It is currently Wed Jul 30, 2025 2:17 pm
PostPosted: Sat Jan 02, 2021 12:27 pm
I need to replace the lower tire. There is a wide range of prices on the Internet, so I assume also a wide range of quality. I would appreciate recommendations for a good source.
PostPosted: Sat Jan 02, 2021 1:37 pm
City: U.P.
Urethane for sure, I used http://www.suffolkmachinery.com on my old 17" Parks saw and was happy. Haven't changed out the rubber tires on the 19" Griz yet.
Brian R, Wood Mechanic
N8ZED
These users thanked the author rbuddy for the post: wbergman (Sat Jan 02, 2021 2:43 pm)
PostPosted: Sat Jan 02, 2021 1:44 pm
First name: John "jd"
City: Santa Barbara
Sulfur grove is the manufacturer for many of the urethane tires. Usually cheaper and faster to order direct.
Installation can be tricky. Soaking in hot water helps a lot.
These users thanked the author windsurfer for the post: wbergman (Sat Jan 02, 2021 2:43 pm)
PostPosted: Sun Jan 03, 2021 5:30 pm
First name: Tomás
Last Name: Mac Giolla Ghunna
Country: Éire
Guessing the tire is off the machine or the rubber is cracking...
If not you might be able to dress it.
So you need a new one,
Are you getting a pair?
Have you folks ran different tires on each wheel?
Did they have differing cambers?
Can you dress urethane if need be, like you can with rubber ones?
Suppose I might be overcomplicating things, as you can dress the other one to match, if it turned out to be actual problem.
These users thanked the author Tom G for the post: wbergman (Fri Jan 08, 2021 2:56 pm)
Users browsing this forum: Chris Pile and 8 guests
