It is currently Fri Apr 24, 2026 11:19 am
PostPosted: Thu Feb 06, 2020 10:58 am
I've heard here before that klingspor makes pre-cut sanding belts for drum sanders. I've been searching but can only find bulk rolls, not precut lengths. I'm specifically looking for rolls for a Delta 18-36...any tips?
PostPosted: Thu Feb 06, 2020 11:12 am
Ed,
I don't know about Klingspor precut strips, but I've been using these https://woodworker.com/80-grit-readywra ... 32-587.asp
The Zirconia seems to last really well, much better than the aluminum Oxide in my experience.
These users thanked the author Jim Watts for the post (total 2): James Orr (Thu Feb 06, 2020 8:46 pm) • Pmaj7 (Thu Feb 06, 2020 12:01 pm)
PostPosted: Thu Feb 06, 2020 11:18 am
Last Name: McDonald
City: Okanagan Centre
State: British Columbia
Zip/Postal Code: V4V2H6
https://www.woodworkingshop.com/categor ... ELTA+18-36
Try this, the blue zirconia definitely works better, but doesn’t seem to be available in precut.
B
These users thanked the author Bri for the post: Pmaj7 (Thu Feb 06, 2020 12:15 pm)
PostPosted: Thu Feb 06, 2020 11:23 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
On that subject, do they make Zirconia sandpapers to fit Robo Sander drums? The paper doesn't last long and I have to switch them every 2 hour of use because they get loaded up especially if I sand an oily wood like EIRW.
Typhoon Guitars
PostPosted: Thu Feb 06, 2020 11:41 am
The link I posted above is precut. They have it for many different sanders.
PostPosted: Thu Feb 06, 2020 6:49 pm
Last Name: Gramann
City: Fredericksburg
State: VA
Zip/Postal Code: 22408
I’ve been buying precut rolls for the Delta 18-36 drum sander for some time. I just got a reorder last year. I had to poke around on the site a bit to find them. The Kingspor website did not go right to them. Searching for Delta 18 36 gets me this: https://www.woodworkingshop.com/product/dt31818/
They also have the feeder belt.
PostPosted: Thu Feb 06, 2020 8:33 pm
Much thanks all!
PostPosted: Fri Feb 07, 2020 7:31 am
https://www.amazon.com/SuperMax-Pre-Cut ... B007OWX0RC
PostPosted: Fri Feb 07, 2020 4:23 pm
Last Name: shelton
City: Alsea
State: Oregon
Zip/Postal Code: 97324
I don't understand why you would buy pre-cut belts when you can buy rolls so much cheaper. All you need is a used pre-cut one for a template and a few minutes time. I buy 3" X 50 yard rolls at https://www.supergrit.com/products/prod ... eeve-cloth for around $50.
PostPosted: Fri Feb 07, 2020 4:45 pm
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
The bulk rolls I buy have different colored stripes on the back of the abrasive that let me know where to cut for my specific sander. It's very handy.
These users thanked the author doncaparker for the post: Pmaj7 (Fri Feb 07, 2020 6:46 pm)
PostPosted: Fri Feb 07, 2020 5:02 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Exactly. I used to buy the unmarked rolls from Klingspor. Real pain (u had to keep a template). Then they came out with the marked rolls. Just find the color line that corresponds to ur sander, cut, and go. Complete swap takes 5 minutes.
Way cheaper than precut
These users thanked the author Mike OMelia for the post: Pmaj7 (Fri Feb 07, 2020 6:46 pm)
PostPosted: Fri Feb 07, 2020 5:11 pm
Last Name: McDonald
For me the premarked are the only way to go. I don’t believe these are available for all applications though.
B
PostPosted: Fri Feb 07, 2020 6:24 pm
I bought the pre cut rolls from Klingspor. They came in a Jet box. So buying pre cut from them is the same product you get anywhere else.
PostPosted: Fri Feb 07, 2020 7:19 pm
Currently I buy from Fintech, 2"x 50 yards for just under 20$. However, I'm playing broken telephone with the templates, the copy of the copy of the copy is getting hinky so I thought a fresh example would be useful to me.
These users thanked the author meddlingfool for the post (total 2): jshelton (Fri Feb 07, 2020 7:37 pm) • Pmaj7 (Fri Feb 07, 2020 7:30 pm)
PostPosted: Sat Feb 08, 2020 10:17 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Seriously, klingspor premarked rolls the way to go. See their info to see if ur sander is covered.
PostPosted: Sat Feb 08, 2020 10:29 pm
It’s a delta 18-36 so hopefully...
PostPosted: Sat Feb 15, 2020 3:04 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Delta is covered in their cutlines
Users browsing this forum: No registered users and 235 guests
