It is currently Tue Jul 22, 2025 6:42 pm
Post new topic Reply to topic  [ 49 posts ]  Go to page Previous  1, 2
PostPosted: Thu Oct 31, 2019 3:00 pm
$7 bucks a strip, that's $28 bucks for a normal binding scheme:
https://www.rothkoandfrost.com/inlay-c3 ... B3%5D=1877
PostPosted: Thu Oct 31, 2019 3:43 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
1,400 mm (55") seems line a strange length to sell these in. That is not quite enough for doing both sides of a guitar but too long for one side.
Bryan Bear PMoMC
PostPosted: Thu Oct 31, 2019 5:26 pm
Leftovers - Another good reason to build Ukes! laughing6-hehe
They may be cutting the strips off a sheet that is 55 inches wide, rather than a roll that is 300 feet long.
PostPosted: Thu Oct 31, 2019 5:49 pm
First name: Carl
Last Name: Dickinson
City: Forest Ranch
Zip/Postal Code: 95942
I recently bought 3 Pcs Tortoise Shell Celluloid Guitar 1650 x 6 x 1.5mm Binding Purfling Strip on eBay for $7.59 w/ free shipping. the vendor was "friendstore1682010". Came fairly quickly considering it was from china and no hazmat fee.
PostPosted: Thu Oct 31, 2019 10:58 pm
LOL laugh all you want, they come in different sizes, just ask.... Just tryin' to help a brother out. I don't use plastic for the most part but was happy to find a vendor when I needed it. So it goes.
PostPosted: Fri Nov 01, 2019 5:59 am
plastic is more protective and when done right is fine. I have seen martins that are 100 yrs old and the plastic is still solid.
Often it is technique and using any wood glue on plastic is asking for a problem. I use Duco Cement havn't had an issue in 20 yrs of building
These users thanked the author bluescreek for the post: Pmaj7 (Fri Nov 01, 2019 8:03 am)
PostPosted: Fri Nov 01, 2019 7:23 am
I certainly wasn't laughing at you, John, the laughter was because I often find a reason to use "offcuts" of materials that prove to be an economical solution to sourcing materials for other instruments. If a vendor sells you 55 inches of material for less money than one who sells you 3 ft of the same material is that a problem? Not generally - unless it's toxic waste! :lol: It's always good to find alternate sources of materials, especially those that sell for a little less.
PostPosted: Fri Nov 01, 2019 8:16 am
The binding scheme I use on this model has 8 plies of .020 black and they only are available in 2-ply so it takes 16 strips just to do the top and back not counting the outside binding...…..
then I glue another 4 pieces for the side purfling-so you see how it adds up.
PostPosted: Fri Nov 01, 2019 11:25 am
First name: Carl
City: Forest Ranch
The ebay store I referenced above has many colors of abs too including black even cheaper in large quantities.
PostPosted: Fri Nov 01, 2019 11:53 am
Yeah that's beautiful work you do there. I think I cried a bit seeing that guitar sawn in half but it's cool to see the cross section of that too. The black doesn't have to be HASMAT celluloid though does it?
PostPosted: Fri Nov 01, 2019 12:28 pm
No, it doesn't but the problem is I don't want to deal with individual.020 strips so the only lams. that are available are either 4 ply b/w/b/w ABS or 2 ply ivoroid/black celluloid.....
PostPosted: Fri Nov 01, 2019 12:32 pm
Most suppliers sell the 1.5mm strips which equate to about .060.
I only use .090 for the binding which is much harder to obtain.
PostPosted: Fri Nov 01, 2019 4:36 pm
Edgeco has .020 PVC available in 600 ft X 15/16ths inch rolls if you could figure out a way to laminate it without it becoming too tedious.
PostPosted: Sat Nov 02, 2019 7:35 pm
Last Name: Beaver
City: Lake Forest
Brad Goodman wrote:
Here’s an interesting thing....
It turns out I have a piece of an Archtop guitar I built 25 years ago so.
I used celluloid Ivoroid binding.
