It is currently Fri Apr 24, 2026 11:13 am
PostPosted: Sat Oct 26, 2019 1:52 pm
So frustrated with this, I have had good results in the past with these rattlecans (nitrocellulose) but getting horrible blushing now and the bracing is showing through the front !!!!!
Temperature is 15°C and humidity is around 60%, sprayed like this before and been fine. Any ideas?
Thanks ImageImageImage
Sent from my SM-G960F using Tapatalk
PostPosted: Sat Oct 26, 2019 2:39 pm
Humidity.
I’ve had that issue.
In my case it disappeared on the next coat
These users thanked the author SnowManSnow for the post: cablepuller1 (Sat Oct 26, 2019 2:40 pm)
PostPosted: Sat Oct 26, 2019 2:40 pm
SnowManSnow wrote:
Humidity.
Did you sand the coat of first ?
PostPosted: Sat Oct 26, 2019 2:54 pm
cablepuller1 wrote:
SnowManSnow wrote:
Humidity.
I just kept on w my schedule.
I’m sure someone will have more help than I can offer
These users thanked the author SnowManSnow for the post: cablepuller1 (Sun Oct 27, 2019 6:28 am)
PostPosted: Sat Oct 26, 2019 3:13 pm
what brand? I don't use anything but Minwax anymore
PostPosted: Sat Oct 26, 2019 3:14 pm
what was your prep
sealer
filler
stain
water based
etc
PostPosted: Sat Oct 26, 2019 3:54 pm
bluescreek wrote:
what was your prep
sealer
filler
stain
water based
etc
Water based stain, zpoxy fill, tried Nitrocellulose sanding sealer but it also blushed and I had to sand it off, then sprayed with nitrocellulose satin
PostPosted: Sat Oct 26, 2019 3:56 pm
This stuff, highly recommended and used before with little to no problems Image
PostPosted: Sat Oct 26, 2019 4:53 pm
Yes, humidity. I never sprayed when it was over 50%. With rattlecans, you can't add retarder or anything to compensate.
PostPosted: Sat Oct 26, 2019 5:36 pm
City: Tyler
Rub it with a soft t shirt type cloth. A little warming can go a long way. In a humid environment you need to apply lighter coats. And relax, there are ways to deal with blush. I’ve never had to sand it off.
These users thanked the author Glen H for the post: cablepuller1 (Sat Oct 26, 2019 5:37 pm)
PostPosted: Sat Oct 26, 2019 5:37 pm
Cool, never tried that
PostPosted: Sun Oct 27, 2019 4:52 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
Oh my.... So much going on here and unfortunately little to do about it since we are rattle cans... If we had a gun we could adjust things. But we don't so we are here.
Your spray pattern needs to be tighter, more overlap. Your coats are also very uneven with the blushing at the thicker areas. Most of this could have been avoided with better technique as your environmentals look fine for lacquer.
What to do now? well if you can find a spray can of retarder you can use that to re-wet and let the moisture out of the coating. That or sand it off and try again.
Brian
These users thanked the author B. Howard for the post: cablepuller1 (Sun Oct 27, 2019 6:24 am)
PostPosted: Sun Oct 27, 2019 6:20 am
Humidity must be controlled . You may have a bad can , this stuff does spoil.
I stopped using most of the rattle cans , but I did find Minwax works well. I use it for touch ups for and I have done an few posts ok kgf
and showed my process. Unlike a sprayer you don't have a lot of adjustment so you have to work with the can. I lay the surface I want to spray flat so I can spray a nice coat. Blush usually comes out. I have used ever clear and noblush from big A auto.
Wipe this off with thinner or acetone. You also want sealer between your filler
These users thanked the author bluescreek for the post: cablepuller1 (Sun Oct 27, 2019 6:25 am)
PostPosted: Sun Oct 27, 2019 6:27 am
Thanks guys, will sand off I think.
Can I use shellac as a sanding sealer under the nitrocellulose as had bad blushing with the nitro sealer as well
PostPosted: Sun Oct 27, 2019 6:30 am
yes I use Zinser transparent clear
PostPosted: Sun Oct 27, 2019 9:45 am
Spray another light coat, while the humidity is low, and the blushing will disappear.
These users thanked the author guitarjtb for the post: cablepuller1 (Sun Oct 27, 2019 11:03 am)
PostPosted: Mon Oct 28, 2019 7:19 am
Last Name: Howard
City: Magnolia
State: Delaware
Ah... The possibility exists that this is not all just typical moisture induced blush. And based on temp and RH given by the OP there should not have really been much blush. The possibility exists that what you are seeing is actually refractory paste used to make the finish satin that was not thoroughly mixed into suspension before spraying. These agents are thick and known to bve tough to mix in properly especially at lower gloss numbers. Rattle cans are even harder to mix up and if that can sat in inventory for a year it may take 40 minutes or more of shaking it to mix it properly.....
