It is currently Mon Jul 21, 2025 7:45 am
PostPosted: Fri Nov 08, 2019 8:31 am
Last Name: Simmons
State: Ohio
Hi Everyone,
I applied a black colored grain filler on my acoustic prior to using sanding sealer.
Afterwards I put about 3 coats of sanding sealer on, and now I've noticed not all the grains were filled.
What's the best way to handle this? Should I sand back a bit/level sand, fill the grain again and then re-apply sanding sealer?
Can I just grainfill now without sanding back?
Thanks!
PostPosted: Fri Nov 08, 2019 11:29 am
First name: Blake
Last Name: Dyson
City: Hillsborough
Zip/Postal Code: 27278
You can go ahead and grain fill again if you want to. I fill after sealer. I guess it depends on your filler and sealer/finish. I don't think you want to sand before filling if you're doing it after sealer, the filler will go into your sanding scratches and I don't think you want that.
PostPosted: Fri Nov 08, 2019 2:47 pm
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
Adhesion is important here.... need more info about products being used to give any usable advice.
Brian
These users thanked the author B. Howard for the post: broken1812 (Fri Nov 08, 2019 6:33 pm)
PostPosted: Fri Nov 08, 2019 6:33 pm
Last Name: Simmons
State: Ohio
I'm using all stewmac products. Colortone powdered grain filler and then Nitro Sanding Sealer.
PostPosted: Sun Nov 10, 2019 7:27 am
Last Name: Howard
City: Magnolia
State: Delaware
FWIW I have always found any water based grain fill to be problematic. It shrinks more than most other fillers when it dries so it requires usually twice the coats to get the same fill. Adhesion over sealers etc can also be difficult as most finish products are water resistant and will readily bead water without thorough prep. Stew Macs info seems to suggest this as well as they say to apply to wood..... not sealed surface.
To move on sand back so at least all the gloss is gone before applying more filler. Back to bare wood would likely be best. Alternately you could switch fill materials to something like an epoxy and finish the fill over what you have.
Brian
PostPosted: Mon Nov 11, 2019 12:57 am
If the - black - grain filler you originally used is not evenly distributed you may want to sand back completely to wood and reapply the filler. Too heavy of a build up of sanding sealer can affect adhesion of the top coat and clarity of the final finish, so be careful with that.
Users browsing this forum: Chris Ide and 36 guests