Great info Brad. These pictures tell me two things,
The first is celluloid bindings can be great. I've always leaned toward wood but now I think I should reconsider plastic.
The other is that side braces should extend plate to plate and not stop at the linning.
Joe Beaver
Maker of Sawdust
PostPosted: Sat Nov 02, 2019 8:46 pm
I am going to do a test......
I will rout a binding channel in a piece of wood and glue some binding in using different types of glue and see how they react to trying to break the bond....
So far the glues I am going to use will be:
Duco
LMI weld on 4784 ( blue and white tube)
LMI FCA (jar)
CA
Hide glue
Roo glue
Yellow glue-after wiping plastic with acetone
I will do one set with ABS, one with PVC and another set with Ivoroid
These users thanked the author Brad Goodman for the post: Pmaj7 (Sun Nov 03, 2019 10:47 am)
PostPosted: Sat Nov 02, 2019 8:50 pm
This picture tells me one thing... DON'T drop your guitar on a cement floor from a height of 8 feet........
PostPosted: Sat Nov 02, 2019 10:26 pm
A short article that doesn't give up much information on 50's Gibson plastics.
https://www.themusiczoo.com/blogs/news/ ... de-and-out
PostPosted: Sun Nov 03, 2019 7:40 am
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
Prep of the binding will be important...Bolteron in particular needs cleaning and toothing with a 3M non-woven maroon abrasive pad if used with glues that are not hot enough solvent-wise to bite into the material (e.g., Duco). FWIW, the acetone wiping trick with Titebond works well with celluloid, but you'll definitely need very good prep with ABS, PVC, and alloys of those two.
I'm not sure the problem is short term so much as long term (5-10 years) on glues like Duco on Bolteron, but I'll be interested to see how things turn out.
- Beth Brower
These users thanked the author Woodie G for the post: Pmaj7 (Sun Nov 03, 2019 10:55 am)
PostPosted: Sun Nov 03, 2019 10:24 am
I always run plastic binding over a 100 grit piece of sandpaper stuck down to a marble tile to give it some tooth. Especially when using CA. This definitely helps adhesion.
Brad, I am really interested in hearing the results of your testing.
PostPosted: Sun Nov 03, 2019 11:50 am
I have been building for over 20 years. A few years ago there was a lot of talk about using some of the wood glues to glue on plastic
RU
Rabit
Hide and Tite bond were mentioned
I had tried the HHG and tite bond.
the process was straightforward sand and glue. At first the results appeared promising so I made a guitar after testing. In 2 years I had to redo all the wood glued plastic binding for it came off clean as a whistle. So use a glue that is designed for the material you are working with. Binding will get bumped so know it has to work and be something you can rely on.
I tried CA one time. It really made clean up a bear and it also left glue marks under finish and I had to give that guitar away. I went back to good ole duco cement. After 20 years none came loose unless it was damaged and that showed signs of welding into the wood cells.
martin had a big issue with binding coming off and they have that fixed now. it seemed the glue they used was reformulated .
PostPosted: Sun Nov 03, 2019 12:35 pm
John, Please correct me if I am wrong, but 100 years ago wasn't hot hide glue the only glue that Martin was using at that time?
The other question I have- have you been using ABS or PVC or just celluloid?
PostPosted: Sun Nov 03, 2019 2:11 pm
Martin used acetone to glue on the celluloid binding not hide glue. before plastic Martin did use ivory that had hide glue.
PostPosted: Sun Nov 03, 2019 5:02 pm
I use Titebond to *fix loose bindings and I've never seen one come back though perhaps they took it to some other guy and gave me a bad review! But I think that works out ok becasue when binding gets loose it usually takes some fibers and residue with it and that's probably what the Titebond really sticks too.
PostPosted: Sun Nov 03, 2019 5:48 pm
as a martin repair shop we are told to use a specific glue from 3m. I have used CA on binding that was loosened but nor shrunk.
If it has shrunk I then loosen it to the joint and reglue.
These users thanked the author bluescreek for the post: jfmckenna (Sun Nov 03, 2019 5:55 pm)
Users browsing this forum: Bing [Bot] and 25 guests
