It is currently Fri Jul 25, 2025 8:55 pm
 Post subject: Burn mark on spruce
PostPosted: Wed Jan 06, 2021 1:20 pm
Hi there!So i am curious.In old mandolins and bouzoukis they make a burn mark about 1cm behind the bridge. I understand that they make it so as to prevent top sinkage. But i have thought of something else. Is it possible that burning the wood at that point can prevent moisture absorption at that point?So the instrument is playing better?
 Post subject: Re: Burn mark on spruce
PostPosted: Wed Jan 06, 2021 1:51 pm
Last Name: G
The scorch mark is from "pliage", which is where the wood is heated over an iron to actually bend the wood to give the wood more of an arch. Sometimes it is lightly cut to introduce the arch instead. (It also helps with the string break angle to to the tailpiece.) Selmer guitars sometimes used the same hot pipe technique. Take a look here:
https://bumgarnerguitars.com/2014/04/03/pliage/
On some bowl-back mandolins you can see the crease where the pliage was done, as there is actually quite a sharp bend there.
It's really unlikely that it has anything to do with moisture transfer.
cheers, SteveG
These users thanked the author SteveG for the post (total 2): pikolo (Sun Jan 17, 2021 6:22 am) • Colin North (Wed Jan 06, 2021 2:26 pm)
PostPosted: Wed Jan 06, 2021 2:05 pm
First name: Richard
Last Name: Hutchings
City: Warwick
State: RI
Zip/Postal Code: 02889
Word of the day "Pliage". Thanks, I'm going to start using that one.
Hutch
PostPosted: Wed Jan 06, 2021 2:32 pm
I just used it nudiustertian conversation.
PostPosted: Wed Jan 06, 2021 2:38 pm
First name: Richard
City: Warwick
State: RI
What the heck, and there's more. nudjwhodiwhatsis :-)
Hutch
