It is currently Wed Aug 06, 2025 1:10 am
PostPosted: Fri Mar 06, 2020 6:08 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
I was bending wood yesterday on my hot pipe when I heard a loud snap/pop sound come from somewhere close by. That was followed about 10 seconds later by another one. It sounded a bit like the sharp pop sound an electrical discharge can make but I didn't smell smoke. Then I noticed the crack in the wood base of the hot pipe.
Anyone here dealt with something like this? The crack doesn't close up at all under clamping. It doesn't move one bit. I'm thinking of gluing a piece of wood cross grain over the crack like a big cleat to stabilize it. What do you think?
PostPosted: Fri Mar 06, 2020 6:51 pm
Last Name: Colbert
City: Anacortes
Mine is the same unit you have, and so far I've had zero problems with it.
I think your idea of glueing on a crossgrain piece would be fine. If it was mine, I'd likely pull the thermostat, disconnect the cord, flatten that side on your sander, glue up a 1/4" piece of Baltic birch, drill a new hole for the cord and reassemble.
I'm headed to California... wish me luck.
Best, M
PostPosted: Fri Mar 06, 2020 7:13 pm
It doesn't look like it would affect the function of the unit. I would probably just fill the crack with epoxy or put it on "ignore".
PostPosted: Fri Mar 06, 2020 7:33 pm
Last Name: McDonald
City: Okanagan Centre
State: British Columbia
Zip/Postal Code: V4V2H6
Get crafty, clamp, inlay a butterfly key.
PostPosted: Fri Mar 06, 2020 9:49 pm
Make Nakashima san proud!
PostPosted: Fri Mar 06, 2020 10:05 pm
First name: Jay
City: Bothell
State: Washington
Michael's suggestion is a good one, but Brian's suggestion has me thinking. It might just happen.
Clay - I could just leave it but it's on the side that I work from the most. I'm a bit concerned that the crack might get worse because I tend to apply pressure from that side. Right now, the crack goes nearly a quarter of the way through the block.
PostPosted: Fri Mar 06, 2020 10:57 pm
A butterfly cleat would be kind of cool. I knew a sawyer who used to find and cut the planks George Nakashima used in his furniture pieces. That was the first place I saw butterfly cleats used.
PostPosted: Sat Mar 07, 2020 6:38 am
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
What about cutting a new block? It’s just wood with holes.
PostPosted: Sat Mar 07, 2020 6:43 am
Cool ideas but it's a tool, I would probably just drill it and shoot 3" deck screws in it from both sides. Guess I'm a neanderthal.