Brian
These users thanked the author B. Howard for the post: cablepuller1 (Mon Oct 28, 2019 7:48 am)
PostPosted: Mon Oct 28, 2019 9:18 am
I think the fact that the blushing mirrors the bracing patterns on the top and back indicates that this is moisture related blushing. Stearate in the lacquer would not do that, but would make more random patterns.
These users thanked the author Barry Daniels for the post: cablepuller1 (Mon Oct 28, 2019 1:19 pm)
PostPosted: Mon Oct 28, 2019 1:30 pm
I have used Mohawk & Behlens Blush Eraser for many years with great results. Just the lightest spray mist over the lacquer will completely remove the blush. It works best when the lacquer is fresh but also works when the lacquer is dry. I buy it from Stew Mac.
https://www.stewmac.com/Materials_and_S ... raser.html
Mike Franks
www.mjfranksguitars.com
These users thanked the author Mike Franks for the post: cablepuller1 (Mon Oct 28, 2019 1:34 pm)
PostPosted: Mon Oct 28, 2019 7:58 pm
City: Tyler
Sometimes I just spray lacquer thinner on it. Light mist usually clears mine up. Normally another coat does the trick.
PostPosted: Tue Oct 29, 2019 7:35 am
Last Name: Howard
City: Magnolia
State: Delaware
So the thinner sections of wood had more moisture in them? I doubt that. What I suspect is that the instrument was sanded with a RO sander and the spots over the braces were scuffed through the sealer which allowed the lacquer to absorb in those areas and that may have affected the flattening paste and how it aligned in the coating as it dried. The stuff behaves much like a fine metallic in suspension and though you cannot see it it flows around just like a metallic does as it dries.
That brace shadow is why I never sand an acoustic instrument with a RO sander.... guitars are designed to vibrate freely and trying to sand them while they vibrate at at 30-60hz..... You always sand thin over the braces because of this.
Brian
These users thanked the author B. Howard for the post (total 2): Kbore (Sat Jul 25, 2020 5:58 pm) • Michaeldc (Tue Oct 29, 2019 7:58 am)
PostPosted: Tue Oct 29, 2019 8:18 am
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
That's intriguing! Do you think the mechanism of injury is that the braced spots on the top provide more resistance to deflection, while the unbraced spots vibrate away from the sander? I am not disagreeing with you (I have no basis for disagreeing). I'm just trying to get a sense of how the problem happens.
PostPosted: Tue Oct 29, 2019 8:52 am
This theory seems like a stretch. I have never seen this thinning issue from an RO sander and I use mine on guitars all the time.
Edit 1: The reflection of the braces is more likely due to the thermal mass of the bracing which slows down cooling and moisture condensation.
Edit 2: I added that last edit before I read Clay's post. You can see this thermal mass effect in windows and other areas where condensation occurs.
Edit 3: The overthinning of the top above braces can be minimized by using fresh sandpaper.
Last edited by Barry Daniels on Tue Oct 29, 2019 10:12 am, edited 2 times in total.
PostPosted: Tue Oct 29, 2019 9:02 am
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
I have seen this effect from sanding. I was doing a WRC top and got epoxy on the top while I was doing the pore fill. I decided to try a wash coat of thinned epoxy on the top to even things out. That was another mistake since it came out blotchy. I decided to try to sand all of it off and risk over thinning the top. I didn't use a power sander just a rubber block and (in retrospect) too much pressure to try to speed up the process. It didn't' take long for me to notice that the top above the braces was sanded through and the open areas much less so. I suspect this has happened to me before but I never noticed because I usually don't sand once the finishing starts (french polish) but it really taught me a lesson.
The guitar ended up looking strange in certain light/angles but sounds good. It was for me so not a huge deal.
Bryan Bear PMoMC
PostPosted: Tue Oct 29, 2019 10:05 am
When I have had that happen I assumed it was because there was a temperature difference between the air inside the box and the air outside the box ("spraying" also cools the air) causing some condensation. The thicker places where the braces are glued lessen the reaction to the dissimilar temperatures. I found immediately moving the guitar body to a warm environment and placing it under hot lights eliminated the blushing. Mohawk "no blush" (butyl cellosolve in a rattle can) would be a handy thing to have if you are doing rattle can finishes (Buying a small compressor and a cheap jamb gun would be a better option in the "short" long run).
These users thanked the author Clay S. for the post: cablepuller1 (Tue Oct 29, 2019 3:17 pm)
Users browsing this forum: Bing [Bot], Melt in the Sun and 233 guests
