It is currently Wed Jul 23, 2025 12:55 am
Post new topic Reply to topic  [ 48 posts ]  Go to page Previous  1, 2
PostPosted: Tue Nov 19, 2019 1:43 pm
meddlingfool wrote:
Yes, a sharp chisel is your pal in this. Setting it so that your fret plane kisses the top of your 3/8 bridge should be fine. Start by cutting about a half inch behind the FB, then an inch, then 1.5" etc, rather than trying to get the whole cut in one go. Hope that makes sense. Then floss as needed to clean up the joint. Try to be very careful about removing the same amount of wood off each side so your centreline stays good.
It is much easier to bring a neck back. For that reason, I always set my necks about 1mm forward at rough fit. Then, right before I glue the neck on, I floss it to the exact angle, both perfecting the joint and the angle at the same time.
Mind you, I use a bolt on neck. If you're using a dovetail and have to change the anlke, then you have to mess around with shims to get it right as well...
Ed,
It is bolt on
Thanks for the clarification
Also, you don't need to remove much material to get the angle change you want, so go slow.
There is a way to calculate exactly how much to remove to get the change you want, but that knowledge is beyond me.
I imagine Woodie might be able to help in that regard...
PostPosted: Tue Nov 19, 2019 1:58 pm
I think I had found something at StewMac quite a while ago to help determine how much to remove. Check out Dan's video, I didn't look at it all but I think he deals with the same issue you have
https://www.stewmac.com/How-To/Trade_Secrets/Fixing_the_angle_of_an_acoustic_neck_joint.html
These users thanked the author SteveSmith for the post: SnowManSnow (Tue Nov 19, 2019 2:23 pm)
PostPosted: Tue Nov 19, 2019 2:23 pm
I talked to John earlier and he explained it. I wrote down the summary numbers :)
A post up there explains it too ^^
This may be a great guitar after all :)
PostPosted: Tue Nov 19, 2019 2:37 pm
It won't be even 1/32nd of an inch and you will need to taper that to zero at the heel cap. Is it a butt joint or M&T? If it's a butt and you have bolt holes in the face of the heel then be very careful using a chisel as you my tear out wood around the holes. Probably no big deal since hopefully no one will ever see it again but still.
PostPosted: Tue Nov 19, 2019 2:51 pm
When I do a butt joint, the inserts are recessed about 1/8”, and the face relieved by about 3/32” leaving only the edges touching..
PostPosted: Tue Nov 19, 2019 3:07 pm
mT joint.
Yes
I’m trying to mentalize (new word) how to get an accurate mark I can cut to
PostPosted: Tue Nov 19, 2019 3:32 pm
So with the MT joint then using the chisel angle it in so you remove wood closest to the tenon. You only need the outer 1/8th inch of the cheeks to be flush with the head block and sides anyway so it's ok if you screw up a bit. Then when you get to that 1/8th inch edge you start to be real careful. Then mount the neck and floss it with some good cloth like sand paper.
Slow and steady wins the race here.
PostPosted: Tue Nov 19, 2019 5:40 pm
First name: George
City: Seattle
And now a word about safety: no matter what, DO NOT try to hold the heel steady with your hand while trimming with a chisel. Always DO use a jig to secure the work piece.
That is all.
George :-)
These users thanked the author George L for the post (total 3): Pmaj7 (Thu Nov 21, 2019 2:01 am) • bcombs510 (Tue Nov 19, 2019 9:39 pm) • SnowManSnow (Tue Nov 19, 2019 8:51 pm)
PostPosted: Tue Nov 19, 2019 6:19 pm
FWIW, I don't mark it at all. Just a few careful cuts, check, repeat...
These users thanked the author meddlingfool for the post: SnowManSnow (Tue Nov 19, 2019 6:38 pm)
PostPosted: Tue Nov 19, 2019 6:39 pm
I got it to 3/8”:) from the top of the soundboard to the line over frets:)
Will that work?
These users thanked the author SnowManSnow for the post: Bri (Tue Nov 19, 2019 6:46 pm)
PostPosted: Tue Nov 19, 2019 8:51 pm
That is all.
I always clamp it in a vise
PostPosted: Tue Nov 19, 2019 8:52 pm
Number 15 is looking promising again ha.
I spent all day worried about that.
I appreciate all the help
PostPosted: Tue Nov 19, 2019 9:04 pm
Last Name: McDonald
City: Okanagan Centre
State: British Columbia
Zip/Postal Code: V4V2H6
That is all.
Don’t even think about showing that pic again!
Hope it all healed up good.
B
These users thanked the author Bri for the post: George L (Wed Nov 20, 2019 11:04 am)
PostPosted: Tue Nov 19, 2019 9:11 pm
First name: Carl
Last Name: Dickinson
City: Forest Ranch
Zip/Postal Code: 95942
Here's the formula as stated in Bill Cory's book on building martin kits.
Lay a straightedge on the frets.
"A" is the gap between the straightedge and the bridge crown(above or below).
"B" is the height of the neck heel, base to bottom of fretboard.
"C" is the length from the neck heel to the center of saddle slot.
(AXB) / C = X.
X is the amount to remove from the top or bottom of the neck heel tapering to "0" at the other end. Got it?
I've run a piece of tape from the objective to the opposite point to sorta define the line. :)
PostPosted: Tue Nov 19, 2019 9:17 pm
(A+B) / C = X.
So C is scale length
PostPosted: Tue Nov 19, 2019 9:58 pm
First name: Carl
City: Forest Ranch
Oops I wrote it wrong..... (A X B) / C = X. Corrected above.
No, C is the distance from the center of the saddle slot to where the neck contacts the body.
These users thanked the author CarlD for the post: SnowManSnow (Wed Nov 20, 2019 6:42 am)
PostPosted: Wed Nov 20, 2019 6:52 am
here is a tip that doesn't require math
since you have to remove wood from the upper part take a 1/32 shim place at the heel and just snug your bolt , measure , if you need more ad another shim. Once the neck is in position scribe a mark on both sides of the neck BINGO
PostPosted: Wed Nov 20, 2019 7:06 am
John I did get it fixed nicely to just under 3/8” at the saddle.
Thanks for the help yesterday
PostPosted: Wed Nov 20, 2019 7:29 am
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
Great to hear! As already mentioned, most acoustic 14 fretters will work out to about 1/3 * the needed change, or about 1/32" or a bit more.
This is another case of using similar right triangles...I always love when something I learned in grade school comes in handy (besides that whole sharing business and Billy Verner picks his nose and eats it). This is also one that can be done graphically on the bench top with a framing square, although it's a little more accurate to do the math, or just do as Mr. Hall suggested and use some shim stock or veneer to mock up the change.
I'm hoping the fretboard extension angle with the top worked out as well.
- Beth Brower
PostPosted: Wed Nov 20, 2019 8:24 am
Online
Last Name: Colbert
City: Anacortes
Bri wrote:
That is all.
B
+1
These users thanked the author Michaeldc for the post: George L (Wed Nov 20, 2019 11:05 am)
PostPosted: Wed Nov 20, 2019 8:55 am
Great tip using a shim.
Users browsing this forum: Michaeldc and 29 guests
