood so splinters and chipping can be a problem with certain woods.
Can have a tacky feel and be grabby against your shirt
Can allow sweat etc through so the wood underneath discolors. Especially at body contact points and certain woods are more susceptible.
Brian
PostPosted: Thu Oct 17, 2019 9:47 am
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
Brian
I have had success with shellac sticking over 2 coats of Johnson's paste wax. It was not a full finish, just two coats.
Ed
PostPosted: Mon Oct 21, 2019 12:11 pm
First name: jim
Last Name: mccarthy
City: ojai
State: ca
Zip/Postal Code: 93023
Wax is a temporary "finish", in that the sheen and protection is provides oxidizes fairly quickly.
PostPosted: Tue Oct 22, 2019 6:03 am
Last Name: Howard
City: Magnolia
State: Delaware
Ruby50 wrote:
Brian
Ed
Shellac will stick to wax, yes. But the wax becomes a bridge.... anytime you have a harder finish over a softer one you will eventually have issues. This is due to the softer material moving under the harder film and causing most typically crazing and flaking of the top coat.
Brian
Users browsing this forum: Bing [Bot], Chris Ide and 20 guests
