It is currently Fri Aug 15, 2025 2:40 pm
 Post subject: King Double Bass
PostPosted: Fri Nov 06, 2020 4:21 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I hesitate to post this. But I’m looking for ideas to repair. Finish feels like polyester. Cracks seem to confirm. Is there a way to do using a threaded rod to push tail block out assuming I can get glue in there? Tail block is def separated on one side of body, not attached well to top or bottom.(endoscope pics)
 Post subject: Re: King Double Bass
PostPosted: Fri Nov 06, 2020 4:25 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I did get the end pin out. It’s a hole maybe 1” in diameter
PostPosted: Fri Nov 06, 2020 5:06 pm
Take the back off.... Violin family stuff is supposed to be made to take apart and re-assemble.
PostPosted: Fri Nov 06, 2020 5:18 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I don’t think they used hide glue Chris. What would u suggest as a technique?
PostPosted: Fri Nov 06, 2020 5:45 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
The back is already separated at damage site. Just work a flat saw all the way around?
PostPosted: Fri Nov 06, 2020 6:43 pm
Is it one of these:
https://www.youtube.com/watch?v=J18q8iaCnys
I wouldn't be too sure they are made to come apart.
I think there was also a Cleveland "King" Bass maker also.
PostPosted: Fri Nov 06, 2020 7:00 pm
Trust me - they should be. Use a knife to work around the perimeter.
PostPosted: Fri Nov 06, 2020 7:41 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Thanks Chris. So it’s a mechanical process. No heat. Just creep around with a knife. Gonna need a crap load of spool clamps. Gonna have owner pay for those
These users thanked the author Mike OMelia for the post: Chris Pile (Fri Nov 06, 2020 9:25 pm)
PostPosted: Fri Nov 06, 2020 7:44 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Clay, that dude in the video appears to be Jason Burns partner. Apparently Burns left King Double Bass because of that guy’s shady business practices.
PostPosted: Fri Nov 06, 2020 9:27 pm
Mike - I'm sure there are how-to videos on YT you can check out... Do you have a violin makers knife, or any of the knives from StewMac? In a pinch.... a butter knife will work, but don't tell your wife (or Mom in my case decades ago).
PostPosted: Sun Nov 08, 2020 10:06 am
First name: Ernest
Last Name: Kleinman
City: Guthrie
Zip/Postal Code: 73044
couple of drops alcohol and a wide artists palette knife can work too. The alcohol softens the hhg. Watch out for the blocks !!!
PostPosted: Mon Nov 09, 2020 12:40 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I have looked inside the bass and I do see blocks on the edges. What is the concern? That I might cause side damage trying to get through one? I was kind of wondering about them.
PostPosted: Mon Nov 09, 2020 3:39 pm
They are deeper than the linings of the bass. You have to be careful with the knife and go easy to keep from cracking the back (is it laminated or solid wood?).
PostPosted: Tue Nov 10, 2020 3:44 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Chris, for what they charged for these things, it better be solid wood. Given the break in the side, I should be able to determine. The sides are incredibly thin. 0.05 - 0.06". Hopefully the back is a bit thicker.
PostPosted: Tue Nov 10, 2020 3:46 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Btw, the rest of the story. Owner had a loose and wobbly end pin. He read somewhere that to fix, wrap the support plug with sandpaper, and then tap in with a rubber mallet. Second strike caused the damage. I jokingly asked if he used a hammer. Well, he did.
PostPosted: Tue Nov 10, 2020 5:45 pm
A hammer, huh? So owner inflicted.... He is on the learning curve.
PostPosted: Thu Nov 12, 2020 8:07 am
Last Name: O'Melia
City: Huntsville
State: Alabama
Rumor has it that the company used Gorilla glue. Looking at the drips on the tail block, I tend to believe it.
PostPosted: Fri Nov 27, 2020 2:52 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Damage area. Back mostly off. Humidifying
PostPosted: Sat Nov 28, 2020 5:24 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Well, it’s wait and see. Had to work the cracks with a mini dremel tool, build an inside and outside curved set of cauls. Lots of padding and tape. Lots of glue!
PostPosted: Sat Nov 28, 2020 5:43 pm
THAT'S the STUFF.
PostPosted: Sat Nov 28, 2020 7:26 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Thank you Chris for ur advice.
PostPosted: Sat Nov 28, 2020 7:35 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I’ve estimated 48 spool clamps with 12” rods to reattach the back. Glad the owner has the dollars to pay for that. He’s not happy about cost, but he (as I reminded him) has learned a valuable lesson. Hammers and musical instruments do not mix.
PostPosted: Sat Nov 28, 2020 9:19 pm
You are most welcome for the phone call, Mike. Highlight of my day, for sure!
PostPosted: Sun Nov 29, 2020 12:06 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Well, it’s back in place. Still ugly, not much to do about that
PostPosted: Sun Nov 29, 2020 4:01 pm
I'm proud of you, Mike! Good job.
These users thanked the author Chris Pile for the post: Mike OMelia (Wed Dec 02, 2020 4:23 pm)
