It is currently Sat Sep 20, 2025 6:57 am
PostPosted: Fri Oct 16, 2020 2:00 pm
My router took a few nibbles out of my mortise and tenon templates. These are the clear ones that StewMac sells.
I was thinking fill with ca and file smooth, any other ideas for a repair? I’d really like to save it instead of replacing it.
PostPosted: Fri Oct 16, 2020 2:07 pm
You could solvent weld new pieces of acrylic into the divots with acetone.
PostPosted: Fri Oct 16, 2020 3:53 pm
Yeah I always used to just drop fill with CA and file smooth..,
PostPosted: Fri Oct 16, 2020 9:30 pm
Thanks guys, I’ll give one or both of these a try.
PostPosted: Sat Oct 17, 2020 8:14 am
I drilled some small holes in the damaged edge as anchoring points and used epoxy putty once. That was five or six years ago and it is holding.
PostPosted: Sat Oct 17, 2020 11:52 am
Last Name: Dzatko
I have spliced in a tight fitting piece of plexi and used CA glue with success
Paul
PostPosted: Sat Oct 17, 2020 11:55 pm
Epoxy
